Remove keyboard samsung np-r40
I have removed the 2 screws on the base of the laptop, but I cannot get the keyboard to pop out
  • 4,924 Answers
To get the keyboard out you do not have to remove any screws..yet ..just remove the fromt cover of the hinges and buttons..by inserting someting on the F1 buttons and open the snap click that are holding that lid in place ...after that see if there are any screws under it that are related with the keyboard...if there are ..remove them ..if not ..just insert somdething at the base(in the space key are ) ..like a fl;at screw driver ..and move a little the keyboard forward to the screen ..about one inch ..and than pop it up..from the snaps at the side..
here is a video about what Im talking ..
http://www.youtube.com/watch?v=l2ii1PIHaCM&feature=related
do not forget to rate ..
Posted on May 29, 2010
  • 128 Answers
I believe that to remove the keyboard you'll have to unscrew the entire case. Be aware that there are many small components inside these laptops and any one of them can be damaged by static shock or a misplaced finger.
To take the case apart, first unplug the laptop and remove the battery.
Second, remove the hard drive, cd/dvdrom and any other removeable components.
Next, find all the screw locations on the bottom of the laptop.
Draw on a piece of paper a rough map of where each screw is located.
Remove each screw one by one placing them on the paper map in it's correct location so that you can put them back where they came from.
Once all screws have been removed you should then be able to split the case apart, the top bezel should split apart from the bottom assembly.
The keyboard should be accessible, it will either be attached to the top bezel or the main motherboard assembly. If it is attached to the top bezel, be careful that you do not damage the ribbon cable that connects it to the main motherboard assembly when you split the two halves of the case apart.
If you are uncomfortable with this procedure or fear voiding any kind of warranty you may have, then I suggest you take it to a Samsung authorized repair shop or equally qualified technician to have this kind of maintenance performed. good day
    Brigadier General:
  • 10,406 Answers
If you have to ask "how", I recommend that you STOP, and take the computer to a qualified technician, and get the work done correctly and safely.
However, if you insist, look at the top-most edge of the keyboard (nearest the LCD screen) -- there may be two "tabs" which slide underneaath part of the chassis. It _MAY_ be possible to pull the keyboard slightly toward you, so that those tabs will move "above" that part of the chassis, thus releasing the keyboard. GENTLY lift the keyboard -- there is a "ribbon-cable" underneath the keyboard, connecting the keyboard to the computer. Don't damage that ribbon-cable!
I need to remove keys from my keyboard for cleaning
Most keys should 'pop' off but the tricky bit is getting them back on...
If you remove them I would advise taking a photo of the keyboard ... may sound obvious but putting the unfamiliar keys in the right place can be a test on your memory/recall skills to say the least.
1. First up, you need to use a small screwdriver to carefully remove all keys from your keyboard. Then loosen the rubber pieces from each of them and place them separately.
2. Once all keys are removed from your SAMSUNG NP-N145- keyboard, you can either use an ear bud or a cotton swab dipped in water to gently clean the inner regions of the keyboard. However, make sure that you do not use too much water for this cleaning purpose.
3. After cleaning the inner regions of your keyboard you need to start cleaning the individual keys using a light fluid and foam rubber. After cleaning these pieces you need to leave them alone to get dried up.
4. Once the keys are dried up you can assemble them back into the keyboard carefully. Make sure that the rubber pieces too are assembled in their appropriate places.
Regards
Jul 01, 2013 | Samsung NP-N145-JP02US NETBOOK
Remove key bord np 300 e
No exact guides. Using experience, and one video I found.
Three styles are generally used to fasten a Keyboard to a laptop;
1) Screws come from the Bottom of the laptop, up into the Keyboard.
Not always, but most of the time; there is a marking near the screw hole.
KB, or Keyboard, or a Keyboard symbol; and an arrow pointing from it, at the screw hole.
Screws removed there may be Keyboard Cover screws to remove, and remove the Keyboard Cover also.
2) Keyboard Cover. Cover is above the Keyboard, and below the LCD screen.
Once removed, there are generally 2 to 3 screws, to remove at the Top of the Keyboard; or screws come up from the Bottom of the laptop.
3) Detent Latches.
Spring loaded little latches, immediately above the top edge of the Keyboard.
Usually 3 to 5 latches.
Generally start at the Left side, depress the first latch.
Let's say it is the 3 latch design.
One clip to depress, may be above; and in-between the F2 and F3 keys.
The next clip at the top in-between the F7 and F8 keys.
The last clip at the top in-between the F12 and Insert (Etc), keys.
This is the style I think you have. Amount of spring loaded latches,
I do not know. I base it off of this disassembly video,
http://www.youtube.com/watch?v=WrMbmV2daAw
I base it on 10:53 through 10:58 in the video.
He's holding the Top Cover (Palm Rest Cover) in his hand, and the Keyboard is still attached.
(Nope. Never removes Keyboard, lol!)
1) Suggest lay a soft Static free cloth, on the table you're working on.
Helps prevent scratching the table, and laptop.
(DO not perform this on a bed, couch, or directly on a carpet floor.
HIGH areas of Static electricity)
2) Remove ALL power. Remove the AC adapter (Charger), and Battery.
