Question about Jandy Lite2 LG400 Ceramic Compact Heater
Pool heater recommendation
I just purchased an intex easy set 16ft x 42" above ground pool (~ 15000 litres) and am looking for heater. Ideally, it needs to be:
compact (I have a shed roof but it's only 10ft wide)
either solar or electric (but only have a standard 120v outlet and don't want gas or propane)
Thanks
Orlando
  • 146 Answers
They make heat pump pool heaters. it works like an a/c but it heats. only uses electric. http://www.solardirect.com/pool_heaters/heat_pump_pool_heater/hpph.htm
also they have solar panels for pools. another good thing for a pool is a solar cover you just cover it when you are not using your pool.
Posted on May 29, 2010
Do I have to drain my pool to patch it?
use the pool pump to drain may need long hose to your drain for the water. (back of house if closer)
May 28, 2016 | Intex Ultra Frame Round Above Ground Pool...
. I am setting up my new intex pool and it is
Is the ground the pool is sitting on, level? If not, move the pool or use sand to create a level base for the pool.
May 01, 2011 | Intex 15' X 42" Easy Set Pool Complete...
I have an above ground intex vinyl pool, does this need to be emptied and removed in the winter?
Where you live and the severity of your winter would dictate the answer here and you have said nothing regarding this. Please contact a pool service company in youre area and ask for their recommendations.
Sep 02, 2010 | Intex Easy Set Pool 15x36
What chlorine should i use for my pool?
You should use granulated CL in this pool. Maintain CL at 5 ppm - check daily.
Jul 20, 2010 | Intex 15' X 42" Easy Set Pool Complete...
How deep can we dig for oval deep-end pool
This blog has information about sinking an above ground pool. It is normally recommended that you do not sink the pool entirely into the ground becuase of pressure concerns and the risk of collapse. Generally, you leave 1-3 feet of the pool above the ground and install a deck or similar feature to make the pool appear to be in the ground. The type of pool liner that you have (expandable) is best for this practice, but it can be done with overlap or regular beaded liners also.
http://backyardcity.wordpress.com/2009/06/02/the-above-ground-pool-goes-underground/
May 08, 2010 | Intex 18 ft x 48" Easy Set Inflatable...
I have a intex above ground pool 18 x 42 and I need a manual to help me with the filter how do I put it on
go to intex.com
they have a few pdf files and also videos showing how to do it.
Although these are the salt water system it is still the same set up and procedure. Just pretend it is your pump when reading or watching the video
Jul 14, 2009 | Intex Easy Set Pool 15x36
I have a intex pool
go to intex.com and watch the video
Jul 12, 2009 | Intex 15' X 42" Easy Set Pool Complete...
I bought an Intex 15' x 42" above ground pool at a garage sale. No instruction or DVD were included. How is the skimmer set up?
Plug the inlet & suction openings with provided plugs
Hook up the hoses.
Release vent screw from the top of the filter housing.
Remove hose plugs.
Start pump
when water comes out filter housing vent - close it.
check for proper flow.
Thanks for using FixYa - a good rating is appreciated for answering your FREE question.
Jul 08, 2009 | Intex 15' X 42" Easy Set Pool Complete...
Lopsided 18x4 intex round easy set pool
I started out with easy set pools a few years ago and finally gave up and went to their steel supported ones.
I have put up over 20 above ground Intex pools and have learned a few things in the process:
A: The larger the pool with the air ring at the top the more difficult it is to fill to its maximum potential.
B: Eventually the pool is going to collapse with people in it, especially if someone leans over the edge with their arms on it which is a perfectly natural thing to do.
C: It is virtually impossible to get an area beneath the pool level without scraping the ground and measuring it with, in your case, at least a 16' long 2"x4" on its edge with a level on it.
D: Trying to build up the ground on one side with sand will eventually result in collapse of the pool.
E: There is a type of stiff styrofoam ring that you can buy in sections to go around the bottom of the pools, but that will also result in collapse unless it is used for what it was developed, and that is a rigid wall pool.
F: Out of the three types of pools that Intex sell, the easy up with the air ring (the worst), the steel supported all the way around (next worse). and the rigid side, only the rigid side is forgiving to a tiny degree where unlevel ground is concerned.
For your size of pool everything must be exact and completely level or at one point it will collapse. There is little more discouraging than seeing all those gallons of water run out onto the grass. Once the water goes over the edge, no amount of people can prevent the collapse.
Finally I have learned that, with above ground pools, you get exactly what you pay for. My 5th above ground Intex pool was the best, but even with the ring around the edge at the bottom and the rigid side, I was still wasting my money unless the ground was aboslutely level. You just have to cut away the dirt until the level shows no angle.
I wish you all the luck. If you feel a desire, I have 5 Intex pools in my barn I will give to you if you pay the freight. Each was a dissapointment and a waste of time, energy, and above all, money.
I finally spent about $750 on one, had a professional crew level the ground, and it stays up through the winters even.
May 25, 2009 | Intex 15' X 42" Easy Set Pool Complete...
Jandy Lite2 LG400 Ceramic Compact Heater Logo
184 people viewed this question
Top Jandy Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Jandy Heating and Cooling Expert? Answer questions, earn points and help others
