Question about Estate TAWS800JQ Top Load Washer
Lid not turning washer on - Estate TAWS800JQ Top Load Washer
  • 24 Answers
Sounds like a lid switch problem most likely. When closing the lid, slowly lower it and listen/feel for a "click" when the lid is about 3 inches from being completely closed. If you don't, then you have a broken lid switch.
The model of washer you listed, TAWS800JQ, has two different possible lid switches and you get to them differently.
To get to the lid switch, you need to remove 2 screws that hold the control console in place. There is 1 on the left and 1 on the right of the console. They can either be on the front side and easy to see, or on the back side. Loosen those screws so that the console is free and you can flip it up and backwards out of your way.
One type of lid switch can be seen on the left side after you flip the control console up and back out of your way. There is just a little clip that holds it in place. The lid needs to be raised in order to remove the lid switch. Unplug the wiring harness and replace.
The other type, do this:
Then use a flat blade screwdriver to remove the brass spring clips on the left and right side of the washer that hold the front/sides/top on. Unplug the lid switch in the middle of the washer top and then you can remove the wrap-around cabinet. The lid switch is under the top and is held in place by clips and 2 screws.
Posted on May 29, 2010
My washer sensor turns on and then the lid light starts flashing and the washer will not turn on. What is wrong with it?
What is the model number listed on the unit?The lid lock assembly is broken. If you are under warranty get it replaced. If not remove the top of the washer and take out the switch assembly. The 4 wires going in are Yellow, Red, White, and Blue. If you short the white and blue together, the washer thinks the lid is closed. If you short the red white and blue together the washer thinks the lid is closed and locked. The yellow is only there to activate the electromagnetic switch.
Disconnecting the switch assembly will not work.
The electromagnet locks the lid and it also unlocks the lid. It is not a matter of cutting the power to the magnet.
Installing 2 switches that connect the red white and blue is the best option if you want to remove the lock.
The first switch should connect the white and blue. (LID CLOSED)
The second should connect the red to the white/blue connection. (LID LOCKED)
Nov 18, 2012 | Maytag Centennial MTW5800TW Top Load...
Want to disengage lid lock on maytag centennial
I had the same problem. The lid lock assembly is broken. If you are under warranty get it replaced. If not remove the top of the washer and take out the switch assembly. The 4 wires going in are Yellow, Red, White, and Blue. If you short the white and blue together, the washer thinks the lid is closed. If you short the red white and blue together the washer thinks the lid is closed and locked. The yellow is only there to activate the electromagnetic switch.
After that the lid should work.
Please post a follow-up if this works for you.
GOOD LUCK
Jul 09, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
Washing machine stops on rinse on all cycles
this could be a timer problem, or the cold water may be shut off.....if it is advancing to the rinse point but not filling, then there may be a problem with the fill valve also. You may want to check the lid switch too, just to be sure it is making contact.From what you are describing it sounds like the problem with your washer could either be the lid switch or no cold water. However there are a number of other possibilities. I would recommend checking the lid switch first. Open the lid & you should see the lid switch actuator mounted on the lid. This is the probe that pushes in on the lid switch as you close the washer lid. Next you can check the lid switch. The lid switch is hidden under the top of the washer. You will see a small opening where the plunger comes down at & activates the lid switch. You should hear the switch click as the lid is being closed. You can also use a small non-metallic probe to push in on the lid switch. If the lid switch is not responding, you will need to replace the lid switch.Next you will need to check & make sure the cold water is turned on. You may want to turn the water off & take the cold water fill hose off of the back of the washer. Use a bucket & turn the water back on to check the incoming water pressure. If the water pressure checks good & the washer is not filling for rinse, you will need to replace the water valve.If you have good cold water supply & the lid switch checks okay you will need to access the inside of the machine to make more checks. Be sure to disconnect electrical power before attempting any repairs. Please resubmit your question if you need further assistance.Good Luck
Oct 27, 2011 | Roper Washing Machines
My Roper Washer RTW43405Q0 won't spin.
