Question about Neff H5470 Microwave Oven
My Neff 900 is not working and displaying the H95 code .... what's the problem ?
It's nothing more than the door catch, remove the outer cover and adjust the switch. it's on a slot and that moves out of position. just pull it back in position ans nip it back up. simples!!
Posted on Feb 20, 2012
  • owen thomas Feb 20, 2012
3 Suggested Answers
SOURCE: bosch micro wave error code h95
How to deal with error h95 code?
Posted on Nov 18, 2009
  • 5370 Answers
SOURCE: How to deal with error
Thie would indicate that the door is not closed properly. Open the door and re-close it.If the door is getting closed properly, then also it can be problem with interlock door switch.You will see, that door is got closed properly, but because the door lock switch is faulty, it will not get properly locked.So the oven will display this error code.Try pressing the closed door hard with your hand.And see, if error disappears.But if door switch is ok and its getting closed properly, then is inverter board issue.The board is not detecting the door is closed so the h95 error is coming up. This inverter board is also used in Panasonic and Bosch units.The door if its getting closed properly, then its inverter board issue.It has to be checked by meter. Click this link directly, to know more about, this inverter board:----
http://cgi.ebay.com.sg/Inverter-Assembly-Panasonic-Microwave-Z606YM300BP-/350038684098 ------------- This should help.Keep updated.Thanks.Helpmech.
Posted on Apr 28, 2011
Panasonic microwave default code H95? What does this mean?
The magnetron has failed. Likely the inverter needs to be replaced as well. Best to just replace the entire microwave oven with a new one.
May 06, 2015 | Panasonic Microwave Ovens
Panasonic inverter 900w microwave fault code h97
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Apr 13, 2013 | Panasonic Genius Prestige Nnsd997s...
My neff h5430nogb 900 watt oven is not heating. it makes all the right sounds and the timer comes on but it doesn't heat? can you help
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 24, 2011 | Neff H5430 Convection Microwave Oven
My h5470nogb/03 900 watt microwave cuts out after 20 seconds what is the problem please
Possibly the magnetron is not producing power and as the cavity temperature is not rising, it cuts out.
Is there an error code in the display?
Jan 02, 2011 | Neff H5470N0GB Microwave Oven
Neff 5470 used for 20 min then just cut out
Take it back to where you bought it from and get a new one!
May 19, 2009 | Neff H5470NOGB 900 Watts Microwave Oven
Bosch micro wave error code h95
Mar 28, 2009 | Bosch Microwave Ovens
Neff Microwave H6871 no instruction book - unable to operate it
This is more of an idea than solution but have you tried disconnecting the power supply and then plugging it back in? If the red led display lights up you will know it works. Otherwise I would say it's time to replace the microwave. If you don't have access to the power supply try flipping the breaker.
Jan 14, 2009 | Neff Microwave Ovens
Error code H95
I would assume this is a Panasonic oven?
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
Nov 24, 2008 | Neff Microwave Ovens
My microwave NNCS596S stops working and the code H598 flashes on the timer display. If I power it down and then up again it works but only for a short while. Any ideas?
H598? Are you sure?
I would recommend that you contact your nearest Panasonic-authorized servicer.
Aug 10, 2008 | Panasonic Microwave Ovens
H95
We're happy to help you and.we'd appreciate your thoughtful rating of our answer.
Jul 16, 2008 | Panasonic Microwave Ovens
Neff H5470 Microwave Oven Logo
238 people viewed this question
Top Neff Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
