Speakers suddenly dead?
Speakers worked fine last night. This morning, the main speaker shows no green light, but via the volume panel the computer acknowledges that sound is being directed through the speakers.
    Brigadier General:
  • 10,406 Answers
Investigate the "no green light" condition -- did some animal chew through the power-cord? Did some child pull the power-cord out from the outlet? Did your room-mate go on an "energy-conservation" binge, and turn the speakers off?
Posted on May 29, 2010
My volume isnt working theres no sound
you probably have the audio output set to the wrong device. Go iinto the setup menus for your television and change the audio output to the TV speakers.
Dec 21, 2014 | Televison & Video
I awoke this morning to find the sound on my Apex Digital LD4088 LCD tv is dead. The picture is fine, but sound is dead, how do I solve this?
Download the user manual to your TV. Clik here to download it. See whether audio options to it are set right. If all are right, check its speaker. If speaker is OK, the audio output circuit section should be troubleshooted.
If you feel any difficulty in downloading the manual, send your email address to me. I'll send a copy of it to you by return mail.
May 16, 2012 | Apex Digital LD4088 LCD TV
They worked for a long time, now all the sudden they aren't working. The main speaker it's powered on; however the green light is no longer lit and no sound is coming from them. Checking the...
possibly corrupted or missing sound drivers
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
if you dont have a motherboard disc you will have to download the drivers
Aug 29, 2011 | Altec Lansing ACS 54 Computer Speakers
I'm having problems with my Creative Labs Gigaworks S700 speakers. Last night they were working fine, and this morning there is no sound whatsoever. I have them plugged into my laptop, and the laptop...
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 16, 2011 | Audio Players & Recorders
HELP speakers aren't working
Hi
Thank you for your query
Please try the following
1) Ensure your speakers are correctly plugged into the back of the PC they should be plugged into a light green port
2) ensure the volume control on the speakers are turning and you have set them to a decent level
3) Click on Start>Control Panel>sounds and audio devices and ensure the volume is up and the volume is not muted
Please try the above
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Feb 15, 2010 | Altec Lansing VS2121 Computer Speakers
No sound on Logitech Z Cinema 2.1 speakers.
1. Check Output cable properly connected to the computer in Green socket.
2. Check computer Volume Balance.
- go to start- control panel-sound & game controller
- check ur volume mute/unmute, volume all balance
3. check sound drivers/update driver
- go to - My Computyer - right click - properties - hardware - device manager - check sound hardware - Uninsall all sound driver
- Then Scan in device manager. it will automatically install again.
4.Then check output volume.
Feb 01, 2010 | Logitech Z Cinema 2.1 2.1 Speakers
Last night my Compaq desktop was working completely fine and I shut it down normally using windows. Now this morning the power button wont turn the computer modem on! There is a green light that is...
try to umplug the modem from the motherboard last pci slot on the botom of the case if that works ok if not try new power supply if still not working problably bad motherboard thanks
Oct 13, 2009 | Compaq Presario 5000 PC Desktop
Speakers on Dell Computer show uninstalled worked fine before
do a system restore/reinstall the drivers /check for the volume control in the control panel/
Dec 21, 2008 | Dell Audio Players & Recorders
Speaker volume on one side extremely low
i have the same speakers.
but isntead of one side going,
both sides are dead.
and the light on the control side doesnt even turn on
it is plugged in
but i do not know what is wrong
solutions please?
darkhunter234@hotmail.com
Jan 24, 2008 | Dell A425 Computer Speakers
Computer stopped recognizing the speakers
You need to reinstall the latest drivers for your present sound device then restart your pc then check it. It will work surely! you should install the drivers that came with your sound devices! thats it!
Dec 07, 2007 | Polk Audio M3 Speaker
115 people viewed this question
 Grubhead
Grubhead
