Question about Maytag PER5710 Performa Electric Kitchen Range
When trying to bake, Lock flashes - Maytag PER5710 Performa Electric Kitchen Range
  • cstrouse May 29, 2010
    Maytag Performa per5710baw
    "Lock" light flashes when you press the bake button.
  • 952 Answers
Thanks for using FixYa.
It is normal for the lock to flash. It is a safety feature for the oven to remind you to close the oven door. Just make sure that the oven door is secured and closed properly.
I hope this helps. Thanks and good day.
HotRatchet
Posted on May 29, 2010
    Genius:
  • 1,416 Answers
in an situation this what you need to do to fix up your oven,
first of all put off the power supply of the of the oven and put it on for after sometime and click on the reset button and reprogrammed your self ,(i mean the timing )and all awys be careful with water or any form of liquid with it .
Good luck and thanks for using fixya.
  • Oloyede Monsuru May 29, 2010
    hello,
    then you will have to do what is call home service, open the oven from the cover that protect external effect clean up the liquid or the water around and allow it to dry up it self and then screw it back
    and then click on the reset button to reset the functional program
    thank you.
After self clean cylce the LOCK indicator remains in the dispolay and BAKE function will not work. door flashes in display when BAKE is pressed.
Hello. It sounds like the door switch is shorted and telling the main board that the door is still locked. This will prevent the oven from functioning properly. The door switch part number is 74009591. The manual door lock assembly is 74009764. The part number for the main oven control board is 74009777.
Aug 31, 2015 | Maytag MGR5752BDW / MGR5752BDQ /...
Lock light is flashing when I push bake it says door
Hello meathead4094 - Often when the LOCK light is flashing, it is because there is door malfunction. Try reprogramming the range by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. Typically, this will clear the flashing. If issue persists, the range could possibly have a faulty door latch, light switch or EOC (electronic oven control). I would strongly recommend contacting a professional to get the appropriate diagnosis prior to make any unnecessary part replacements.
Apr 18, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
GE Profile elec range JSP40 Locked door flashing can't use oven
Replace the oven temperature sensor to solve the F3 problem.
You may need to replace the oven lock micro switch to solve the locking problem.
Change the sensor first. Then try the oven.
Mar 04, 2009 | GE JSP46 Electric Kitchen Range
I can't get oven to work on broil or bake; only self-cleaning.
Hello
Welcome to Fixya
My name is Huum,
Try turning the breaker off for 5 minutes and see if this resets the system.
if not you may have a defective Control board and you will need to have a HANDS on tech to diagnose these parts to be sure! They will have the diagnose equipment !
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 21, 2008 | GE Profile JTP18 Electric Single Oven
Mgr5875qdw
Hello sfgelectric,
Welcome,
You said, your broiler and oven won't work. That you set bake and it beeps and the bake light flashes but oven wont light.
Does the display flash any error codes, or just the bake light?
Fault codes
1. BAKE or LOCK may flash rapidly in the display to alert you if there is an error
or a problem. If BAKE or LOCK appear in the display, press the CANCEL pad.
2.If BAKE or LOCK continue to flash, disconnect power to the appliance.
3.Wait a few minutes, and then reconnect power. If the flashing still continues,
disconnect power to the appliance and call an authorized servicer.
4.If the oven is heavily soiled, excessive flareups may result in a fault code during
cleaning. Press the CANCEL pad and allow the oven to cool completely, wipe out
excess soil, then reset
For most concerns, try these first.
Check if oven controls have been properly set.
Check to be sure plug is securely inserted into receptacle.
Check or re-set circuit breaker. Check or replace fuse.
Check power supply
I'll check the repair manual to see what I can find.
Let me know how it goes.
Perhaps this will fix a glitch.
Huuum
Remember to leave a rating.
Oct 16, 2008 | Maytag MGR5875QD CleanDesign Gas Kitchen...
Thermador double oven / Bake wont work /FC code flashed once
I found I have this exact problem. Same bake preheat issue: I can bake if I set broil first. However, the oven doesn't work if I press bake first. The control board has already been replaced a couple times over the years. Is this another replacement??
Aug 30, 2008 | Thermador SC272T Electric Double Oven
Oven will not unlock
Fault Codes
“Bake” or “Lock” may flash rapidly in the display to alert you if
there is an error or a problem. If “Bake” or “Lock” flash in the
display, press CANCEL pad. If “Bake” or “Lock” continue to
flash, disconnect power to the appliance. Wait a few minutes,
servicer.
If this does not work let me know please.
Mar 06, 2008 | Maytag PER5705 Performa Electric Kitchen...
Ge oven problem
door lock is not work check wires motor and switchs.. you may have to replace the door lock
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
F9 code
I hit the same F9 problem when trying to self-clean, except that the door was locked OPEN.
After much trial and error, I found the following fix: 1. Switch circuit breaker off. 2. Switch circuit breaker on. 3. Press Bake button. 4 Press the small/inside button which indicates that the oven door is closed.
The lock mechanism opened and the oven now works fine.
Nov 22, 2006 | Amana AOCS3040 Electric Single Oven
Maytag PER5710 Performa Electric Kitchen Range Logo
124 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