3) http://www.insidemylaptop.com/disassemble-dell-inspiron-n5110-inspiron-15r-laptop/
Linked for specifically showing the spring latch design.
Go to Steps 5 through 11.
Steps 5 through 8 for the spring latch info;
9 and 10 for the Keyboard Cable removal, from the ZIF motherboard connector.
NOTE*
A) Keyboard Cable STAYS with Keyboard. It disconnects FROM the motherboard connector.
B) The Keyboard Cable is an FFC. Flat Flex Cable.
It has NO plug connector on the cable, for the motherboard connector.
Just a flat cable with flat terminal contact strips on the end,
http://en.wikipedia.org/wiki/File:Flat-Flex-Cable.jpg
It MUST go back in the motherboard connector, the SAME way it came out.
For this reason, you may wish to make a mark on one side of the cable, and a matching mark on the same side of the motherboard connector. (Sharpee?)
Then when installing new Keyboard (If this is what you are after), you compare the two; and line the Keyboard Cable up off of the old one.
The bottom rectangular part, that is white in this example; is the BODY.
It is Stationary to the motherboard.
The upper part, that is Black in this example; is the Locking Bar.
When closed, the Locking Bar wedges the Keyboard Cable, in the Body. Can also be stated as when Locked.
I call this style the Flip-Up style. (Pretty technical, huh? lol!)
You may also have this style, the Slide style,
Closed (Locked),
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L675D-L670D/big-body/dismantle-laptop-10.jpg
Open (Unlocked)
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L675D-L670D/big-body/dismantle-laptop-11.jpg
All you can see of the Locking Bar here, are two 'Tabs' on either side of the Keyboard Cable.
The 'Tabs' are eased up with your Thumbnails.
Use a metal tool, and you can slip. Possibly break the motherboard connector, and could stab the motherboard.
It ONLY moves about 2mm. That is a little more than 1/16th of an Inch, or about the width of this capital letter -> O <-
Being detailed because IF you BREAK the motherboard connector, you are looking at MOTHERBOARD REPLACEMENT.
Be careful, go slow.
Regards,
joecoolvette
Mar 11, 2013 | Samsung R610-64G Laptop
Samsung r40 reset to factory settings
hello there Start by pressing F4 when the BIOS "Samsung" screen is showing. This will allow you to restore the original operating system from the recovery partition, if is there. (Also try the other Fn keys - F6 and F8 may do something).
Otherwise you will need to beg, borrow or buy an XP Home installation CD and use that for a new installation. You can use the Samsung key on the bottom to activate it. You can get the R40 drivers from SamsungPC.
Feb 12, 2013 | Samsung NP-R40 NP-R45 NP-R65" (CL102791)
Hello, I am looking for the basic instructions for replacing the keyboard unit on a Samsung NP-R720 laptop. I am not a computer novice ! The first computer I owned, I built in 1983, but there can be some...
First, not that the keyboard is held by two long screws (as marked in the picture below), which are to be opened from the bottom.
After removing the battery and bottom screws, you have to remove the top cover (near LCD hinges, above keyboard). After that you would be able to pull the keyboard and remove the connecting ribbon cable to detach it. Below is a video for Laptop keyboard replacement.
Also, have a look at some Similar Laptop Disassemble Guides
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 12, 2011 | Computers & Internet
Hi..samsung r40 power jack ..how do i remove underside cover to gain acess??.. i have loosened all screws and still seems as if there are hidden screws..
hey, dc jacks are always a nightmare to replace, ie i guess you want to replace it, you actually need to remove the motherboard in the machine so you need to remove all screws on the bottom of the laptop, then remove the keyboard, and you will find more screws under there, and you will have to remove screen etc to gain access, ie everything needs to come apart to get into them. and once its apart you will have to unsoldier the old dc jack and resoldier on the new one, if you aint good at soldiering i wouldnt recommend doing it yourself.
May 26, 2010 | Samsung Computers & Internet
HOW DO I REMOVE CD-RW FROM SAMSUNG NP-R40
there is a screw & a button near the drive, first remove the screw, then push the button up (its like a lock), keeping push the level up while pulling out the drive.
Oct 28, 2009 | Computers & Internet
How to open up to get to fan? replacement fan site?
Screw mapping differs depending on the model, there will be a few hidden screws around the hinges these are usually located underneath the keyboard bezel (this plastic strip that goes across the top of the keyboard), behind the hinges and under the laptop, once you have got all the screws the lid will come away from the base and then you will be able to start to split the base so you can get to the fan, the fan will come out easily.
I live in the UK and i get the majority of my spare parts from ebay, i don't really trust repair shops as these parts are second hand mostly.
Regards.
Jul 16, 2009 | Computers & Internet
Bios battery location
On the R40, you will need to remove two things to get to the BIOS battery: 1) the regular battery, 2) the Keyboard. The BIOS battery is located just underneath the keyboard. In order to remove the keyboard you have to remove two screws from the bottom of the notebook (each will have a little picture of a keyboard and arrow next to it). Pop the keyboard up gently and the BIOS battery is just above the mouse buttons.
Check out the service manual for more details (pages 68, 77, 85).
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-45899
Apr 28, 2009 | IBM ThinkPad R40 2681
648 people viewed this question
 Grubhead
Grubhead
