Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
I put a new timer on. I tried to run a cycle. It
I put a new timer on. I tried to run a cycle. It fill and agetate, but it will not advance to the rinse cycle or the spin cycle. What could be the problem?
  • Whirlpool Master
  • 1,606 Answers
You need to replace the lid switch . Pt. # 8054980 . It is located behind the control panel , same area as the timet .
Posted on May 29, 2010
Washer will not cycle
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Oct 24, 2008 | Kenmore 15864/15862 Top Load Washer
Machine fills with water (hot or cold) but doesnt advance whatsoever
the timer motor that advances the timer to change the cycles is not running,they are a small high impedance motor and burn out,you need to just buy a whole new timer rather than try to replace this small motor
Jan 09, 2011 | Whirlpool LSR5132PQ Top Load Washer
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Machine will not automatically advance thru cycles
The timer has a motor used to advance it through the cycles. If the machine fills with water and the timer stays in one position no matter where you put it......even in the spin cycle, then replace your timer.
May 03, 2009 | Washing Machines
Frigidaire washing machine gets stuck on cycles
Apr 01, 2009 | Frigidaire Washing Machines
Maytag washer wont start after it fills
Did you replace the pressure switch its a round plastic thing with a plastic tube at the bottom and six electrical connections
Mar 14, 2009 | Maytag Washing Machines
Washer won't advance from cycle to cycle
* It's the timer, if your washing machine fills with water and begins agitating, but the timer never
the timer.
* It may be a cold-water supply problem, if the washing machine fills with water, agitates,
Nov 16, 2008 | Danby DDW1805W Designer Series...
Won,t drain on rinse cycle
There could be several causes for this, but probably a bad timer. One test for this...when it stops...is to turn it off...and turn the timer slightly clockwise...to the middle of the rinse cycle...and turn it back on. Does it run then?? Try advancing it to the spin cycle after the rinse. If it runs okay after you manually advance the knob...the timer is probably defective.
Jan 13, 2008 | GE WNCD2050AWC Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
128 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
