Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
5 month old Whirlpool Cabrio washer has moldy smell. Tub seems to empty well. Any ideas?
  • 24 Answers
Smelly washers are common. Cabrio washers are HE and therefore use less water. By using less water, it doesn't rinse ITSELF as good as an older non-efficient machine. Things you can do to solve the problem. Buy a cleaner from Whirlpool called Affresh. It's 3 tablets that you throw in the washer without clothes and run it on the longest heavy duty cycle possible. Use the hot water setting and the longest duration. For existing smells use all 3 tablets. Then use 1 tablet every month to prevent reoccurring odors. You can also try the same type of cycle on hot water with a half of a gallon of bleach in the tub, or try it with a half of a gallon of vinegar. One of the 3 should do the trick.
Posted on May 29, 2010
Top load washer smells like rotten eggs when water is draining into tub
As someone who has had a deep well drilled and found water, but water contaminated with iron and sulfur, I can tell you first hand about the rotten egg smell. The water softener will remove the iron that can turn clothes orange, but doesn't do anything to remove the rotten egg odor. You will need a charcoal (carbon) water filter to eliminate the sulfur smell.
Sep 19, 2014 | Whirlpool WTW8600YW: 4.6 cu. ft. Cabrio...
My LG front loading washer smells like wet clothes that have been in the washer for months? Musty smell?washer overnight? Strong smell of musty old clothes
This is caused by the biomass built up inside the tub of the machine. This can also be caused by a moldy door boot. You need to scrub your door boot between the tub and the door. Water settles in the bottom of it and molds. Once you clean this, order affresh washer cleaner for your machine. This kills all the biomass built up in the tub and removes the smell. You will put all three tablets in the drum and run on the longest hottest wash available. When this is completed your machine should smell much better. To keep this from getting so bad again... Keep the washer door cracked open between cycles. This keeps the inside from smelling. Hope this helps
Apr 04, 2012 | LG WM-2277HW Front Load Washer
Our laundry smells moldy since we bought cabrio several months ago. We've done everything we know to fix problem ,, but are not happy with the service of this machine or smell of our clothes at all!!
have you tried the super cleaner that works to clean just about everything--- vinegar
I dont know for sure if it affects several washers of that model but i have been a appliance tech for 30 years and haven't been to service that problem ever, the cabrio is what i have in my home and love it,cleans well without any foul smells
Jul 31, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Our front-loading HE washing machine delivers
try putting in 2 caps of a citrus or pine bleech straight in to the drum with some old rags. then select a boil wash. the rags will spray the water around the tub, the bleech will clean the tub and make it smell fresh. DON'T put any clothing in whilst doing this. if you are worried about bleech in the machine just select a rinse cycle after. i do this once every 3 months
Aug 05, 2009 | Maytag MAH2400A Front Load Washer
Moldy smell in front load kenmore washer
Run an empty load with bleach and detergent and/or ammonia on hot.
Dec 21, 2008 | Washing Machines
forget the vinegar, theres a product www.affresh.com this will help. you also MUST USE HE( high efficency) DETERGENt. reccomneded amount is 2-3 tablespoons. regular detergent, and too much fabric softener is possibly adding to the moldy/musty smell..
Nov 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Moldy smell
Turn it off, unplug it. Remove filter and check if filter and/or filter and pump housing are clogged with something "smelly". When you're at it check the drain pipe for too.
May 08, 2008 | Kenmore Elite 45986 Front Load Washer
Washer does not spin
I had the same problem in october- my had a bad wiring harness, some board problem, and a bad sensor. if it hadn't been under warranty the cost of parts alone would have been over 1000bucks.
Dec 19, 2007 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
1,858 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
