Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Morning! My name is Joe; is anyone there? I'm trying to diagnosis this wpl cabrio washer that the inner tub wabbles around even on empty. The model is wtw6300sw0. What can be tthe solution?
  • th4201 May 29, 2010
    This is a classic case of "how much is too much?". On a Cabrio washer the tub is supposed to be able to rock back and forth and left and right just because of how it's suspended. If the inner tub isn't rocking in sync with the outer tub, then you have a problem. Can you describe what or how it wobbles? Does it cause any sort of problem when it's agitating or spinning?
  • Whirlpool Master
  • 8,220 Answers
Leaking at tub
you might need a new inner tub. you can order a new one at www.repairclinic.com. you can click the second blue link to order.
http://www.repairclinic.com/PartDetail/Inner-Tub/W10296143/1553051?modelNumber=WTW6600SB0
Mar 29, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio loud noise
Check your bearings. This post will show you most of what you need to know about your bearings:
http://www.squidoo.com/how-to-replace-bearings-in-a-whirlpool-cabrio-maytag-bravo-or-kenmore-oasis
Nov 06, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
2007 Cabrio does not agitate, flashes oL code even when empty
The OL error code indicates that the washer is overloaded. If the washer is not overloaded, this would indicate either a drag on the drive system or the control board is failing. Be sure nothing is on the floor under the washer that could be causing a problem. Raise the lid & manually spin the basket, it should spin freely. If not, you may have an item stuck between the spin basket and the washer tub.
Oct 14, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
My tumble action washer spins out of balance no matter if it is leaded with clothes or not
turn the tub by hand and see if it wabbles if so only one fix replace inner tub.
Sep 28, 2010 | Kenmore 43142 Front Load Washer
Love my Cabrio,but have had to have serviced four times due to a coin or button getting from the tub into the pump and making a hole in the pump. I try not to let anything in, but I'm human . Has anyone...
Yes. The way to get coins out is to:
1) Remove the white cap inside the tub and then remove the bolt. Pull that section off.
2) use a putty knife to push in on the two locks about 6" in from each side that hold the top to the main body of the washer and lift up the top into the maintenance position
3) Unclip the hose from the tub and remove
4) There is a white ring around the top that is clipped to the outer tub multiple places. Pull it out of the clip and remove this.
5) Lift the inner tub out
6) At the bottom of the outer tub, there is a white plastic cap above the motors with two bolts to remove.
Once you've removed all these, you should have found all the hidden coins. Reassemble everything and then be very careful about checking pockets before using the machine!
Mar 12, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
It sounds like my whirlpool cabrio topload washer has a coin in it rattling around but the tub is empty. What if anything do I need to do?
Take the back off and run it take a flashlight and look inside for something that might have come loose.Hope this helps have a great Thanksgiving.
Nov 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio won't balance even empty
Check the four suspension rods on the outer tub to make sure they are not broken and/or out of placement.
Jun 09, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Sock stuck in outer tub whirlpool cabrio
youll need to "pop" the main top.. then unsnap the outer ring that cvers the outer tub. if you look at the center of "agitator/ or bump plate depending on model" theres a small cap that will come of fand reveal a 7/16 screw remove the screw, and then oyull be able to lift the entire inner basket right out to retrieve any debris.
Feb 14, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
436 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
