Question about Sony STR-DA90ESG
Wiz sony I?m getting protector error on my Sony STR-DA90ESG
  • 1 more comment
  • wizlouis Apr 08, 2008
    Do you have a good repair shop in Brooklyn
  • Anonymous May 03, 2008
    I have the same model, same problem. I understand that one or more of the output transistors are shorted. I took it to a repair shop in Orlando. My problem is the repair tech said there are 16 (I think) output transistors and they are around $25 each his cost - he showed me in his parts book.
    He said no way to tell if one was bad, a few, or all, without expending the labor to lift their legs off the circuit board, and he was not going to order 16 replacements which would cost him $400.
    So I am stuck. I used to repair commercial power amplifiers so I could do the work myself but the way consumer units are built 0 including this one - its a real pain to get in there and isolate each output drive transistor to see how many are blown.
    I love this unit, despite its use of non-standard IR carrier frequencies, which is why no programmable or universal remotes can learn its codes. But s allows separate routing of audio and video, which is a rare feature in consumer units.
    Any advice is appreciated. It seems to be the COST of the replacement transistors and the labor to find out how many are even bad that is why this repair shop just handed me the unit back. Maybe another repair shop in the Orlando area ?
    Thanks !
  • bbittel May 05, 2008
    Trying this once again now that I have been able to establish a user account - sorry for repeat post but I REALLY want to get my DA90ESG working !! Any help is most appreciated -
    in his parts book.
    I love this
    Any
    Thanks !
  • 4,234 Answers
The receiver has detected a problem in the final output stage and has shutdown to prevent further damage to either the amp or the speakers. The most common cause of this is shorted output transistors. Figure about $15-$30 for parts plus the local labor rate.
Dan
Posted on Apr 08, 2008
How do i get my sony DA30ES am -fm reciever out of protector mode
Here is a guide for you: STR DA30ES Protect
let us know how , if you need further assistance.
Jun 09, 2012 | Sony STR-DA30ES Receiver
My sony str- is getting a sony protector check code 22. Is that a fuse problem or do i have to get sony to fix it? napa.king@yahoo.com
Unfortunately this is not a fuse problem, as the fuse would burn before the protector check code appears. Probably there is a short circuit and you should take to an authorized sony repair shop. Good Luck.
Flavio/BRAZIL
Jul 22, 2010 | Sony STR-DA5000ES Receiver
SOny DA90esg sound distord like it have a cold ? any ideas
Check your wiring. Sounds like your "out of phase" The easiest way to tell if this is the problem is to adjust the balance from left to right. all the way on either side should sound good, then move to the middle and it sounds dead. That's it. Find your speaker wire that has the + and the - reversed and switch. If this is not the fix, post a comment and I can help you dig some more. Hope this helps
Jun 24, 2009 | Sony STR-DA90ESG
Error code - protector
Try disconnecting all the speakers from the back and turn the unit back on. If the "protector" display goes away, turn the unit back off and reconnect one speaker. Turn it back on and check for "protector". Repeat.
If you find that one of the speakers causes "protector" to appear, you either have a bad speaker cable or bad speaker. Try swapping each of those out to see what happens.
Apr 20, 2009 | Sony STR-DA90ESG
Sony str-de525 system "protector" problem
You've blown it. It recognizes a potentally harmful situation and goes into protect mode.
Mar 15, 2009 | Sony STR-DE935
Function Selector Bypasses Input Sources
Hopefully this post isn't too late... That receiver has the ability to disable certain inputs. The easiest thing to try is to do a factory reset.
1. Turn off the receiver
2. Hold down DISPLAY and PANEL UP/DOWN buttons and press power.
3. All Clear should appear on the screen.
Unfortunately, this clears out all of the other settings on your unit. It should, however, re-enable the inputs.
Let me know if this helps!
Dec 28, 2008 | Sony STR-DA90ESG
Direct tuning
Unfortunately, according to the manual you can not directly tune a station.
Dowload the manual here:
http://esupport.sony.com/US/perl/model-find.pl?mdl=STR-DA90ESG
and go to page 50.
Oct 23, 2008 | Sony STR-DA90ESG
I don't have the remote control
You need remote control for STR-DA90ESG, its details are as follows...
1-475-133-11 RM-H501 REMOTE CONTROL
Currently In Stock: Yes Unit Price (in USD): $98.95
Its available at Sony Accessories, enter model number of unit in search box and see details.
Sep 27, 2008 | Sony STR-DA90ESG
Protector mode
The problem is that the output transistor(s) are shorted causing the unit to shutdown in what is called "protect" mode. This is a common failue and should be easily repaired by a service shop for about $25-$40 in parts plus labor.
Dan
Mar 17, 2008 | Sony STR-DA90ESG
Open Questions:
sony DA90ESG I have a Sony Receiver DA90ESG i have it for a while and its one of the best receiver i ever come across. Never the less i was playing it the other day and i heard a pop in the front speakers i was using the MD moode witth regular audio cables. I notice some of the displaying light were dim like it was not getting enuff power. After i check the wires ect i turned it back on the display said ' OK ' It was ok for a while and then the other day i was playing it again and the sound went. The same display light was dim and the light on the volume went off but the display was up. I tried checkng the wires and everything seems to be ok. After i left it off for a while and turned it back on it played for a short time and then no sound. I saw an unusal display it reds ' AC-3 RF' when i put the recevier on tuner the sign comes of but still no sound. I turned it off again for a day and it start playing again but after 5 mins the sound went again and the same display comes up again AC-3 RF' Could you tell me if it some thing that iam not doing or should b doing, or should i give it out to be fixed. PS When the sound chips out and u try to open the lever it just go up and down repeatedly at a slow pace and wont close, but when the receiver starts to work the lever moves freely and closed itself. It seems like a power problem not sure but any help will be gratefull dont want to buy ny other recevier. Regards Desi Wilmot desilee2000@hotmail.com
Feb 28, 2017 | Sony STR-DA90ESG
Sony STR-DA90ESG Logo
167 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
