Question about New Home Sewing Machines
Janome 657a threading instructions
Janome 657a sewing machine i require threading instructions
mallow1
  • 35 Answers
SOURCE: lost manual to Hello Kitty sewing machine made by Janome
I've always been able to get a free PDF downloadable manual from Janome. They are happy to send you a manual for your specific machine via email, and they've always been very helpful to me. Here's a link tothem:
http://www.janome.com/index.cfm/ContactUs/Machine_Support
Hope this helps!
Posted on Aug 16, 2008
  • 323 Answers
SOURCE: how to thread sewing machine
Yes, but it is a good basic machine.
Here's how to thread it:
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
Posted on Mar 20, 2009
SOURCE: JANOME MEMORY CRAFT 5700 INSTRUCTION BOOK
Hi, I downloaded (for free) a copy of the Envision 8006 (and 8007 supplement) manual from the Elna website 2 1/2 years ago. The Envision 8007 is the same as the Janome Memory Craft 5700. I can email you a copy of the manual.
Posted on Apr 11, 2009
SOURCE: How to thread sewing machine Janome model 372
google how to oil and thread a bernina 900 if your janome is like mine this video will help you.
Posted on Dec 07, 2009
SOURCE: I just bought a janome mini sewing machine. I
First, in order to get the bobbin thread up, you have to turn the wheel backward, not forward. If you try this, and it is not the problem, keep going.
Next you need to check the needle. There is a screw on the right side of the needle carriage right underneath the underside of the top...unscrew this and the needle should come right out. The flat side of the needle shank should go towards the back of the machine. If it isn't, switch it so that it is and try again.
If this doesn't solve your problem, what has happened is that the gears in the machine have gotten out of alignment. There is an easy fix:
Take off the plate that covers the bobbin chase...there are two screws one on each side. Remove these...you need a stub screwdriver, because regular ones will not fit under there.
Remove the bobbin carriage and the bobbin, making careful note of how they fit back in. Take a picture before disassembling it so you have a reference.
The part that carries the thread around the bobbin is still in the machine. Turn the wheel and you will see it rotate. What has happened is that the needle is not going down in the machine at the right point because someone kept sewing after it jammed and one gear kept going while the other one didn't and now it is out of alignment. These machines have plastic gears and the can slip past each other if you aren't careful not to stop immediately when they jam.
To fix it, you are going to have to do some trial and error. Grab the rotating part of the bobbin chase and hold it firmly. Rotate the wheel forward until you hear it click once. Then rotate the wheel backward again and see if it grabs the top thread. If it doesn't, repeat holding the bobbin chase and turning the wheel forward until it does.
Once you have the gears basically aligned, you will need to reassemble everything. Put the face plate back on and put at least one of the screws in all the way. The face plate holds the bobbin chase in correctly and if you don't fasten it it will not work correctly.
Now try sewing. If it starts to jam, stop immediately, cut the threads and look at the back. If it's a loopy mess, you are going to have to dissamble as before and again grasp the bobbin chase and turn the wheel forward one more click, then reassemble and try again. Eventually, you will find exactly the right alignment and the machine will sew perfectly.
I just had to make this fix on my own machine...I didn't want to take it in for repair because the bench fee alone would cost as much as the machine did!
There are some great video's on YouTube for help with threading the machine...look for StampTV and you should find them. Good luck!
Posted on Apr 21, 2010
My Janome MyStyle 16 keeps jamming - thread bunching in the bobbin cavity. Have tried everything but keeps happening... How can I fix this??
PDF]INSTRUCTION MANUAL - Janome
janome.com/siteassets/support/manuals/.../inst-book-7318-english.pdf
making any other adjustments mentioned in this owner's manual. ..... 16 q w e r t. SECTION 3. BASIC SEWING. Straight Stitch Sewing. Machine setting: q Stitch ...
How to Thread a Janome Sewing Machine - YouTube
? 6:55
https://www.youtube.com/watch?v=NUsT0plWt6Y
Mar 1, 2013 - Uploaded by Easy Sewing for Beginners
In this video I show you how to thread a Janome sewing machine ... I've unwrapped it and started reading the manual and it wasn't easy to see ...
Nov 26, 2015 | Janome Sewing Machines
Need user manual for mylock 634
You can view and download the instruction manual in PDF format by clicking this link.
For further details and videos, click here
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
Jul 20, 2010 | Janome MyLock 634D Mechanical Sewing...
Sewing Machines Logo
361 people viewed this question
Top New Home Sewing Machines Experts
Tally Girl
Tally Girl
Nava Hirshenson
Nava Hirshenson
Level 1 Expert
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
