Question about Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
Washer will not drain
I pulled the cleanout and found a dental pick and some coins. Put back
together and now it sound like it is trying to drain ( hear impeller turning) but still no draining.
  • 159 Answers
There may be more debris in there or the impellor is now broken from its shaft,the pump will need replacing.
Posted on May 29, 2010
Samsung washer keeps reading ND. Have manually drained the washer, cleaned all the hoses out. Found a coin, removed it, washed a blanket and the washer worked fine. However when doing another load, again...
The nd error code stands for No Drain.
Try following the steps here:
http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view_us.jsp?SITE_ID=1&PG_ID=4&PROD_SUB_ID=864&PROD_ID=866&AT_ID=149972
You will need to slide the unit forward to access the pump if there is no access panel on the lower front. If the clean out access panel is on the lower front bail the water from the washer and twist the filter head counter-clockwise. If the front panel does not have the access panel the washer will need to be slide forward. With the washer pulled out the back access panel can be removed. With the panel removed, the drain pump will be visible. Remove the two hoses on the pump followed by the two 7/16 bolts that mount the pump down. With the pump off, you can now remove the debris inside.
Put the washer back together and test for proper operation. If the error code comes back this means that the pump is clogged again or the pump has failed and would need to be replaced.
I hope this information helps you. A 4-thumbs up rating is greatly appreciated. :)
Jun 07, 2011 | Samsung WF209ANW 40 cu. ft. Front Load...
I have an Axxis+ washer/dryer. The washer is giving me an F:34 error, any ideas?
you can try this I had one of these the other day. On the bottom front of the washer you will find a round access cover, rotate it to the right to remove it, inside you will find a green cord to manually unluck the door, pull it down. Door should now be unlocked. Chances are the door won't unluck because the wash water is not draining from the washer due to a clogged drain pump. Right behind that round access cover is the water pump. Before you open the pump cleanout, soak up all the remaining water inside the wash basket of the machine, or use a wet dry vacuum to vacuum up the water. Have a shallow pan and lots of bath towels to catch the water when you open up the drain pump cleanout. Check the drain pump cleanout for lint, small socks, coins and whatever gets left in pockets of clothes.http://servicetechhelp.com/discus/messages/2801/65423.html?1241057606
May 03, 2010 | Bosch Axxis WFL 2060 Front Load Washer
My washer will not drain or spin
Machine will not spin unless it drains first.Remove lower front panel youll see pump cleanout cap,unscrew youll probably find coins etc.drain water by hand have wet vac ready.Hope this helps .Please rate my response :)
Dec 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WASHER SLOW TO DRAIN, BUT YOU CAN HEAR THE MOTOR TRYING TO. iS THERE A FILTER ON THE DRAIN MOTOR??????
Theres a DRIAN MOTOR PUMP that could be clogged , its a small motor usually with propeller located where the DRAIN hose is connected , hope it helps AJ
Nov 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Grinding Noise when Washer Attempts to Spin
It is probably the same problem because it is trying to drain during the spin cycle. My machine sounded as though a chain wis clanking, the solution was removing a coin caught in the drain pump. Access the pump from the bottom of the machine. 4 screws hold the mounting bracket on undo those, the electrical connection and two hose to the pump. Undo three screws holding impeller to motor and coin can fall out. Examine for damage if it is not too tore up, put back together. Keep in mind that when you unclamp the hoses that water will come out.
Feb 02, 2009 | Maytag MAH2400A Front Load Washer
Won't drain
dip as much water as possible from tub..remove bottom panel remove clean out port on pump clean and reinstall
Aug 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Drain Cycle Noise
The only way to get into the drain pump is to have the top panel, the control panel and the front panel removed.  You will have to move the washer out of the closet to get the 2 screws holding the top in place.
Jul 14, 2008 | LG WM2688H Front Load Washer
F2 error code on my Kenmore Elite HE3 washer
Based upon your description, the drain pump has either failed or the pump filter has become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) BE READY TO CATCH LOTS OF WATER. CAREFULLY AND S_L_O_W_L_Y unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.
If you need further assistance, let me know
Regards,
reg501
Jul 04, 2008 | Kenmore Elite 45986 Front Load Washer
GE WBVH6240FWW pause/drain problem
I had the same problem for months. Load would pause all the time and items would be soaked. Today it wouldn't do anything and I found out that it was a drainage problem. I called the warranty department and they scheduled a service but warned me that if the problem was caused by debris in the sytem, I would be charged for it. So, I took the job on and finished with like new results after about 4 hours of work. First the pump filter was nasty(batteries, coins, a wrench, hair,etc.), so I emptied and rinsed. Unplug machine. Take off lower front panel (3 screws) and the turn the pump cleanout knob counterclockwise about 2 turns. Have something ready to catch water. Put back in and test machine. If that doesn't work, you will have to clean your pump. Repeat the same drainage process with pump cleanout knob, take hoses off from pump (to the right side of pump cleanout tube), disconnect wiring, remove both screws holding the cleanout tube and pump to the frame and remove assembly out of washer. Remove the 3 screws on the back of pump. Take a flat screwdriver and pry the impeller from the body of the pump(pry carefully because you don't want to mess up the o-ring). Once you have the impeller out, clean impeller and inside of pump casing.(Don't get the electical portion wet!). Put everything back together and test. That is everything I had to do. It sounds hard but it really isn't. Remember to disconnect power from the machine before working on it. You don't want water from the pump cleanout spraying all over the place, the machine has an internal ground and you may become one if your not careful. Our machine is working awesome, my wife is not yelling no more, and I really hope this helps somebody out there. Good luck.
Mar 16, 2008 | Washing Machines
Problem with Maytag MAH2400 AWW
As for the user whose machine will not drain and sounds as though a chain is clanking, the solution is probably a coin caught in the drain pump. I just had the same problem. Access the pump from the bottom of the machine. 4 screws hold the mounting bracket on undo those, the electrical connection and two hose to the pump. Undo three screws holding impeller to motor and coin can fall out. Examine for damage if it is not too tore up, put back together. Keep in mind that when you unclamp the hoses that water will come out.
Dec 28, 2007 | Maytag MAH2400A Front Load Washer
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer Logo
113 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
