Question about Epson Office Equipment & Supplies
Espon R390 fatal error code - 0x60 PW sensor error it came after i reset ink counter
Soulvisitor
  • 1113 Answers
SOURCE: oki 9800 230 fatal error
No reset need to fix fault then clears...check toner carts are secure on drums, all their contacts are clean,
Replace Toner Cartridges with Gen OKI new ones... are you using non oki product? Cause Toner carts, thats where I would start looking cause the error is the machine not receiving correct information from a little chip built into the toner cartridges to allow operation to begin.
Posted on Dec 21, 2007
  • 97 Answers
SOURCE: 161 fatal error C7300
Try this - WARNING - will reset everything to factory defaults
The machine must be put back into "Shipping Mode" in order for the consumable counters to reset.
In order to place the printer back in "Shipping Mode" do the following:
0.27c?openelement&fieldelemformat=gif
1. For the C72/74/92/94 models, hold the (1) and (5) keys down, for the C73/75/93/95 hold (0), (1), (6), and (7), while turning the printer power on. (Hold until "MAINTENANCE MODE" is displayed)
2. Press (0) five times until "ENGINE DIAG MODE XX.XX" is displayed.
3. Press the (2) and (4) keys simutaneously, "ENGINE DIAG LEVEL 3" should now be displayed.
4. Press the (5) key once, "LOCAL PARAMETER SET" should now appear on the display.
5. Press the (6) key three times until "FACTORY WORKING MODE" is displayed.
6. Once "FACTORY WORKING MODE" is displayed, press (3) once so "Shipping Mode" (Fuse Cut Enabled) is displayed in the bottom line.
7. Next press and hold (3) & (7) together, until "Shipping Mode" stops flashing.
8. Power the printer off and back on, now the printer will reset the consumable counters. ecblank.gif ecblank.gif ecblank.gif
Posted on Dec 08, 2008
jell587
  • 447 Answers
SOURCE: reset canon iP 1600 waste ink counter
This link should help you with your problem.
Posted on Feb 21, 2009
  • 33 Answers
SOURCE: How to reset the Canon MX850 Printer, after ink
One way is to hold the 'Stop/Reset' button for at least 5 seconds until the display shows a new message about ignoring the current ink condition. This does not reset the chip but it does allow you to continue printing with the refilled ink tanks.
Posted on Apr 29, 2009
pineworks
  • 4041 Answers
SOURCE: canon i9900 printer error "waste ink counter is almost full"
You can try I think it is, but also try cleaning the heads that also will gave the same code
Canon i9900 waste tank reset
1) With the printer powered off, hold down the resume button and press the power button.
2) While holding down the power button, release the resume button and press the resume button twice in succession. Now release the power
button. The indicator will blink in green and remain lit in green.
3) Press resume 4 times (Green) for Waste ink counter reset.
4) Press the power button. The printer will switch itself off after performing the function.
Or try
1) Power off printer
2) Hold RESUME button then press and hold POWER. (The beeper MAY sound once, or may not depending on your model.)
3) Hold POWER and Release RESUME.
4) Press RESUME twice then release both POWER and RESUME buttons.
5) When the indicator lights steady, press RESUME 4 times (for the S900, 3 times for the 8200 apparently).
6) Press power to set data.
7) Print away!
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 12, 2010
0x02 motor drive fatal errorCR
check (manually) if the printhead moves correctly left/right without any friction. then check if on the right there isn't paper jammed
Sep 15, 2015 | Epson Stylus Photo R290 Ultra...
Espon T 11 has "Service
Usually when you receive this error its either the waste ink pads,has already to much ink on it where the inks go to when you clean the printhead.
Try going in this site http://inkjetprinterhelp.us/epsonSSC.html and download the SSC service utility. then reset all the counters. After that the printer will be working fine, but there is a possibility that the excess ink will leak out on your printer. Hope this would help
May 19, 2011 | Office Equipment & Supplies
Want to know how to reset my epson R390 printer
Hi!
