Question about HTC Touch P3450 Smartphone
My htc elf phone when i tried to upgrade its rom it stopped on boot loader and i need the original rom for it
    President:
  • 1,118 Answers
You can find official resources for your phone here, and lost of useful informations about it here.
Hope you are able to sort your problems out.
Regards, Carlos
Posted on May 29, 2010
HTC Dream "G1", locks on the boot "T-Mobile G1" screen. Will not hard reset or fast boot.
The phone needs to be reprogrammed / reflashed with the original software.
you need to obtain a rom image of the phones program and then place it on a storage card that fits to the phone.
Then you need to start the phone in boot loader mode to flash the program.
you can also try the recovery mode and see if allows you to fix the issue. more information about programming the phone here http://wiki.xda-developers.com/phpwiki213/index.php?pagename=HTC_Dream_overview_and_useful_information
if you require a rom file for the phone you may be able to find one from http://forum.xda-developers.com/wiki/index.php?title=HTC_Dream
if you are unable to get the phone to function contact your dealer or take it to a repairer.
recovery mode Hold Home button and press power button In this mode you can open shell/flash image/perform backup etc. depending on which recovery image you have on the phone. Press CALL+MENU+POWER buttons simultaneously to exit mode.
bootloader mode Hold Camera button and press power button In this mode you can install new system image (DREAIMG.NBH) from SD card by just pressing power button again.
Sep 13, 2010 | HTC G1 Smartphone
Hi, my name is Walter. I have an HTC 7500 not upgrading
You can try with the sd card boot option,More info you can find here
http://www.resco.net/forums/ShowPost.aspx?PostID=2804
and here
http://pdaphonehome.com/forums/xda-mda-sx56-pocket-pc-phone-edition/48619-upgrade-failed-phoen-s-screwed-up.html
i tried it in the past and is working.
Jan 11, 2010 | HTC Advantage X7500 Smartphone
I was flashing a rom into my htc touch and i stopped the proccess when handset went white and now it is stuck on the tri colour boot loader screen and activesync wont recognise it?
It is in bootloader mode and there are 50% chances of it's survival. You can try flashing the phone again (use an original ROM instead of a cooked one, try 3 - 4 different ROMS), in case you are lucky the flashing would complete and your phone shall start again. In case the flashing doesnot complete and you are stuck in Bootloader mode, you will have to get it repaired by Service Center as the chances are that the ROM chip will need to be reinstalled.
Nov 12, 2009 | HTC Touch P3450 Smartphone
I upgraded my htc touch elf 0100 today. but after upgrade it does it start then show "smart mobility " logo then switch off. I used onyx_5.5 for upgrade. I am in really trouble PLZ help me..........
1.have you gone through the instructions from ROM cookers. 2. put the mob on recharge and try to restart. 3. have u done a hard reset after rom update 4. try xda forum
Nov 03, 2009 | HTC Touch P3450 Smartphone
HTC Touch was stucked up after an error while upgrading to WM 6.1
i think u have tried to upgrade thru custom rom bcoz this pda came with WM 6 only so u tried to upgrade to 6.1 thru custom rom procedure and it seems like something went wrong and u get a boot loader screen tri color with code written SPL 1.XXX on it dont worry i can help u in this go step by step as soon as ur problem is resolved leave other step
first try this
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if ur pda boot normally after reset procedure it will take some time to boot dont panic if it is ok then good luck
if it doesnt help then try this
download Hard SPL 3.1 from here
http://forum.xda-developers.com/showthread.php?t=445666
install it as described in the instructions inside the zip file
and then Rom Lite version for ELF from here
http://forum.xda-developers.com/showthread.php?t=451100
first install hard spl 3.1 as directed on ur pda and then update to custom rom from the the file downloaded
pls rate me FIXYA if it helps
Mar 14, 2009 | HTC Touch P3450 Smartphone
Stuck on windows boot up screen
Regarding with your HTC Viva / Elf
Try hard reset with phone in "OFF" state following this instructions if it will do;
1. Press and hold the TALK and END buttons, and at the same time, use the stylus to press the RESET button under the battery cover at the top
of the device.
2. Release the stylus, but continue pressing the TALK and END buttons until you see this message on the screen:
Warning! Your device will be set back to factory default settings. Please ensure any additional installed programs and/or user data have
been backed up before a hard reset is performed.
3. Release the TALK and END buttons, and then press ENTER on your device.
Mar 03, 2009 | HTC Touch P3450 Smartphone
Upgrading from wm 6 to wm 6.1
there is no official rom available for upgrade u have to switch to un official one's at xda developers but it involves risk
Jan 31, 2009 | HTC Touch P3450 Smartphone
HTC Touch Elf CD ROM
my device p3450 is stock in boot loader and i tried many rom even profissional one is not help which is \r\nDID-ELF010050_CID-DOPOD001_ROM-2.20.721.2B
which my device have same info of cid and device number
but untel now my device is stock in boot loader that when i try to to update its stop in 3% and it reboot and agine in boot loader stock whith no ruu in top right display but only usb in below disply left and number of old and new rom
Oct 04, 2008 | HTC Touch P3450 Smartphone
HTC TOUCH IN BOOT LOADER
Either search for it online or try Needrom.com (you must register to download any stock ROM, etc: search is free)
Oct 08, 2017 | HTC Touch P3450 Smartphone
Upgrade Problem
i am unble to install dictionary in htc 3400.
Feb 23, 2008 | HTC Touch P3450 Smartphone
HTC Touch P3450 Smartphone Logo
147 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
