RAM I have a Compaq Presario a year old using Vista basic came with 1GB says 2 max eather stick of Ram works single but when both are in it will not work right dont get it i have never had a prob. in the past intalling ram can you help
    Novelist:
  • 113 Answers
It's likely that the 2 sticks are different types/speeds of memory, so either one works, but both in tandem do not. Even if identical, it's possible that when 2 sticks are installed, they will automatically attempt to run in "Dual channel" mode - and they may not be able to do so because of timing issues. You might have better luck using a 2x1GB pair bought because it specifically supports your machine. Corsair's web site has a memory configurator that helps you to pick the correct type of memory for your machine.
Posted on Apr 08, 2008
Will a compaq Presario R3000 take one 2 G memory stick? I am trying to upgrade the memory on my partner's laptop. Can 1 stick of memory, 2GB, be used instead of 2 1 Gigs?
Hi Bronzen...
HP website for you laptop...
Please take time to rate me
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=125&prodSeriesId=384511&prodTypeId=321957&prodSeriesId=384511&objectID=c00208189
According to the HP website: 1280MB DDR SDRAM (1 x 256MB, 1 x 1024MB) Memory Max 1280MB DDR SDRAM (1 x 256MB, 1 x 1024MB
Sep 15, 2011 | Compaq Presario R3000 Notebook
214-Dimm Config Warning
Just had same problem. Found a solution:
I have an old HP Compaq dc5000MT. It has 4 RAM slots
Here's what DIDN'T work:
1gb + 1gb + 512mb + 512mb
1gb + 512mb + 512mb + 1gb
512mb + 1gb + 1gb + 512mb
Here's what DID work:
1gb + 512mb + 1gb + 512mb
I'm sure that:
512mb + 1gb + 512mb + 1gb would probably work as well.
From my guess they're are 2 "channels" (slots 1&2 are channel 1, slots 3&4 are channel 2) and you have to keep the amount of RAM balanced on both slots and in the same order.
Another thing to note with the old XP OS. IT ONLY WORKS WITH 3GB or RAM. MAX. So 1 + 1 + 1 + 1 (4gb) WILL NOT WORK... PERIOD for XP. Vista, 7, 8 etc. allows you to use a ton more ram + readyboost. They need all the help they can get though since they are major resource hogs.
Aug 15, 2011 | HP Compaq d530c PC Desktop
Can the 1 G of Ram be increased to 2 G of ram on a Compacq V3020
The specs for your laptop says that the maximum allowable RAM that it can hold is up to 2gb so yes you can upgrade it.
2 pieces of 1gb RAM (1gb per slot) or a single stick of 2gb on 1 slot.
Good Day.
Jun 29, 2011 | Compaq Presario V3020US (4400 mAh )
I have a compaq presario cq60-215dx notebook pc, was wondering how do i go about upgrading the RAM?
I have checked the Compaq Presario CQ60-215DX Specification It Originally has 2GB Memory and supports upto 4GB RAM max. If you intend to upgrade the RAM, you can buy additional RAM and put them in you system. Here is the HP Guide to Replace RAM and How to Upgrade RAM Guide
Compaq Presario CQ60-215DX has two RAM slots for DDR-2 (533 or 667) Memory Modules. First you have to check that the RAM slot is available for additional RAM. I believe that it has two modules of 1GB each in both slots. So, you have to get two modules of RAM 2GB each to upgrade to 4GB (or one 2GB RAM module to upgrade to 3GB). Hence, it is recommended that you get 2GB replacement module for each 1GB module you have on you system from local laptop repair/ service center, which would be cost effective as existing 1GB RAM Modules would be useless for you upon upgrade.
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Dec 31, 2010 | Compaq Presario Notebook
Bsod when adding 1gb of ram to my compaq 2200 laptop
jayson30
In regards to the memory issue the problem is that your notebook only support 1gb of memory so you will have to split it between 2 512 sticks as that is the max the computer can handle. This is why the system blue screens with the 1bg stick.
Let me know if you have any more problems or questions
Issken
Mar 04, 2010 | HP Compaq Presario 2200 Notebook
Which ram support for compaq presario c700 tu''
This laptop can have a max of 2Gb of ram, (2x1gb)
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot, None-ECC
Hope this helps.
Aslong as you get 512Mb or 1Gb sticks of PC2-5300 none-ecc laptop ram, you will be fine.
Jan 02, 2010 | Compaq Presario 700 470024-192 Notebook
Upgrading memory on my Compaq Evo N400C notepad
i have the same Compaq Evo N400c its a ram under the keyboard check there to upgrade it i got Compaq Evo N400c 1gb ram
Dec 30, 2008 | Compaq Evo Notebook N400c
How much more memory can I install
This laptop can support up to a max of 1 GB of RAM , so if you buy 1 stick of 1 GB of RAM you need to take out the 768 MB and just put the 1 stick of 1 GB RAM, or your other option is to buy a 256 MB of RMA so your computer will still have a max of 1 GB of RAM and that would be cheaper and you can still use your old RMA on your laptop , this is the lin for the complete specs of your laptop http://www.dealtime.com/xPF-Compaq-Refurbished-COMPAQ-P4-M-1-8GHZ-256MB-30GB-14-1-TFT-CDRW-W-XP
Hope that helps...........
Sep 28, 2008 | Compaq Evo N610C Notebook
Compaq Presario M2000 PC Notebook
The Bios on the laptop motherboard only will recognize a total of 1gig Ram. So the 256 stick would be removed and 2- 512 sticks installed.
May 22, 2008 | Compaq Presario M2000 Notebook
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
