Question about Dell Latitude D600 Notebook
How to solve c:\windows\syestem32\command.com
How to solve c:windows\syestem32\command.com problem during running of command? Is due to dis reason Sound is not coming from System??
  • 128 Answers
Yes it is due to this reason that sound in not coming from system,u need to repair ur OS with the Recovery CD or at last u need to reinstall ur system
good day
Posted on May 29, 2010
How to fix 0xc000007b problem
This Microsoft Office error code occurs when you are updating installing and copying etc. This error occurs due to router and modem configuration and ISP restriction.
This error can be solved in 4 ways
1. By cleaning temp folder
2. By cleaning the %temp% folder
3. By cleaning the system file
4. By cleaning the Internet Explorer junk
Guide to solve your issue
Open the Run by pressing the window + R keys
Then open the temporary file system location by searching the temp in command prompt
If you have files means then select all the files and clear them by pressing Shift + Delete
This is also similar to clear the temp folder. By this method, we clear the user junk files.
Instead of temp search as %temp% in command prompt and follow the above steps.
Open the Run command prompt
Enter the cleanmgr command
Then select the drive which one want to clean
Then scan for junk data after that choose the entire item from the list except the recycle bin to clean.
Open the run window and enter the inetcpl.cpl command
Then go to advanced tab and select the reset button to clean the junk data
Then you will get pop up to delete the personal settings click ok to delete.
By following the above steps you can resolve your windows error code issues. For further more guidance regarding windows, you may visit the Microsoft Support Number.
Aug 30, 2015 | Computers & Internet
DELL DIMENSION E521 BSOD???? HELP?!
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 06, 2012 | Dell Dimension E521 PC Desktop
Slow boot windows 7
Well, the reason may be one or more problems acting together. The problem nowadays is that it is very difficult and time consuming to monitor and take care of your Lenovo PC. Even experienced users find it hard to perform such tasks on regular basis because you might need to prepare a huge amount of time and energy to deal with each issue separately.
If you want to fix the problems more efficiently, try the Lenovo speed up program, available here: http://www.speeduplenovo.com/
May 03, 2012 | Lenovo Computers & Internet
HP a67000f running vista freezes up. It will do this at anytime even during start up before windows is loaded
Run the Check Disk Utility.
Apr 28, 2012 | Computers & Internet
Hello, I need to disable caching on bios ami 02.59 as i get blue screen irql not less or equal 0x0000000a , 0x00000007,0x00000002, 0x00000000, 0x804e89f where do i find the disable caching option, i...
No, windows 7 dvd will not work with xp. You will need a xp system disc to fix this. Boot from the xp operating system disc and when it comes up click Repair. When the dos command prompt comes up run the check disk utility.
Mar 31, 2012 | ASUS Computers & Internet
My compaq c700 presario getthing hang during play youtube video or doing any work on it.please help me to get out of this problem .....
This can be due to a slow internet connection. Try going to www.speedtest.net to test the speed and see if that might be a problem. Next, scan for viruses and other malware. A good tool can be found at www.malwarebytes.org.
Next run the command MSCONFIG at the command prompt (in Win7, this command can be entered in the space above the START button. When the window opens, click on the startup tab. You can choose to disable everything and see if the problem goes away. Then run the command again and enable the programs you need at startup until you find the problem.
Oct 27, 2011 | Compaq Presario C700 Series Laptop...
Received a ibm thinkpad with window xp pro installed and passward was forgotten how can i remove passwork
You can run the emergency repair installation disk for Windows XP, and specify a new admin password during the process. If you do not have the disks, then it's a much more complex thing to solve (like booting up in safe mode and using command line functions).
Nov 07, 2010 | Computers & Internet
I am trying restore windows vista on my ACER Aspire 5100 but a message keep coming up saying that Windows cannot open the required file D:SourcesInstall.wim. It also says the file does not exist and to...
This error is due to....
  • The default security provider in Windows XP, or
  • the System drive letter
  • To solve dis issue.. try one of the methods
    1)Reset Windows XP Default Security Provider
    1. Open Start menu, select Run, type regedit and then press Enter.
    2. In the Registry Editor window, locate and delete the following registry keys:
      HKEY_USERS\.DEFAULT\Software\Microsoft\Cryptograp hy\Providers
      HKEY_USERS\S-1-5-20\Software\Microsoft\Cryptograp hy\Providers
    3. Exit the Registry Editor and restart your PC
    2)Reset The System Drive Letter
    1. Start your computer in Safe Mode-turn on the PC, and press F8 during startup. Next, when the Windows Advanced Options menu is displayed, scroll down and select Safe Mode.
    2. Open Start menu, select Run, type regedit and then press Enter.
    3. In the Registry Editor window, locate the following registry keys:
      HKEY_LOCAL_MACHINE\SYSTEM\MountedDevices
    4. Edit this key to change the value of the system drive.
    5. Exit the Registry Editor and then restart your PC
    Mar 20, 2009 | Computers & Internet
    Firewall settings
    This usually happens due to missing or corrupt SharedAccess reg key, which represents the Windows Firewall Service.
    Resolution
    Download sharedaccess.reg (for Windows XP SP2 only) and save to Desktop. Then double-click the file to merge the contents to the registry. The Services entry will be created. Restart Windows (mandatory step, otherwise the following NETSH command will display an error message).
    After restarting Windows, run the following from Command Prompt (cmd.exe)
    NETSH FIREWALL RESET
    Launch firewall applet from Control Panel, and then configure your Windows Firewall settings.
    If nothing helps, as a last-resort solution (before reinstalling Windows XP Service Pack 2), give these two commands a try. Click Start, Run and type:
    rundll32 setupapi,InstallHinfSection Ndi-Steelhead 132 %windir%\inf\netrass.inf
    Restart Windows, and then run this command (from Command Prompt):
    Attempt to start Firewall applet. Start the Windows Firewall service if prompted.
    Apr 21, 2008 | Microsoft Windows XP Professional With...
    Dell Latitude D600 Notebook Logo
    54 people viewed this question
    Alun Cox
