I cant tell if my dlp lamp is good or not - Televison & Video
  • 4,472 Answers
What would lead you to believe it's not. Please give me as much information as possible along with the make and model of the tv/unit and how long you have owned it.
Thank you,
Lee
Posted on May 30, 2010
  • judd233 May 30, 2010
    i don't know It was given to me and they didn't know what was wrong with it. it is a toshiba 52hm95.
Power light blinking red..tv won't come on after replacing lamp
DLP TV Repair Tutorial - DLP Bulb Won't Turn On - YouTube
? 14:13
https://www.youtube.com/watch?v=5frOnh58Z6M
Jun 26, 2013 - Uploaded by ShopJimmy.com
DLP TV Won't Turn On Common How to Replace Ballast DeadTV ... solid green power light plus sound ...
• New Lamp Doesn't Turn On? Try This! - Fix Your DLP - FixYourDLP.com
www.fixyourdlp.com/forum/viewtopic.php?t=19
Mar 12, 2009 - 50 posts - ‎36 authors
Mine did the same thing after replacing the lamp. ..... TV won't turn on and Color Wheel is GOOD, Temp sensor is GOOD, Ballast is GOOD, and ... • NEW Bulb- still not working
Jan 14, 2010
• Resetting the Samsung DLP Lamp Counter/Hour Meter
Mar 20, 2009
• Samsung Dead Lamp, Black Screen, or Intermittent
Mar 12, 2009
More results from www.fixyourdlp.com
Samsung DLP: replaced lamp however tv won't turn on - HDTV ...
Dec 09, 2015 | Televison & Video
How can you tell if you have a bad lamp or ballast on the Sony DLP KDS60A3000
Remove and examine lamp to see if shattered--lamp has a 2,000 hour lifespan and may look good--if it fails the lamp light on sets front should light.
A ballast is harder to call--can check the approx 300 volts from the power supply to see if it shows at ballast.
Video instructions for lamp replacement are by model number available on You Tube for most sets.
Apr 03, 2012 | Sony KDS-60A3000 60" HDTV
How do i reset my vivitek lamp?
Check your menu options for something like lamp options or special features. I believe if my memory is correct its a user accessable feature from the main menu.. If you cant find it that way send Vivitek an email here for technical support they should email you the user manual telling you how.
http://www.vivitekusa.com/v_contact_support.asp
Oct 17, 2010 | Vivitek V37655 56" DLP TV
Our philips dlp tv was getting a dark picture then today no picture but sound then the whole tv shut off and will not come back on do we need to replace the lamp?
Definately sounds like a bad lamp. A lot of times you can look down in the lamp and the filament will be broken or busted up. That would tell you for sure, but even if it is not visibly bad, I would definately try replacing the lamp first. I've changed many of them at our shop, and your description is definately a common symptom of a bad lamp in any dlp.
Jul 29, 2010 | Philips LX-5414 DLP TV
I turn on my tv then it immediately shuts back off and now i cant get it to stay on. Why is that?
I think you have a dlp tv . always first unplug from wall 10 to 20 minutes to reset micro pross. if that don't work mit dlp tvs are known to have bad filtor capacitors. and always make shure you have good lamp. J.D.W.
Jun 24, 2010 | Mitsubishi WD-52525 52" Rear Projection...
KEEPS SHUTTING OFF
What type or TV is it DLP , LCD, Plasma?
DLP -----> LAMP--------->go to this 2 sites
http://www.discount-merchant.com/SearchResults.asp?Search=Mitsubishi%20WD-62525%2062
http://www.discounttvlamps.com/mitsubishi-tv-lamps-s/20.htm
PLASMA------->Digital boar or On switch it depends ... can you go on the Display Menu and it looks goo?
do you see any spots?
LCD-------------> You need DMD Bord
good luck tell me more so we can figure it out!
Jan 23, 2010 | Mitsubishi WD-62525 62" Rear Projection...
I need a replacement dlp lamp for a Vivitek model RP42HD51-A Can you help??? Cost & Availibility???
here is your tv lamp IQ number:3797048800 so with this is easy to find you a good price try this website http://www.discount-merchant.com i buy a lot from this site is good free shipping and good service i like it oh y will give you a link so you can do it yourself..
i think you know who to !
this is your part number! im not doing any thing lol.. so i can help you
hope it works good luck!
http://www.discount-merchant.com/Vivitek-3797048800-3797552Projection-DLP-TV-Lamp-p/vivitek-37970488-dlp-bulb-lamp.htm
http://www.youtube.com/watch?v=tJXxi5NVZjA
Nov 15, 2009 | Thomson 50DSZ644 50" DLP Rear Projection...
Where can I purchse new lens/lamps at for my Mitsubishi vs 5047?
Is this a CRT (picture tube) or LCD, DLP projetion set. DLP and LCD are lamp driven CRT have three picture tubes (red green and blue). You can tell by looking at the back pof the set if you see the glow of white light than it's a LCD or DLP. Lamps can be purchased at "bluestar international" ($100-$400) (google it) and CRT's are not worth replacing (over $300 each_)
Sep 20, 2009 | Mitsubishi VS-5047 50" Rear Projection...
Samsung DLP HL-P5063W. . .no lamp!
You will need to have it diagnosed if you do not have the service manual, or the knowledge of how these circuits work. I can tell you to replace this or that but it would be a guess! You need to start measuring the voltages on the ballast circuit, as I have seen door switches, fan sensors, heat sensors cause all of your symptoms as well. Good Luck
Jul 24, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
