Question about Iomega ZIP 250 External ZIP Drive
I have a Zip 250 disk that will not read. When I insert the disk in the external disk drive, it will spin and stop a few times and that's it. When I try to access the disk/drive letter via "My Computer", it just tell me to "Please insert a disk in the disk drive." The zip drive itself is ok because I am able to read/write to other disks.
  • 4,924 Answers
If the disk is unreadable this means that the format or the files extensions on it are not readable in the operation system you use..either are damaged or the disk itself is damaged or it wasn't finalized like it should ...If other disks inserted run ok than the disk it is damaged and it is nothing wrong with the drive itself..When it says to insert a disk this means that it is not seeing the disk at all and it sounds like a drive problem ..but if other disks are ok ..than it is just a damaged disk or in a format unreadable ..beware if it a cd unit ..will not read dvd-es..or if it a dvd kind will not read large dvd-es (dual layer) or blue-ray disks..
Posted on May 29, 2010
  • 2 more comments
  • tmd820 May 29, 2010
    Is there any way to repair it so I can access the files? I have some family photos on there that are pretty valuable.
  • Catalin Turcu
    Catalin Turcu May 29, 2010
    probably it is beyond recover from heat exposure or something ..anyway I will try to link to a recovery program just to give it a try ..maybe there is something readable on it ..
    try this one ..it is free and it supposed to recover files from disks..
    http://www.kvipu.com/CDCheck/download.ph...
    just install it and choose check or recover ..if you choose recover also choose a folder for to put the files in..
  • tmd820 May 30, 2010
    No luck. But thanks for your help.
  • Catalin Turcu
    Catalin Turcu May 30, 2010
    Im sorry to hear that ..the disk is too damaged to work than ..it is either a temperature or a mechanical damage and it can not be restored until is read ina a device ..If they are important enough for you ..you may try a professional recovery ..they may have ways to do it iven on this kinda disks...probably another kinda optical reading and if we are talking about pictures..those are the easiest to retrieve from a damaged hard disk too .so I guess from a disk like this also ...Give it a try ..I can do no further ..and I kinda expected tis ..cause your disk is not read at all...thast why it says to insert a disk in the drive ...You can try it in another less sensitive drive ..and see maybe you will find one to read it ..
I own a 250 meg. parallel port external Zip drive. This drive could once be used on DOS-based computers with software called GUEST.EXE and some drivers, with GUEST selecting the correct driver and...
Recomendation: Replace for a external hard drive, The Zip drive is outdate. With theExternal HDD you gona have more space than a Zip drive, really much more.
Dec 13, 2010 | Iomega ZIP 250 External ZIP Drive
Error message - computer cannot read - options: initialize/ignore/eject
The fact that this happened while using Time Machine is almost assuredly nothing but coincidence. You have significant file system damage, to the point that Disk Utility can't fix it. I'd recommend that you purchase and run DiskWarrior on the drive. DiskWarrior is an industrial-strength filesystem repair program that will fix things that Disk Utility cannot.
http://alsoft.com
Jan 20, 2010 | Iomega ZIP 250 External ZIP Drive
I had a computer with a slot for reading iomega ZIP 100 disc. My new computer does not have this. Is there a device to read my zip dizc and send the contents to a USB port?
IOMEGA make a USB ZIP drive that reads and writes 100 and 250 Mb disks. Don't know if this is available any more, you might be able to pick one up 2nd hand.
If you still have your old computer, try networking your old and new computer together so you can transfer data from the ZIP drive on your old computer to your new one.
Mar 21, 2009 | Iomega Zip 100MB (31714) External ZIP...
Can't read specific Zip 100MB Diskette
Its probably a bad disk. The only way I have been able to fix these is to First launch disk utility THEN put the disk in. THEN run the utility. You have to do it in this order. The key thing here is utility has to be running first and then insert the disk "HOT"
Hope this helps!
Jan 22, 2009 | Iomega Zip 100MB (31714) External ZIP...
100mb zip disk not reading
These are pre-formatted and servoed at the factory.
Awhile back I was researching the 'Click of death" fault and found a guy in Belgium or Germany that coded a repair program for bad disks. Googlee for it
sometimes when it formats, it hoses the servo information (which the drive uses to keep track of things) and the disk becomes useless. This is why I stopped using ZIP disks and won't even buy a drive when I see them for 9.99 ;-)
Jan 16, 2009 | Iomega Zip 100MB (31714) External ZIP...
Can not eject zip disk
I have the imoga 100 external zip drive and there's a pin hole on the front panel. that if you straighten a paper clip and stick in the whole, it should manually eject the disk.
Jul 12, 2008 | Iomega (32453) External ZIP Drive
Cant figure out how to use zip drive when i have added a pass to my zip dr 250
1. Insert a blank disk into the zip drive
2. Give this disk a password (it can be any password, as long as you
remember it)
3. Using the Ioega toolset, set the zip drive's sleep time to a large
value (such as 1 minute)
4. Wait a while until the drive "spins down". You will hear the drive
stop spinning.
5. Take a pin or a straighten paper clip and stick it into a hole in
the back of the Zip drive. This will manually eject the blank disk.
6. Insert the disk you want to access (the one you don't know the
password to)
7. now use the IoMega toolset to remove the password. When prompted
for the password use the password from step (2).
This is just a word of warning in case you store any important information like I used to on zip disks. Perhaps move to a more secure medium.
May 09, 2008 | Iomega Zip 100MB (31714) External ZIP...
250 zip drive
Throw it away. It is rubbish.
Apr 24, 2007 | Iomega ZIP 250 External ZIP Drive
Iomega ZIP 250 External ZIP Drive Logo
407 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
