Question about Remington Electric Chain Saw
WHAT TYPE OF OIL SHOULD BE USED FOR REMINGTON 3.0 HP ELECTRIC CHAIN SAW?
    Brigadier General:
  • 4,088 Answers
Just buy regular chain/bar oil at home centers, hardware stores, or saw dealers.
Posted on May 30, 2010
What kind of oil or oil mixture do I need to use my Remington 2.0 HP 14" Electric Chain Saw?
Hi brown9148..
The only oil you need for your electric chain saw is "Bar and Chain" oil...specially formulated oil sold at Loews,HomeDepot,Ace Hardware, Auto parts stores,etc...
You use this oil to lubricate the chain and bar of your chainsaw when you are using it.
It will go into the oil tank and auto feed to the chain and bar...but keep a check on the oil level to make sure it is being used.
Refill tank when needed.
Please take time to rate me
Sep 24, 2011 | Remington Electric Chain Saw
What kind of oil does a Remington 3.25 (Peak hp) 16"/40, 6 cm Electric chain saw take
You need to use bar & chain oil. It's thicker and stickier that regular oil so it will stay on the bar and chain and not run out of the saw when you are done using it.
Jan 21, 2011 | Remington 16" Electric Chain Saw Assembled...
What type of oil does remington 3.5 electric saw use
Use regular chain/bar oil available from home centers, hardware stores, and saw dealers. Hope this helps!
May 30, 2010 | Remington 16" Electric Chain Saw
3.0 Peak HP 16'/41 cm remington
You might actually have the chain too tight. With the saw off you should be able to lift the chain until the gear tooth (tooth on inside of chain) almost lifts out of the chain bar.
I've never used an electric chain saw but if it has a chain oiler you should also check your chain oiler to make sure you're getting enough oil on the chain, if you run the saw with the chain aim at a clean surface you should see oil on the surface almost immediately.
May 26, 2010 | Remington Electric Chain Saw
Remington electric Pole Chain saw - what type of oil do I use?
SAE 30 motor oil if the temperature is between 30 & 75°F.
-Colder use SAE 10 oil.
-Warmer use SAE 40 oil.
take a look on amazon: Amazon com SAE 30 motor oil
Apr 24, 2010 | Remington Electric Pole Saw
What type of oil do I use in my remington 16 inch 3.5 hp electric chainsaw?
You need “Bar and Chain Oil”, available at hardware stores and home centers. It is SAE 30 with additives to make it adhere to your bar and chain.
An excerpt from a Remington manual follows (edited).
FILLING OIL TANK
1. Remove oil cap.
2. Fill oil tank with SAE 30 motor oil if the temperature is between 30 & 75°F.
• Colder use SAE 10 oil.
• Warmer use SAE 40 oil.
3. Replace oil cap at once. Tighten oil cap firmly for a good seal. This will avoid oil seepage from tank.
4. Wipe off excess oil.
• It is normal for oil to seep when saw is not in use.
• Empty oil tank after each use to prevent seepage.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank you for using FixYa.
Apr 11, 2010 | Remington 16" Electric Chain Saw
What type of oil is used in the remington 16" chain saw?
From page 9 of a M12510US (bar oil is SAE 30 with additives to help it adhere to the bar and chain):
FILLING OIL TANK
1. Remove oil cap.
2. Fill oil tank with SAE #30 motor oil. Note: For temperatures below 30°F, use SAE #10 oil. For temperatures above 75°F, use SAE #40 oil. 3. Replace oil cap at once. Tighten oil cap firmly for good seal. This will avoid oil seepage from tank.
Note: It is normal for oil to seep when saw is not in use. Empty oil tank after each use to prevent seepage.
This is one of the most complete "Owners Manuals" Remington offers. If not your saw you can find your manual here:
Remington.com
http://www.desaparts.com/index.htm
  • Type "YourModelNo" into the "Model #:" window, then click search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Breakdown" link.
HTH Lou
Jan 23, 2010 | Remington 16" Electric Chain Saw
What type of oil is used in electric chiansaw
The oil to use for the chain is called BAR OIL and if there is anything that might be universal, it is BAR OIL. You can use BAR OIL on electric and non electric saws alike. Self sharpening and non-self shaprening chains. Any manufacturer. It is BAR OIL.
Do not use any other kind of oil in your saw. BAR OIL is particularly sticky and hangs on to the chain even while cutting the wood at high speed.
Thank you for posting your question at FixYa.com
Please remember to vote
a
Nov 11, 2009 | Remington 16" Electric Chain Saw
Oil
While Bar Chain oil will probably work, the owners manual (sitting in front of me) on page 9 says to "use SAE #30 motor oil". This is the owners manual for Models: M12510US, M15012US, M15014US, M15014AS, M30016US, M30016AS, M30016AW, M35016UW, M35016AW. Remington Electric Chain Saw
May 25, 2009 | Remington Electric Chain Saw
What type of oil do I use for a Remington Electric Pole Saw?
Mar 13, 2009 | Remington 16" Electric Chain Saw
Remington Electric Chain Saw  Logo
448 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
