Question about Viking Professional Series VURI140TL Stainless Steel
Free standing 25lbs ice machine
The ice machine makes ice non-stop. it overflows. so when i open the door the ice overflows on the floor. i had to shut it off. it looks like maybe the sensor doesnt work so it keeps making ice even if it is full,
  • Anonymous Nov 28, 2008
    I have the same problem, I think mine is the pan inside that fills with water is over flowing and causing a big ball of ice to form and therfore it is not draining/melting properly. who knows, i cant figure it out.
  • 59 Answers
It sounds as though the bin therrmisotr is defectice, which as you stated the unit is not sensing the temperature and just continues making ice.
The second issue would appeare to be a drain issue, it should be a gravity drain into either an open drain or a sealed pump.
Posted on Mar 05, 2009
SOURCE:
Water leaks from freezer on floor.
Hello. May be the ice maker is overloading water. Is simple to regulate. You must take away the front cover from the ice maker, then will see a regulator screw, move it about 1/2 turn to minus posicion and check if water still leaking from the ice machine
Oct 20, 2014 | Whirlpool Refrigerators
I have a Hoshizaki Machain and it is leaking water above the door on the left side running down to the left leg when standing in front of the machin, what cause this to leak?
IF you are talking about a freezer, make sure the unit is level as the condensate pan may be overflowing. Also, if the door does not seal properly, it can cause "Sweating" as cold air is escaping and causing condensation at the door. Start with that first.
Sep 10, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Ge pfs22mis ice maker won't stop
Hello:
No real fix here, just a design flaw..
Try switching ice maker on /off switch until you ready for more ice..
Cheers
Jul 15, 2017 | GE PFS22MIS
It won't stop making ice. HELP!!!
The ice unit is available online. U can disassemble the unit and see if u can spot the problem also. It is not complicated
If you need further help, reach me via phone at https://www.6ya.com/expert/gary_9c859f4aa7e5ab10
Mar 01, 2018 | KitchenAid KBFS25EVMS Stainless Steel...
Whirlpool refridgerator is leaking water on the freezer side (side by side refridgerator) onto the floor. The ice machine was overflowing with ice and has frozen ice in the ice maker that won't budge. We...
WAS IT LEAKING FROM INSIDE THE FREEZER OR FROM BOTTOM OF FRIDGE? ONCE IN A WHILE YOU NEED TO TAKE OUT THE ICE BIN AND DUMP ICE OUT AND CLEAN IT. HOW CAN THE ICE MACHINE OVERFLOW WITH ICE WHEN THE ICE IN THE TRAY WON'T BUDGE? NEED CLARIFICATION. SOUNDS LIKE YOU EITHER HAVE A BAD ICE MAKER MODULE OR THE SOLENOID FOR THE ICE ON THE WATER VALVE IS BAD.
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE Monogram ice maker dispensing ice on its own
my best guess is the board in the door.try appliance parts pros.they have the best warrenty on parts.
Nov 19, 2017 | GE Monogram ZDI15C Automatic Icemaker
Ice maker is overflowing
Older icemakers have a bar that drops from above your ice bin; once the bin is full the bar is raised and trips turning the ice maker off so that it won't dump. If your's is this style, try manually pushing the free end of the bar upward so that it locks in the upward position. Newer ice makers with the ice bin in the door have a small panel that moves to the open position when the door opens and closes when the door closes. Mine also includes an optical sensor that is visible when this panel is in the closed position. Try placing a non-clear tape over the optical sensor (don't know if that will work or not but worth a shot). If effective in stopping the ice flow then call a repairman. If none of this works, turn off the water supply coming out of the wall to your freezer.
Sep 08, 2009 | Kenmore Freezers
Viking Professional Series VURI140TL Stainless Steel Logo
188 people viewed this question
Top Viking Refrigerators Experts
Ekse
Colin Stickland
Colin Stickland
fordexpert
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
