Question about Fuji FinePix E550 Digital Camera
Zoom error Lens stuck in the halfway-out zoom position (lens cover is closed)and I am getting the "zoom error" message.i try to 1.turn off/on again but not ok 2.take battery off for 1 hour but not ok 3.Changing new batteries but not ok please give me how this problem was solved by my self. thank you... (i had bought camera about 3 years .my camera ever sent to dealer because same ploblem about 3 time)
  • cagosta Apr 11, 2008
    I've had this problem before and was able to manually 'urge' the zoom to retract. Worked for months, but now has happened again and won't take any 'urging' this time.
  • Anonymous Apr 21, 2008
    Lens stuck in the halfway-out zoom position (lens cover is closed)and I am getting the "zoom error" message.i try to 1.turn off/on again but not ok 2. Please assist me
I had sent my camera in for the same issue and they did nothing to help with it. Seems to happen when battery gets low or dies, lack of on-screen battery meter doesn't help. Typically have to manually twist the lens to close it or open it after fresh batteries installed and then seem to fix it.
Posted on Apr 13, 2008
SOURCE:
Lens Error
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Aug 04, 2009 | Nikon Cameras
My camera lense is stuck and my camera wont turn on
hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u
rate me!!!
Jul 28, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
Lens stuck in out position, screen shows zoom error. How can I fix the problem?
just take out the battery ....charge it ...and put it back....switch off and switch on the camera once....should work fine
May 15, 2009 | Fuji FinePix A345 Digital Camera
Zoom Error, Lens won't close
There are several causes for this to happen.
1. The lens assy is out of alignment and stuck; stalling the motor.
2. The motor itself is defect
3. If you can hear the motor working , then it will be a stripped plastic gear between motor drive and lens assy.
DIY repair not recommended (possible)
Mar 07, 2009 | Fujitsu Cameras
Canon S3IS
It's about $124 repair charge if your camera is out of warranty. I called Canon and the guy said to be sure the batteries are now wearing down (which I charged mine last night thinking that was the issue and it doesn't appear to be, however, I'm going to buy some new ones JUST to be sure), but other than that it would have to be serviced because it's something internal. The only place to have it serviced is in Illinois, so it's a send off, he said other Canon shops only service SLR's, not these little automatic ones. HTH...it really stinks to have my camera malfunction at the end of ball season!
Jun 16, 2008 | Canon PowerShot S3 IS Digital Camera
Nikon coolpix 775 digital camera
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Dec 02, 2007 | Nikon Coolpix 775 Digital Camera
FUJIFILM A 310
Hi
I had same thing. I took camera to bits and still didn't work. Then one day just before throwing it in the bin with batteries in and lens extended, I grabbed the outer ring (bigger part of lens near the body) and pulled it out a little further. I think there was a slight click then the red light turned green and everything was back to normal. Maybe I was lucky,but its worth a try because it definitely worked for me. Cheers John
Oct 21, 2007 | Fuji FinePix A310 Digital Camera
Coolpix s6 lens cover error
I have a solution posted in doc "nikon s5 s6 lens cover error repair.doc"  uploaded on site http://www.esnips.com/web/papputatiyasStuff    It will be helpfull for you. Its is a step by step solution with images.
Regards Mukesh
Aug 30, 2007 | Nikon COOLPIX S6 Digital Camera
Fuji FinePix E550 Digital Camera Logo
165 people viewed this question
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
