Question about Kenmore 54603 / 54606 Side by Side Refrigerator
Kenmore Elite 106.54603300 no cold air in either side
I have a Kenmore Elite Stainless side-by-side model 106.54603300 that stop working last night. Lights work, Fans work, no cold air in either side. Condenser is warm/hot and clicks. No other noises can be heard from it. Tried turning it off for a while but no luck still does not get cold in either side.
Thank you in advance for you help
    President:
  • 949 Answers
The problem is most likely the start relay for the compressor. The part number for the relay is 2319792
The picture below shows the location of the relay, on the side of the compressor there is a black cover (part 12 below). The metal band on the cover is holding it on. With the power off (unplug the frig), take this cover off. Next write down the wires and where they are connected or take a digital picture of the terminals so you can remember where the wires go. Part 16 in the picture pulls off the compressor terminals, it may be tight and need to be gently pried off with a screw driver. once off, shake the relay, if it rattles at all it is bad for sure.
Let me know if you have questions or need more assistance.
Posted on May 29, 2010
  • 7 more comments
  • lawrencedigi May 29, 2010
    took the relay off, shook the relay and it made a rattle sound. Like something inside was loose, like metal parts or something. Not loud, but noticeable. Should a fully operational part make no noise at all?
  • Philip May 29, 2010
    A new relay of this type will not make the rattle sound.
    You should be able to find a local appliance parts dealer that would have the part in stock as it is pretty common.
  • lawrencedigi Jun 01, 2010
    Ok, parts stores were open today. got the part, installed it, seems to be getting cold, however i hear a "click" sound every so often from the area where the part is installed. Is this normal?
  • Philip Jun 01, 2010
    You may here a ticking, more of a mechanical sound from the refrigerant from time to time. Saying that you should not hear the relay or overload(both are inside that cover) they should be pretty much silent.
    Make sure the fan below is running to keep the compressor cool and the back panel is on covering the compressor and coils, this cover directs the air flow across the compressor, if the compressor gets too hot while running this could cause it to click on and off from time to time and still be cooling.
    fans are running, it was a "tick" sound comming from the area of the part. It has been three hours with the doors closed and it is only kinda cool inside.
    It will take about 24 to cool all the way down to temp. The back wall of the freezer should start to feel the coldest
  • lawrencedigi Jun 02, 2010
    ok, just checked it again, not cooling off. checked the compressor, it was hot. turned it off and took the part back out and now it rattles.
    the whole underside of the unit has been cleaned, no dust, both fans are working, lights are on.
    I'm very confused.
  • Philip Jun 02, 2010
    Was the relay the part number I gave you? The 2319792.
    The only thing I can think is either the relay was bad or it is the wrong one. If the cooling started and the condenser was clean and fan running it should work fine. I have never heard of a relay failing so soon even if it was hot down there.
My kenmore elite side by side refrigerator isn't cooling properly
I need your model number I cannot pull up views without the model number. The number most times looks like 321.654987 Thank You, Sea Breeze
12_9_2012_3_01_59_pm.jpgKenmore
Dec 08, 2012 | Kenmore Elite Side By Side Refrigerator -...
I unplug the Kenmore elite not working after unplug
um engine? not sure there is an "engine" on it but there are 3 things that make noise 2 fans and the compressor. Are all three running
Jul 28, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a kenmore elite smartheat quietpak 9 model#110.85872401, it will not heat up just cold air. the air lint filter is clean.
make sure it is not set on air only,just went to a job and that's what it was lol.unplug dryer,take off bottom panel,on right side you'll see the heating element,pull off one of the wires and read out heater with a meter,if it's bad you'll need part number 3387747
Nov 07, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore elite won't quit dinging
kitchenaid refrigerator, model ksRa25CN5500 stopped cooling
May 11, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
I have a kenmore elite model 59676539500 and is not blowing cold
hello, that would be my first guess can you hear the compressor trying to kick on at all ? how old is your kenmore ? if theres no cooling anywere and out of the blue it just stoped cooling then your right with the compressor
Apr 01, 2009 | Refrigerators
Kenmore Elite Stainless French Door Not getting cold
This unit may be frozen up.  Defrost completely to allow the passages to get a free flow of cold air.
Nov 16, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Side by side model # 25357682790
is the freezer fan working?is there frost in the freezer on the walls?can you find the defrost timer?let me know and we can go from there-mike
Oct 15, 2008 | Kenmore 53542 / 53544 Side by Side...
Kenmore Side by Side Refrigerator - ice/water dispenser
The water will not dispense, its worked since we moved in but last night it just stopped working.
Oct 16, 2007 | Kenmore Refrigerators
Kenmore 54603 / 54606 Side by Side Refrigerator Logo
247 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
