Question about Diamond Audio CM310D4 Car Subwoofer
Where the screw holes are at there is a little
Where the screw holes are at, there is a little rip.
    Scholar:
  • 84 Answers
A small tear in the rubber surround will effect a little bit of the reproduction of sound. It's an air leak and will not harm the sub but it will make a small bit of noise. Use epoxy or a clear caulking and seal it up unless you want to replace it.
Posted on May 31, 2010
Whirlpool front load dryer - gives little holes in the tee shirts and other clothing's. Sometimes it feels like its burnt and sometimes its just holes and ripped
Check for sharp edges and pinch points on the ribs in the drum that tumble the clothes. I had my drum replaced under warranty.
Dec 14, 2016 | Whirlpool Washing Machines
How to turn off isuzu t belt light 4jg2 engine
Someone posted this response on a prior post with the same question.
The reset is done by taking the clocks out of the dashboard. On the back there is a small silver screw, towards the middle. About 1cm away from that screw is a hole which has a silver contact going round it. Remove the screw from the hole it is in at the moment and screw it into the other hole. That switches the light off, you leave it there then until you need to change the timing belt again, thus moving the screw back over to the original hole. Hope this helps you out.!
Aug 28, 2016 | Isuzu Cars & Trucks
How do i put a screw back into a wallowed out hole
Use a larger self-tapping screw. Drill out the hole the screw goes thru the same diameter as the larger screw.
Jun 02, 2015 | Ovens
Washer ripping clothes
Check the drum baffles (the paddles inside the tub) to see if one is loose and also check the front tub seal for any tears.
Nov 05, 2012 | Washing Machines
The input hole where i plug in my bass ripped off. is there any way to reattach it?
When I have repaired damaged cabinets, larger "fender washers" of modest thickness usually work the easiest, and look the best.
Otherwise 2 chunks of clad board that span the hole on either side of the panel to make a sandwich and drilled to accomodate the jack will work if the old panel is thin enough. If not, one chunk can be used and then that patch of a single clad board gets attached to the panel with screws..
Jan 29, 2012 | Behringer BX108 Thunderbird Retro Bass...
Well. I bought a new dash kit for it so I can put an after market radio in there but I don't know how to remove the stock radio. I don't want to jus t rip it off. There are these little holes but I don't...
What kind of car do you have? There is a specialized tool that you can get from the car manufacturer's dealership that will let you remove the factory deck. It's hard to do it without that since the factory deck has clips at the back of it that are "extroverted", meaning to be able to remove the deck whatever tool you use slides down the holes then spreads open and around the clips and when you pull it brings them together to unhook them from the deck "frame".
Aug 18, 2010 | Car Audio & Video
One of the 3 wings fell off inside dryer drum.
unplug the dryer,open the door,remove the two phillips screws that hold the door on,the screws are in the middle of the hidges,look at the other side and remove the two screws that are there,pull off the front panel grabbing it at the top where the top screws were and pull forward the bottom of panel is on clips,just slide the panel up off the clips,now spin the drum until the baffle that you need to repair is in the lower right hand corner and you can get to it there.if the holes are to big for the screws add a washer to stop the screws from falling through the holes,sometimes the screws get ripped through the holes making the holes to big for the screw heads and a washer needs to be added,let me know how you make out
May 01, 2010 | Maytag Neptune MDG5500AW Gas Dryer
I have a little rip on the subs ring
The little rip on the foam surround can be repaired easily with some pure silcone from a harware store. Make sure it's pure silicone, because the silicone mixtures may deteriorate the foam prematurely. Also, all you're really doing is plugging the hole that the rip makes so that air doesn't leak out and further damage the surround and also affect your sub's performance. You'll need to apply a thin to moderate coat of silicone to the rip, and make sure that some gets into the rip. Do NOT use globs or big lumps. You should apply some silicone to your finger, and carefully apply it to the area. Try not to get too much on the inside/backside of the rip. If you'd rather just get a replacement sub, you should be able to find the raw driver on eBay or at a local MTX dealer.
May 18, 2009 | MTX RT12X2-200 Car Speaker
Pls tell me how to open monitor for repair
Protocol Internet Caf'e
AL SALAMAH ST. JEDDAH
I also opened the cover of monitor but its really hard because the two clips hold it tight from the top of monitor. First I open the 2 screws at the back. Then you have to hold the cover very strong and its strongly to left and right like you are ripping it till and the cover gets free from the clips at left and right parts.Than when you look at the top of monitor, you will see little holes at the left and right sides of monitor. you will have to free them with a screwdriver. ( its mostly possible that there will remains some track:) i have 40 samsung monitor here in my cafe so plz guide me to open the cover of monitor. call me my no. 0564993626
May 14, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
GE top load Washer ripping clothes
Solution!
GE has replaced the "boot" (the large rubber gasket at the opening of the washer) on my washer. This has fixed the problem!
Although the majority of people I spoke with at GE did not know about this, eventually I got a repair technician out here who spoke with one of the engineers. The engineer said that there was a problem with the boot causing clothing to rip. The new boot we have on our washer covers a ring of plastic just on the outside of the metal drum (the plastic rim remains stationary while the metal drum spins - this is the cause of the ripped clothing) - the old boot left this plastic ring exposed. Our washer was only 8 months old - so even if your washer is new, if your clothing is being ripped, insist that the boot be replaced for an updated version.
May 03, 2007 | GE Energy Star WCVH6260F Front Load Washer
Diamond Audio CM310D4 Car Subwoofer Logo
59 people viewed this question
Top Diamond Audio Car Audio & Video Experts
xxxxxx xxx
Are you a Diamond Audio Car Audio and Video Expert? Answer questions, earn points and help others