Download Printer Resetter here: http://www.mediafire.com/?3lbjlqmsqa9
1. Turn on the printer 2. Set the pc date setting to 1 January 2007 3. Adjprog.exe run from the extract of a folder (or locate the file or application. Exe and run it) 4. Click accept 5. Click on the particular mode adjustment 6. Go to interview Then select waste ink pad counter then click ok 7. Click "button box" until it is done then click "initialization" button and then click "finish button" 8. Turn off the printer for 5secs then turn again 9. Set the date today.
Cheers!
Feb 25, 2011 | Epson Stylus Photo R390 InkJet Printer
General error
general error are a "Maintenance request error" or a "Fatal error". Most of the time it is a "Maintenance request error" which means the waste ink pads need to be serviced. You can reset the waste ink counter but the ink pads will need to be serviced at some point. get more information and help from here . Hope this helps you. Or Call or email Epson Tech Support.
If this answer helpful please vote me. Good luck.
Thanks for using FixYa
Jan 12, 2011 | Epson Stylus Multifunction Inkjet Printer/...
My printer shows E 2 7. how can i fix it?
i believe on this model the error code means that the ink tank is full...
http://www.mediafire.com/?s2pa54m5z2wqwru
this is a link to my hosting site where you can download the software reset tool for a the MP models...
To reset waste ink counter at printers canon pixma MP150, MP160, MP170, MP180, MP450 and MP460 there any 2 choice, that is :
  • Start with printer on then run this software
  • Click Reset Main (main) to reset waste ink counter and then click Reset Platen button (additional)
Additional information error codes for the MP models...
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 – Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error – USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Aug 07, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Replace waste ink pad in epson printer (R390) as printer says its saturated
Hi there you can download this from my website.
Main features.
SSC Service Utility allow you to do many amazing things with Your Epson printer :
1) Work directly with CSIC in Epson Stylus printers cartridges.
2) Reset or rewrite any chip using special addon device.
3) Freeze internal ink counters.
4) Reset internal ink counters even with empty cartridges.
5) Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode.
6) Hot swapping of cartridges supported.
7) Resetting of protection counter (even then it is already full).
8) More then 100 different Epson printers supported
This allow many people with high printing demands to save some money (program works with both black and color cartridges).
Up to day this software works under Windows 95/98/ME/2K2/XP with both the LPT and USB printers.
Download Free
Click Link = http://www.4all2sell.com/reset-tools/sscserve.exe
All files on my website are only there for a limited time
Apr 10, 2010 | Epson Stylus Photo R390 InkJet Printer
Same problem nothing words showing on paper!!!!!
Check if your resetter need to date setting first. set date to 1 Jan 2007. Run program. select particular adjusment.menu waste ink counter. Click main pad dan platen counter. check and initialization.Turn off. Turn on again and check it.
Jun 16, 2009 | Epson Stylus Photo R390 InkJet Printer
Not works
You can reset the waste ink counter using
http://tricks-collections.com/2008/09/resetter-epson-c58-c67-c79-c90-r270-r390-rx650-cx3900/
The generic SSC utility is also available at
http://www.ssclg.com/epsone.shtml
However, remember ink is still accumulating in the waste ink reservoir and will eventually start to leak out. To replace the waste ink pads you need to disassemble the printer.
A free copy of the service manual is available at
http://www.filestube.com/2572254e26edfe0a03e9/details.html
Jan 31, 2009 | Epson Stylus Photo R390 InkJet Printer
Epson Stylus color 760
The flashing lights are a "Maintenance request error" or a "Fatal error". Most of the time it is a "Maintenance request error" which means the waste ink pads need to be serviced. You can reset the waste ink counter but the ink pads will need to be serviced at some point.
May 17, 2008 | Epson RX620 All-In-One InkJet Photo...
2,171 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
