Question about Acer Aspire One Netbook 8.9" Notebook
Brightness setting how to set the brightness
  • Acer Master
  • 2,404 Answers
Press the little blue "Fn" button next to the left "Ctrl" button. Then whilst still holding down the blue "Fn" button, tap the left and right arrow keys accordingly to increase/decrease the brightness.
This "Fn" button is how you use all of the other blue icons which are secondary functions of other buttons (i.e. to turn the number pad on you need to press "Fn" and F11 and repeat the process to turn it off.
Try that and if that doesn't work then the screen may be bad.
Posted on May 29, 2010
How do I alter the colour, brightness, and contrast?
Go to menu, go to screen settings or display settings. Should bring up the sharpness, contrast, color, brightness controls. Follow directions on screen to adjust. Hope this helps!
Jan 29, 2016 | Televison & Video
Faint picture screen
Press the reset switch to reset the garmin, is the backlight turned off in the settings or is it possibly faulty?
Oct 27, 2008 | Garmin StreetPilot c530 GPS Receiver
I have a NP470RSE-K01UB that has been upgraded to Windows 8.1 and I am having display brightness issues. I have all the Windows power settings set to max brightness regardless of whether the computer
Go to samsung website and go to support section. Download and install the samsung hotkey software. This should fix your hotkeys to turn brightness up and down.
Aug 11, 2014 | Samsung Computers & Internet
How do i increase the screen brightness HP elitebook 8530p
Sounds like your keybinding/hotkey combo is not doing its job. (or your bulb in the display is going out)
You can open up Control Panel and adjust brightness from there.
Step 1 Click "Start ' Control Panel ' Hardware and Sound ' Power Options" to open the Power Options window.
Step 2 Click and drag the bottom "Screen Brightness" slider to the right to increase screen brightness and to the left to decrease it. Making this adjustment changes the brightness level only for the current power source; if you change power sources, the screen brightness may change again.
Step 3 Click "Change Plan Settings" on whichever power plan is currently selected.
Step 4 Click and drag the "Adjust Plan Brightness" slider to the right to increase brightness for each of the power sources, such as "On Battery" or "Plugged In." If you want high-precision numeric control, you need to access the advanced settings.
Step 5 Click "Change Advanced Power Settings."
Step 6 Click "+" next to "Display" and then "Display Brightness" to expand these options.
Step 7 Click "On Battery" and enter a percentage in the field provided. Choosing "100" will set the screen to maximum brightness; any other brightness will be a percentage of the maximum brightness. To increase the brightness, make sure the number you enter is higher than the current value.
Step 8 Click "Plugged In" and set its brightness percentage.
Step 9 Click "Apply" and then "OK" to close the Advanced Settings window.
Step 10 Click "Save Changes" to save any changes you made on the Edit Plan Settings page. If you only make changes in the Advanced Settings page, the Save Changes button will be grayed out. If that's the case, just click "Cancel."
Hope this helps!
Apr 28, 2014 | HP EliteBook 8530p Notebook
How to adjust contrast on dell 610
You can only adjust brightness. There is no contrast control.
Jan 17, 2014 | Dell Latitude D610 Laptop Computer -...
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
Brightness and contrast symbols
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
T20 screen Is there a brightness setting.
There is a Bios setting, it isn't hidden though. Config > Display > Brightness (high/normal).
Try that.
Jul 02, 2009 | IBM ThinkPad T20 2647 Notebook
Cannot change the brightness
to adjust brightness levels you might want to modify ONLY the brightness, contrast and gamma settings. Others might mess up your colors or god knows what. You can also set up the GPU's brightness settings by going to the gpu's control panel, usually opened by right clicking the desktop and selecting your video card's control panel option. Then adjust the brightness, contrast and gamma options to suit your needs. Hope that helps!
Jun 10, 2009 | Hannspree HW191D LCD Monitor
Picture is not bright
Hi
Try to re settings your Unit... go to settings then choose color setting then click brightness control or the contras control.
Thanks!
Jan 03, 2009 | LG 42LC2D 42 in. LCD HDTV
Acer Aspire One Netbook 8.9" Notebook Logo
136 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
