Question about Car Audio & Video
I am having trouble getting video and music to play from my ipod to my kenwood ddx7017 i connected the three rca wires red,white,and yellow to av in and the red wire to a power wire and a black wire to another black wire how can i get this to work so i can hear music from my stereo
  • jaime_munozj May 29, 2010
    the kenwood stereo i have does not have an aux port in the face of the stereo i have to connect rca wires to the back of the stereo it is a kenwood ddx7017 touch screen
  • 4,924 Answers
Im not sure I understand what you have done ...all you have to do is connect the ipod to the input signal of the kenwood..and stream it ..just use the usb cable ..and connect it like you should connect a usb stick ...after that you should be able to browse the files from the Ipod..
If it makes troubles just let the ipod to work in its own player ..and from the headphones out ..get a line to the audio in at the kenwood..so to be able to amplify the signal..this should work too ..if it has a audio in stereo line ..
Posted on May 29, 2010
    my stereo does not have a usb connection so i have a convertor that has three rca jacks red,white and yellow and the back of my stereo has three female ends that say av in and two that say av out I also have 2 wires that is red and black so i can get power to the ipod i have an older model kenwood touchscreen so it doesnt have all the usb stuff on it
  • Catalin Turcu
    Catalin Turcu May 29, 2010
    Ok ..in this case for audio ..(audio will be the only thing you can plug .cause the ipod do not have a video out) you have to get after case..either a 3.5jack ...to 2 ends rca cable ..stereo for left and right ..left (white) right (red) and ..use the jack cable to get signal out from the ipod..and the 2 white and red inserted into the audio in ..of the kenwood..
    The yellow one is for video signal....
    and after that it will work ..just set it like it had a dvd inserted,,but without the image ..you will only get the audio signal to be amplified ..the actual playback will be made in the ipod....this is the only way if it do not has a usb connection to use the data cable ..
    Brigadier General:
  • 3,917 Answers
Thanks for contacting Fixya.com
Turn on your vehicle and press the "On" switch for the car's DVD system. Wait for the main screen of the DVD system to appear.
Connect one end of the auxiliary wire to the headphones jack on the iPod, and connect the other end to the auxiliary port on the face of the DVD player. The auxiliary port will resemble the headphone jack found on the iPod itself.
Turn on the iPod and allow the main screen to fully load. Scroll through the device to find a song, and test to see if the audio will play through the system. If audio comes in through the car's speakers, the process is complete.
Let us know if you have some thing more to know else accept the suggestion.
Thank You
I accidently put the rca wires in the wrong audio input/output on my craig cd graphics karaoke player.Could this be why i have no sound?
The RCA outs are designed to send a signal to an external amplifier. That amplifier, in turn, sends the music signal to speakers.
The RCA inputs are designed to take audio signals from another device (like an ipod, CD Player, or computer) and play it through the Craig System speakers. If you sing into the microphone, the vocals will be mixed with the incoming music. However, in these cases, there won't be lyrics on the screen. If you play a karaoke DVD in a DVD player, connect the red, white and yellow RCA cables from the DVD out to the Craig Inputs, the lyrics should appear on the Craig screen while the music plays.
If you mistakenly plug RCA cables into the Craig Inputs and plug the other end into an amplifier's inputs, neither will produce any sound.
Using RCA outs is only necessary if you want to have louder music than the on-board Craig speakers can handle. Of course, you can run the yellow video cable to a TV RCA input to get a bigger lyrics window and the RED and White RCA to the TV RCA Red and White inputs to hear the music through the TV's speakers.
