Question about Fedders AEY12F7F Wall/Window Air Conditioner
My Fedders AEY12F7F-D has stopped working after only 2yrs. Two a/c company's have said it's the motor and to just replace the entire unit or fix it for $400, it turns on but just doesn't do anything. Should I take the motor out and have it rewound?
5 Suggested Answers
  • 12 Answers
SOURCE: I have a thru the wall fedders ac unit. The heat
no blower !!! or heating element is bad or switch try putting the fan on only if it works than it is probaly the switch not letting the blower on only heat
Posted on Apr 01, 2009
  • 674 Answers
SOURCE: purchased a fedders a/c 18000 unit still under
Check the capacitor for the fan motor. You can do that with a multimeter with the capacitor test function or if the capacitor looks swollen then it is probably bad. Also, make sure the fan rotates freely by hand. Let me know if you need more help.
Posted on Jun 08, 2010
  • 3289 Answers
SOURCE: One of our Fedders AEY12F7F
Hi - there is a fuse inside the unit and if replacing it does not solve the problem, it could be a problem with the heating element itself. The heater looks like this:
If this part has failed, you may have trouble locating a replacement - as an online appliance parts store has indicated that the part is no longer available from the manufacturer. You may find the part on another parts supplier's (whether online or at a local store) shelf however. You'll have to do some checking or calling to see if someone has though. Of course, if it is just a bad connection or blown fuse, replacement of this part won't be needed.
A handyman should be able to tackle this - as it is an issue with the electric heater circuit - not a cooling circuit or refrigerant problem. Explain the problem to him and ask if he feels confident troubleshooting this problem for you, first. The heater itself will be located behind the grille and cold refrigerant coil. Tracing the 2 wires back far enough should reveal the fuse location. The fuse may be an in-line type - or one that is mounted to a panel. Either way, your handyman should be able to find it.
Posted on Jan 05, 2011
  • 4736 Answers
SOURCE: Leaking inside. Fedders A3X05F2A-J Unit
Mellisia, the problem very well may be, that the drain pan hole under the unit, on the outside may be clogged. When that happens, water backs up and leaks out the front of the unit.The drain hole should be near one of the corners of the drain pan. And with Fedders, it may be on the edge/lip of the drain pan. The clog, may appear to be part of the drain pan and that's why you haven't noticed it.
Inspect the drain pan closely. If you can't find it. You can create one, by CAREFULLY drilling a hole at one of the corners of the drain pan. It doesn't have to be a large hole 1/8" to 1/4" should do.Be sure the unit is OFF and unplugged from the wall, before attempting this. Also, once the drill bit penetrates the drain pan STOP. You don''t want the drill bit to pierce the coils on the back of the unit.
Hope this helped you. Please let me know. Thanks.
Posted on Jun 20, 2011
I have a fedders window ac unit 110 model A6X06F2A works fine for about 10 mins the the fan stops
i would try to oil bearings on motor. that failing replace run capacitor. motor must be getting hot.
Aug 01, 2015 | Fedders Heating & Cooling
Does Fedders AEY08F2B window air conditioner have an oil port to stop squeaking motor.
Most air conditioner units don't have oil ports on motors any longer.
Sep 13, 2014 | Fedders Heating & Cooling
Fedders frustration
Sorry we can be of no assistance on this problem.
Mar 13, 2017 | Fedders Heating & Cooling
How you tighten fan on motor
Hello, usually there is a set screw or a clamp that hold the fan blade to the motor. If it is a set screw just tighten it up, if it is a clamp it must be slid over the hub.
Feb 15, 2012 | Fedders AEY12F7F Wall/Window Air...
Where are the drain ports on a Fedders A3XO5F2E-A My unit is leaking water on the floor even though it is tilted down. ...
The drain holes are in the back corners of the pan...and they will plug with dirt...to get to them you will need to slide the unit out of the chassis if it is that type or pull the whole unit out so you can take the cover off and open the holes...
Then you will be back in business again..
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 15, 2010 | Fedders AEY12F7F Wall/Window Air...
My fedders a/c will turn on fine but after some minutes the fan will stop but the compresor will still work. i will haveto turn it off and turn it on again after 10 minutes and it will work fine again. but...
You need to replace you fan motor. It is going bad and the amount of amps to keep it going is causing it to over heat. The next time you try it and the motor kicks off see if the motor frame is hot. Be careful I have seen the hot enough to cook eggs. These motors can run between 68 dollars and 160 dollars. The age of the unit and your ability to replace the motor dictates a repair or a replacement. If you ck on the price of the motor and want to do it your self I will be happy to walk you thru it. good luck
Aug 26, 2010 | Fedders A6X05F2D Air Conditioner
Unit is not heating but fuse is good
Heating element inside of unit has overheated and is possibly burnt out. This isn't an easy fix for a novice due to the location of the heating coils located behind the a/c evaporator coil. The coil looks just like the coils in a toaster and can be seen if you pull the unit out of the casing. The part can be purchased at any appliance parts house if you take the model and serial number with you. Good Luck on your repairs
Dave
Oct 13, 2009 | Fedders AEY12F7F Wall/Window Air...
Fedders wall air conditioner
If the compressor only turns on after the units it's shut off then it is a control board problem (stuck relay)
Jun 19, 2009 | Fedders AEY12F7F Wall/Window Air...
Part is no longer available -
Maytag window units are made by Fedders. Try going to the fedders website and get their contact info and call them. They should be able to give you a replacement number or tell you where you can get one. Plus, if you have a company around you that sells hvac motors, like United Refridgeration they may have a motor for your unit. But you have to remove yours and take it to them for a possible match.
Apr 05, 2009 | Maytag M7Y15F2A Air Conditioner
Fedders AEY12F7F Wall/Window Air Conditioner Logo
108 people viewed this question
Top Fedders Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Mike
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
