Hi, I have a phillips tv model 60pp935217... when I turn it on the led comes on for about 2 sec. clicks and then turns off with no picture or sound ever coming on. Thanks for any help.
-   i also have simmular problem. 60pp9100d/37- turn it on nothing light blinks . unplug plug it back in chirp noise short time light blinks but nothing
-   Guest
Dec 07, 2008
-   my 60 in phillips tv doesn't turn on-   samnathsam
Nov 09, 2008
-   60 inch philips rear projection when unit is turn on led on front comes on for about 5 sec and then shut down I can hear the hig voltage come on for about 2 sec -   xerox135
Best Solution
posted on Oct 25, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have a phillips HDTV monitor model 60pp935217, i don't get an hd picture but i do have sound. Please help.
I have the same problem. During an AT&T U-verse install, the tech was unable to get the HD picture to work, but was able to get sound. The tech suggested that there was a problem with the tv.
Was this helpful?
Yes
No
Popular Solutions for Philips 60PP9352 60 in. Rear
I replaced the blue bulb. (CRT) Now the picture is concaved looking. ( Further away in the...
(More)
I replaced the blue bulb. (CRT) Now the picture is concaved looking. ( Further away in the center.)Been out of school for a while)
Replaced a CRT the blue one. Now the remote will not work to cut the set on. The picture lookes...
(More)
Replaced a CRT the blue one. Now the remote will not work to cut the set on. The picture lookes further away in the center. Like it is concaved or something.
after a few minutes of use, the screen was flickering and there were lines horizontally appearing on...
(More)
after a few minutes of use, the screen was flickering and there were lines horizontally appearing on the screen
I have a Philips 60" projection TV model #60pp9352. The TV turns on but has no sound. It...
(More)
I have a Philips 60" projection TV model #60pp9352. The TV turns on but has no sound. It initially had issues with HVG and both the LSB and the SSM boards have been changed. After changing the boards the TV was working for about 5 hour. The following day after about 30min the sound turned off and a crackling sound was heard in the speakers, audio output, and Headphone ports. All inputs(AV1, AV2, ....) have the same response (Video but no sound). After leaving the TV off for about 3 days, the sound works again, but turns off after 5 min. What could be the problem?Is something heating up?
