Question about Canon imageRUNNER 400S Copier
Cassette not lifting making noises.
DURING INITIALROTATION CASSETTES NOT LIFTING THE COPIER MAKING NOISE.
  • Canon Expert
  • 1,326 Answers
If the paper is in the paper tray correctly, you can try to remove the affected cassette. Look inside for a wade of paper blocking the paper present sensor. If so remove the jammed paper. If that is not the case, you will have to have the lift gear replaced in the paper feed unit. It is a Black half moon gear... It is not easy to replace..... Mostly, it is the top paper tay. If you can't afford to have the work done? I would not use the tray & change one of the other trays to the paper tray..... Good Luck
Posted on May 30, 2010
What corrective action for a 'no paper, add paper' message?
Please take out the paper cassette tray and see if there is a paper sensor hanging down underneath the machine. Also check to see if the paper cassette tray is lifting up. The tray should make a noise when lifting up. Check to see that the printer recognizes the correct paper size.
Jul 09, 2015 | Dell 2155cdn All-In-One Laser Printer
Why is my Sony DV VTR DSR-45 is making a loud screeching while in FF or REW?
That noise is coming from ur capstan motor.Can u check ur running hour if it more then 3000 or more hour u need to change.
Aug 01, 2014 | Sony DSR-45 Mini DV VCR
Noisy Dishwasher
it is a capacitor to start the motor for the next cycle. I think it is inside the door. you may have to call a tech.
May 19, 2013 | Whirlpool GU2300XTVQ Builtin Dishwasher
What kind of cassette comes with the Rol Volant. It sounds kind of noisy. Should I replace with a Shimano 105 cassette that I have.
If you mean the noise while coasting, cassettes don't make that ratcheting noise. The pawls in the hub/cassette body do. Changing the cassette will not change the sound.
http://www.rolwheels.com/rol_volant_wheels.php
http://www.rolwheels.com/contact_us.php
May 06, 2011 | ROL Wheels Volant
During the spin cycle it makes a loud noise "knocking" sound. It's not off balance.
I will assume this is a top load washer. Unplug the unit. Use a wedge piece of wood or a non marring tool to lift the front of the top cover and tilt it back on the hinges. Be careful of the load lid when lifting it back so it will not fall freely back making a loud noise. On each edge of the drum there are support rods in rubber shock absorbers. My guess is the rubber is deteriorated and you need to order new ones.
Jan 14, 2010 | Washing Machines
Mi copiadora sharp AR5125 tiene codigo U6
code Sub code U6 00 Content Desk communication trouble Detail Failed communication with desk Communication line test error occurs when power is turned on or after the exit of a simulation mode. Cause Improper connection or broken wire of connector or harness Desk control PWB defective Control PWB (PCU) defective Malfunction due to noise. Check and remedy Clear the trouble by turning the power supply On/Off. Check communication line connector and harness. U6 01 ~ 03 Content Desk 1, 2 and 3 CS lift-up trouble Detail Desk cassette lift-up trouble (1st - 3rd cassettes). Cause Defective sensor RADF control PWB defective Broken gear Lift-up motor defective Check and remedy Check lift-up sensor detection with SIM4-2
Nov 03, 2009 | Sharp AR-5316 Advanced Digital Imager...
I have a Toshiba 3560 copier. Its stating 'CASSETTE OUT OF ORDER' Any suggestions on getting this beast up and purring again?
Either there is paper trapped behind that cassette preventing lifting mechanism from lifting paper up to feed height.....or the lift drive assembly has failed. Pull the tray out until it stops, then lift front side of cassette to release/remove it. Look into opening towards right. If no paper, turn copier off then on....this should clear the 'cassette out of order' message. Now, reinstall your cassette. Make sure there is less than approx. 1/2 inch of paper in cassette, then insert cassette fully. It should attempt to raise up....if you hear popping noise during lifting process, the lift drive assembly needs repaired.
Sep 15, 2009 | Toshiba Office Equipment & Supplies
Paper won't load from both cassettes
is the copier seeing the paper in the cassette, if yes then your pick up assy. connectors could be loose or your pick up assy s. are bad. try switching the assy first before replacing also check your connectors
Jun 19, 2008 | Canon CLC 1150 Color Copier
Noise block doring playback of D-VHS tapes
* Do not record program in DVHS mode on an S-VHS cassette. Use of S-VHS cassettes will not allow for maximum performance and may result in head clogging. Use only D-VHS cassettes as recommended in the instruction manual on page 27. * Make sure that the DIGITAL 3-DNR lamp is ON when playing back a cassette recorded in D-VHS mode. If not press DIGITAL 3-DNR so that the DIGITAL 3-DNR indicator illuminates. * When block noise appears on the TV screen, clean the video heads with the DFC-2 D-VHS Head Cleaning Cassette (continue up to 3 minutes total). Please refrain from using any other head cleaning cassettes as drum damage may result.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Canon imageRUNNER 400S Copier Logo
89 people viewed this question
old marine
old marine
