Question about Dell XPS 200 PC Desktop
Reving,loud - Dell XPS 200 PC Desktop
    Brigadier General:
  • 10,406 Answers
Restart your computer -- there may be some "run-away" program on your computer that is working the CPU to its maximum.
Also, there are some heat-sensors inside your computer, i.e., the hotter that the inside of your computer is, the faster that the fans will run.
Check that the fan on top of the CPU is still working -- if not, your CPU will generate a *LOT* of heat.
Also, turn the computer off, and take a can of compressed air, and give your computer a "blow-job" to remove all the dust from inside your computer -- dust makes a great insulation, thus making your computer run "hotter" (and making the fans work harder/louder).
Posted on May 29, 2010
Engine knocking i reved up the motor a loud pop sound came from under the hood now the motor will only turn a little bit even by hand before locking up tight. any ideas?
From your descripion you may have spun a rod bearing. I haven't really seen any timing chains break persay. You usually hear a rattling sound coming from the front of the motor but you can still rev it up.
It sounds to me like you might want to clean out a pan large enough to drain the engine oil in. Drain the oil and look for small metalic flakes. If you see any, it's time to call some salvage yards and shop for a low milage motor(less than 100,000 miles) If you are lucky, you might stumble upon one with 50,000 miles or so. It's probably the motor though. If the chain broke, the upper end of the engine is going to be scrap metal anyway because the valves would have hit the pistons and bent..It would still be cheaper to replace the motor with a used one. Good luck
Mar 12, 2014 | 1994 Nissan Pickup
Loud ticking like the battery is died and a low deep thump in the exhaust wont stay running
google youre model jeep followed by the word forum join and post there
Feb 01, 2013 | Jeep Cars & Trucks
My 2000 passat just started making a loud noise when i accelerate and it seems like its moving slower in acceleration and reving higher
my good friend I believe the solution I give might be not good for you as to what you state It sounds that you are loosing your automatic gear box. Have you ever changed the oil & filter of your Gear box? If not that was the reason.
Aug 15, 2012 | Volkswagen Passat Cars & Trucks
My computer makes a loud sound, like reving up an engine, drives me crazy, could you suggest something
this is probably the cooling fan in the power supply. replace the supply or try a drop of oil to the fan shaft
Apr 15, 2011 | E-Machines eMachines Desktop PC
As soon as i kick the bike over it over reving really loud
Be sure that the slide in your carb is in corectly, if it in wrong it won't allow the slide to drop all the way down. Check for cable adjustments.
Nov 02, 2010 | 2004 KTM EXC 250 Racing
Vfr 400 nc24 whining noise when engine is reved
The loud whining noise is just normal for vfr 400 because it is gear driven cam.. As you reach 5000rpm up, the bike's electrics try to misfire the plugs so it would act as a speed limiter (180kph).. You have to bypass the sensor at the speedo..
Sep 28, 2009 | 1988 Honda VFR 400 R NC24
Engine makes loud humming noise when reved up and being driven
I would get it to a real mechanic and ask him about a failing timing chain. If that is ruled out next I would check the power steering pump.
Sep 23, 2009 | 2001 Saturn SL
Wr250f 2001.riding bike reved and stopped wont kik properly
if this is a two stroke,then if you have run it out of fuel,there is no lubrication for the piston and you may have damaged the piston or piston rings,check the compression,esay test is remove sprk plug pit your finger hard into the hole and crank the bike over,if your finger gets pushed off with loud crack sound then compression should be ok,but if it doesnt and the preesure is very weak then you will be looking at a top end rebuild,hope this helps
Jun 24, 2009 | 2003 Yamaha WR 250 F
Dell XPS 200 PC Desktop Logo
136 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