For the washer to operate the lid must be fully closed, the timer must be pulled out, and the water must be drained.
The main causes for not spinning are:
  • Lid partially or completely open
  • Lid or other object has hit the timer knob and turned the washer off
  • Lid not locked (by the way, not on all washers) and may be not draining.
    Make sure the lid is completely closed. Make sure that no clothing is in the lid area.
    Make sure the Timer knob is pulled out.
    The lid must be closed and locked for the washer to operate. Once the lid is closed, make sure the desired cycle is still selected and then press the Start button and listen for the lid to lock.
    Make sure there are no loose metal objects such as coins and paper clips in the lid opening area. Metal objects can prevent magnetic switches from reacting correctly when the lid is closed.
    If the washer has not drained, it will not go into spin.
    Hope this works.....
    May 01, 2010 | Roper RTW4300SQ Top Load Washer
    My Admiral washer will not spin.
    Unplug the washer.
    Insert a putty knife between the top lid and the front panel,where the top meets the front. About 2 inches in from each side are 2 clips that must be pressed inward to raise the lid.
    Once the lid is raised,remove the 2 wires from the lid switch and jump them together with a small jumper wire.
    Plug the washer in again and turn the dial to spin and turn it on.
    If it spins,replace the lid switch.
    Jan 17, 2010 | Washing Machines
    My washer turns off when i shut the lid...turns on with weightlid
    Check your lid switch. The lid switch is toggled by the action of the washer lid closing and it will not complete a cycle if it does not engage. It sounds like the switch may be loose and needs to either be adjusted, or tightened. If you need instructions, please post back with a brand name and model number so that I can explain how to access the switch. I hope you find this helpful.
    Oct 04, 2009 | Washing Machines
    Washer will not turn on. The knob moves but nothing happens when I turn it on. I've checked the breaker, the water, the plug/outlet, and hoses. Everything looks fine. But nothing happens.
    If your washer doesn't seem to work at all, check these:
    No power
    Lid switch
    No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
    Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
    Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
    May 05, 2009 | Whirlpool LSR9434PQ Top Load Washer
    Washer filled with water then nothing
    This is commonly caused by a lid switch malfunction. If your model number is correct, the lid switch for your washer is located under the right hand side of the washer casing along the wash tub rim. The switch is activated by a small plastic piece on the washer lid (called a "lid strike") through a small hole. The switch contacts close when you shut the lid. In many cases, the lid switch either comes loose, or the lid strike breaks off. In both cases, the washer will exhibit the symptoms you describe. Open and close the washer lid and listen for a distinctive "clicking" sound as the switch is activated. If you cannot hear the switch, make sure the lid strike is intact and the mounting screws for the lid switch (located around the wash tub opening on the casing) are tight. Sometimes, all it takes is to tighten the lid switch screws to realign it with the lid strike. If the switch is defective, or the strike is missing, parts can be ordered on line at searspartsdirect.com. Just type in your COMPLETE model number (include the "110" prefix), which can be found on a nameplate under the washer lid. The lid switch will be listed under the "Top and Cabinet" heading as item number 11. The lid strike will be listed as item number 20. Other sites that offer competitive pricing are repairclinic.com and appliancepartspros.com. If you require instructions on how to replace the switch, you may use the following link:
    http://www.fixya.com/support/r385198-replacing_lid_switch
    If you have questions, or if the diagnosis is incorrect, please let me know. I hope you find this information helpful.
    Jan 11, 2009 | Kenmore 22422 Top Load Washer
    Kenmore 110.24622 will not wash, rinse or spin. No noise at all
    most washers have a lid safety switch which cuts all power when lid is raised, typically a small "prong" is attached to the lid which fits into a switch in the body of the washer
    Jan 10, 2009 | Kenmore 22422 Top Load Washer
    Estate TAWS800JQ Top Load Washer Logo
    140 people viewed this question
    Top Estate Washing Machines Experts
    Dan Webster
    Dan Webster
    dweatherby
    Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