Aug 30, 2014 | Audio Players & Recorders
Tip
Connecting up your "Whatever" to your TV/HDTV
Connecting this up will be easy. What you do is get a yourself a set of the right, for your setup, cables. That uses EITHER one of the formats, of these described, below. You will need, either, a THREE way Cable, or three separate " Coaxial Cored" Cables with RCA PLUGS on them. Colored Yellow, (Video) Red, & White. (Audio) AV. OR If you have SCART Connection Sockets, it's a big Black Socket at rear of unit(s), you get a SCART Cable.& It's all inside. Now some units, use a standard called Component Video, that uses, a Green, Red, & Blue Plugs. Also we have with the "Component Video" it is marked "Y" "Pb" & "Pr" these simply go color to color at BOTH ends, this is where the Red, Green, & Blues, colored Ends, of the Wires, goes, remembering that this is ALL only Video. With this method, you still must use the AV, red & White, Audio, Inputs to get the "Sound" into the unit, with the Component setup, you will also ,need, Two more Cables, for the AV Audio. these are, Red & White.(So with Component Video there are 5 Cables/Plugs in all). In any event ALL Cables go Color to Color, at each end, plugging into the corresponding Colored RCA Jacks, on either machine, or VCR or TV. Now if you have SCART, then it simply plugs in only one way. It is that simple. So connect up with the leads your set uses, and select the correct "Input" from TV/Remote, it is NOT on a "Channel" it will be on AV, AUX, and Press "Play" on VCR/DVD whatever.... should be all go.
on Feb 10, 2010 | Televison & Video
How to connect vcr to a sanyo dp26649 flat screen tv
Hello.
Get an RCA cord. The RCA cord has three wires. The wires are yellow, white and red.
The yellow cord is responsible for display, while the red and white is responsible for sound.
Look at the back of the TV, connect the yellow to "video in", then the white and red to 'audio in'.
Connect the other end to 'video out' and 'audio out' respectively at the back of your VCR.
Now, press source/AV on the TV and there should be a display of the VCR on your TV.
Now you are through.
Yours sincerely.
Elect_Comp.
May 16, 2011 | Sanyo DP26649 26 in. TV
How do i wire red white and yellow rca to an xbox 1 av plug. my av plug has blaack white orange and green wires
In the old school standard AV: Red and White are usually audio channels (Red:Right - White:Left), Yellow is video.
Orange can be coax audio, (both L&R channels in one cable). Before digital (optical) came out, some receivers actually had a coax (orange) jack in the back. Radio Shack sells a splitter if necessary.
In higher resolution systems video is separated into three colored cables: RGB or Red, Green, Blue
called 'component' video. The green cable carries Yellow, the blue cable carries (PB) Blue and the red cable carries Red (PR). And with today's tech, the component signal is carried YCBCR as (digital video.) cf. http://en.wikipedia.org/wiki/YPbPr
Component 'wire colors' are there just to remind us. If your TV has "Component" input. Try green to green, white to yellow and black to red. Orange to audio (splitting L&R if necessary)..
Also, here is a PS3 link that might help: http://www.ps3hax.net/showthread.php?t=9238
Good luck !
Apr 23, 2011 | Video Game Consoles & Games
Can you hook up ipod touch to a HD TV or media player
Yes. What you need is an adapter from apple, depending on the type of input your HDTV has. If you need composite, generally denoted by a single yellow RCA video connector and two (Red and White) RCA audio connectors, you need this cable: http://goo.gl/OlSDa Please note that Composite is not an HD signal. Although iPods are not able to output a true HD signal, over component (see below), they will output a slightly higher signal. If you require a Composite connection, denoted by three RCA video connectors (Red, Green and Blue, labeled Pr, Y, and Pb, respectively) plus two (Red and White) RCA audio connectors, then you need this cable: http://goo.gl/yk8Zt Also note that video out on iPods is only supported for certain video formats/video playing apps. Before buying a cable, you should most certainly research whether the videos/apps you are playing/using support video out.
Dec 31, 2010 | Apple iPod touch
I have an older Kenwood Home Theater system (approx. 2000-2001). I am tryuingto connect it to my new large screen TV (Samsung). Since the theater system does not have an HDMI connection port, how do I...
Use the red and white looking audio outs on your TV next to your yellow video out they are together (RED, WHITE, YELLOW). These are known as RCA jacks. Find a RCA wire and connect it to the AUX input of your receiver and the output of your TV. Turn your receiver to AUX mode and it should work.
Dec 02, 2010 | Kenwood Audio Players & Recorders
CANNOT SUCCESSFULLY HOOKUP A DVD/VHS TO MY VIZIO MODEL NOS. DVD-v2000 25W
I was the person chatting with you earlier on, before the chat was disconnected. My system went off and I'm sorry about that.
I'm responding here in order to make sure your problem is solved.
LAST QUESTION THIS IS A DVD/VHS DUAL UNIT AND IS CON NECTED WITH THE wHIT rED AND YELLOW TO FROM THE COMPONENT AREA TO THE BACK OF THE TV
You can do the connection by using two different methods: (a.) you can use the component method or (b.) you can use the AV method.
