Question about FrancisFrancis! X5 Espresso Machine
Blowing the fuse
When I switched on my coffee machine, it blew the fuse in my kitchen. I replaced the fuse and the on / off switch on the back did not work, but could use the on off switch on the plug socket to switch the machine on and off.
I have now replaced the fuse again and it has blown.
I just had this happen to me too... any ideas?
Posted on Sep 22, 2010
Windshield wiper fuse keeps blowing
Since you Disconnect the motor also renewed the switch and is still blowing the fuse ,it is obvious that you have either broken wire between the switch and the motor. Try to test the failure by means of a tester circuit. Good Luck.
Aug 21, 2012 | 2003 Mitsubishi Diamante
The machine has just stopped working, none of the buttons work. Tried switching on and off ....help please
sound like you blew a fuse. There is a little fuse box next to the on/off switch. You can buy new fuses at espressozone.com. Hope that helps!
Jun 26, 2011 | Lavazza Espresso Point Capsule Machine
My machine won't do anything when it's turned on. It blows the fuse in the kitchen every time. I looked in the back and nothing appears to be grossly burnt or destroyed. Any suggestions? I'm a mess without...
It is possible that the boiler over heated and blew the element, disconnect one of the legs and turn machine on, if it trips breaker, then replace element.
Sep 08, 2010 | Saeco Classico Espresso Machine
Hotpoint Dishwasher BF1620 blew the main fuse circuit in fuse box during mid cycle wash? Re-set main power fuse circuit but now as soon as Dishwasher switched on immediately blows main kitchen power fuse...
This is happening because you have a very bad fault, a Phase to Earth short, problem. Leave machine UNPLUGGED, Breaker/Fuses OUT. do NOT use it, nor Touch it, It is possible to get severe electric shock. PLEASE get a registered serviceman to inspect this unit.
Feb 07, 2010 | Hotpoint 23 in. BFI62 Built-in Dishwasher
How do you open up this machine? I need to get in and do a simple repair--replacing the steam wand. Unfortunately it's so recessed into the case you sommehow have to get the outer shell off to...
The top comes off...you have take the clock out, undo a nut behind it and then you can pry the top off carefully. There are several metal pegs that engage holding clips that you are undoing by prying.
Jan 30, 2010 | FrancisFrancis! X5 Espresso Machine
Wont switch on
I would open it up (unplugged) and use a meter to find the problem. maybe the thermal fuse blew and can be replaced.
if that is the problem verify that the thermal switch is not stuck closed(on)
Jan 24, 2010 | Braun Tassimo Espresso Machine/Coffee...
Maytag washer blows 1.5A fuse in back of the top compartment where the dial etc is
There is a micro switch next to the fuse. It is shorted out. Replace the micro switch and solve your problem.
May 20, 2009 | Maytag SAV571EEWW Washer
Fuse blew on my Maytag washing machine. 1 amp only and others blow. Time to buy new or service?
yes.you can buy the switch assembly unit. it gets short and the fuse blows out.
May 04, 2009 | Washing Machines
Fuse blowing on model #lat8440oaa w
a short in a wire somewhere grounding causing fuse to blow
Feb 26, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Gaggia blew a fuse
ensure that you have replaced w the same rating of fuse, amp and voltage
also check for a possible broken part or wiring problem that could cause a short circuit
cheers
Sep 15, 2008 | Gaggia Baby Espresso Machine
FrancisFrancis! X5 Espresso Machine Logo
170 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
Joe Lalumia aka...
Joe Lalumia aka...
billconfused
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
