Question about Hoover F5872-900 SteamVac Wet/Dry Vacuum
No sucking with hand attachment on Hoover steam vac 5870-900
How do you get stair attachment to **** after it sprayes the cleaning solution -- spray but no sucking with hand held attachement
SOURCE: NoSuckage !!!
I noticed on the bottom of the tank there is a rubber gasket that seals the recovery tank to the machine base the one I borrowed the gasket slipped of and the suckage decreased dramatically.
Posted on Jan 12, 2008
Agent Don
  • 310 Answers
SOURCE: Constantly sprays water
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=515776&thid=544922
Posted by elstretcho on Apr 25, 2008
Hoover F7452-900 SteamVac Upright Vacuum
I noticed recently that our Hoover F7452 All Terrain constantly sprays water. As soon as I turn it on, whether or not it's set to Rinse or Auto-Rinse, its leaking water at the brushes. I probably wouldn't have noticed but I attached the hand-held adapter to clean our stairs and when I was done there was a HUGE pile of water under the vac. I took everything off and cleaned really good and looked again this morning and its still doing it. Any ideas?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You probably have a bad trigger release valve or a loose connection @ the bottom of the SteamVac or the gasket under the solution tank in not sitting on there right and is leaking or you may have a small cut in the hose, but it so may guess that it is a bad trigger release valve or a bad gasket. Check with your local vac dealer to see if they have a new or a good used one to see if there is the problem or back track the problem from the bottom to the solution tank. So If you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Posted on Apr 25, 2008
micromaster
  • 3614 Answers
SOURCE: lost instructions for hoover steam vac
kindly please wait...
Posted on Jul 13, 2008
SOURCE: hoover steam vac model F5853-900 series 17.9
Make sure that the recovery tank is completely close.
Posted on Jan 20, 2009
  • 909 Answers
SOURCE: Lost Manual for Hoover Steam Vac Model #5906-900
Visit www.hoover.co.uk
There you can pick after sales service,instruction manuals, etc. etc.
You will find your manual there.
I hope this helps
Posted on May 13, 2009
I have a hoover steam vac LS 3600 and i attached the tool to clean my couch. the tool is sucking but no solution is coming out. i checked the hose and everything looks ok but no solution will come out of...
There is a small pump inline of the spray unit. This is normally a coil type reciprocating type and most often this can be dirty or faulty.
So remove pump and check it on table to see if this works, if not clean or test coils for continuity. If not replace.
Sep 08, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Attach furniture/stair cleaner ?
Please look at the user manual at the following link:
http://www.hoover.com/pdfs/manuals/F5871900.pdf
It is for a similar Hoover Steam Vac model.
Oct 30, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Hoover steamvac won't spray water/cleaning solution
Clogging of the pump that sprays water/cleaning solution is very common in Hoover and Bissell Steam Vacs. Try running a cycle of 1part vinegar or CLR to 3 parts warm, distilled water through the vacuum pumps. The heads get clogged with soap and the water pumps get clogged at the opening of the flash heater due to minerals in hard water. If you want to extend the life of your steam vac, don't use the heater unless you are using distilled water. This can get expensive, so I recommend not using the heater.
Sep 11, 2009 | Hoover F7431-900 SteamVac Vacuum
I have used my Steam Vac for carpeting, but until today, had never tried cleaning upholstery with the spin-scrub brush. I spent a miserable afternoon trying to control the spray, which seemed to go...
I can sympathize. My vac came with two handheld attachments. I have better luck with the handheld attachment that doesn't have the spin-scrub pads. To keep the water from going all over the place, you need to keep the part the you hold only about 1 inch from the surface of the upholstery; if you hold it higher it gets everywhere; if you hold it lower the spray doesn't spread out wide enough and it just makes big water droplets that roll down the upholstry.
If the vac isn't sucking up the water, it is likely you have it set up wrong. Take off the attachment; if you put your hand over the open end of the tube, do you feel suction? When you are using the handheld attachments there is a rectangular piece you remove (attached to the dirty water tank) and you stick the rectangular part from the hose in there. If you are getting suction but it's just not sucking up any water try these 1) maybe you aren't laying down enough water, spray it more heavily OR 2) you need to **** up the water right after you lay it down. Don't let it soak in for more than a few seconds.
good luck!
Aug 17, 2009 | Hoover SteamVac F5914-900 SpinScrub...
MY hoover steam vac hand held hose cleaner leaks profusely
try taking a sharp knife and shaving a little off the edge of the plastic, or a small file if you can get to it, see if it is getting binded. If its getting stuck internally, you will have to replace the switch instead of risking takin it apart.
Jul 09, 2009 | Hoover F5810 SteamVac Upright Vacuum
Hoover Steam Vac leaks like a sieve
I have the same problem with my hoover steam vac, different model but same problem. So I have had it for 2 years and never used the attachments because the thing leaked out the bottom when i tried. So today I tried to find a solution online and found nothing. So I started toying with the thing and found a solution for my model and I hope it will work for everyone else. I don't have a stair attachment so this goes for the upholstery cleaning attachment. I noticed right where my upholstery attachment connects to get soap, there is a second hole that is covered by a white rubber seal when the cover for the connection area is closed. I put a plastic bag, or anything to seal it, into this hole to make a tight seal. Tried the machine and worked like a champ. So Would be nice if hoover supplied a plug for that, but oh well worked for me hope it works for others with a hoover steam vac.
Jan 04, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steam Vac clean water tank valve leaks
a) make sure that there is not a place for a stair attachment. If
there is make sure air is not leaking through where the attachment goes
on because of damaged or misplaced fitting.
b) some steam vacs leave water behind them and **** up in front of
them. If you just walked forwad with the steam vac nothing would be
sucked into the tank.
c) try taking your finger off the trigger and using the steam vac. If
the tank still empties the trigger is stuck open.
d) try putting clean water in the dirty water tank only and using it on
a dry rug. If water goes somewhere from the dirty water tank you have
a leak.
e) take apart what you can and look at the parts. A good visual
inspection can solve many of these types of problem if you are careful
not to miss anything.
Nov 06, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Apr 25, 2008 | Hoover F7452-900 SteamVac Upright Vacuum
Stair and upholstery attachment
After tearing things down and inspecting the handle switch, etc., I found that my problem was detergent. It sets idle for a while or doesn't get used very much and the detergent dries and actually clogs the inside of the hose. I cleared it by fully extending the hose, pressing the button and allowing the clog to clear itself. The built in heater helped out a lot once the flow started again. I used a can of compressed air to provide a little blow back to get things moving but not too much or the pump would be damaged. Remove the tool and hold the nozzle into an empty cup while depressing the trigger. A warm vinegar solution clears things out nicely. It's kinda hard for this piece go defective but easy to overlook when wrapping up and storing the unit. Remember, clean water rinse with 1/4 cup white vinegar. There, I fixed it and wasn't even broke!
Apr 08, 2008 | Hoover F5881-900 Vacuum
Hoover F5872-900 SteamVac Wet/Dry Vacuum Logo
26 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