Using the Component method: The component is a combination of red, green and blue wire connection which brings video or display.This three must be connected for you to have a display of your unit on your TV.
Connect the Red, Blue and Green wires respectively to their appropriate places on the TV, then the other part on your DVD/VCR. Note that this connection will only bring a display and no audio. You will have to connect the red and white wire from audio out of the DVD to audio in on the TV.
Once you have successfully done the connection, put on the DVD/VCR and your TV, then press "source" on your TV remote and select component 1 or 2 for you to get a display.
B. Using the AV connection: The Av connection is using the RCA wires which is yellow white and red, just as we discussed while chatting. Connect the Yellow, white and red wires, from the TV to the DVD/VCR, the select AV on the TV remote.
Unlike the Component which its video connection is red, green and blue for display, the AV is only Yellow for display. I hope you under stand this.
Please try to follow my explanations and let me know, if you don't understand and I will explain further.
It was nice chatting with you.
Take care.
May 02, 2010 | Televison & Video
How do I hook up my dish network and a wii console at the same time if I don't have the tv/ant cable I just have the red, yellow, and white cables?
Yellow is Video, Red & White are Audio, these wire color to color from unit to TV. Use these for the Wii, and the Dish, output will wire the same, if that is the ONLY way to output the signal... You can get "Splitter" boxes that allow a two to one, switchable input. Usually though, it's out with one, in with the other. most modern TV's have multiple ways of getting video into the set. Do you have any "other" Video/Audio inputs? Like, SVHS, Composite, Component? If so then you use one each and choose of the menu on the TV. Connecting this up will be easy. What you do is get a yourself a set of the right, for your setup, cables. That uses EITHER one of the formats, of these described, below. You will need, either, a THREE way Cable, or three separate " Coaxial Cored" Cables with RCA PLUGS on them. ColoredYellow, (Video) Red, & White. (Audio) AV. OR If you have SCARTConnection Sockets, it's a big Black Socket at rear of unit(s), you get aSCART Cable.& It's all inside. Now some units, use a standard calledComponent Video, that uses, a Green, Red, & Blue Plugs. Now, with the Component setup, you will also ,need, Two more Cables, for the AV Audio. these are, Red & White.(So with Component Video there are 5 Cables/Plugs in all). In any event ALL Cables go Color to Color, at each end, plugging into the corresponding Colored RCA Jacks, on either machine, or VCR or TV. Now if you have SCART, then it simply plugs in only one way. It is that simple. So connect up with the leads your set uses, and select the correct "Input" from TV/Remote, it is NOT on a "Channel" it will be on AV, AUX, and Press "Play" on VCR/DVD whatever.... should be all go.
Mar 03, 2010 | Televison & Video
How to connect Apple iPOD to Sony Bravia LCD
http://www.applesource.com.au/ipod/soa/Play-back-iPod-videos-on-your-TV/0,2000070791,339287576,00.htm
Connect your iPod to your TV with a DIY cable
The iPod A/V Cable is stylish and handy, but you may feel it's not worth the money; the Belkin cable gives you twice the value per foot but costs the same overall. For a less expensive alternative, find a standard A/V cable with three RCA plugs at one end (coded red, white, and yellow) and a 1/8-inch A/V plug with three bands at the other end.
To set up your iPod for playback, plug the 1/8-inch connector into your iPod's headphone port, and then plug the yellow, white, and red RCA connectors into the RCA jacks on your TV in this non-color-coded way:
Jan 19, 2009 | Durabrand DU1301 TV
Ipod vido out
Using the iPod AV Cable
Step 11Use the Apple iPod AV cable. This plugs into the RCA ports on your TV or VCR. This is by far the easiest method. Step 22Connect the AV cable into your iPod. Plug the small end into the iPod where the earbuds would go. Step 33Connect the red RCA plug. This goes into the right audio input of the television or VCR. The colors should match. Step 44Connect the white RCA plug. This plugs into the left audio input of your TV. Connect the yellow RCA plug. This goes into the video input of your TV. Step 55Begin playing a video on the iPod.
May 27, 2008 | Apple iPod MA446LL/A MP3 Player
Car Audio & Video Logo
27 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
