A C26 code is a peak detection error on your scanner. You'll have to turn off the copier, remove the glass and CAREFULLY clean the mirrors and exposure lamp on the scanner. That usually takes care of the problem.
HI if this is a Toshiba copier the C26 relates to the exposue lamp you can check by looking at lamp when the machine is turned off and then back on it should self test at the initialisation stage if there is no light the lamp has gone you can check with tester if you have the experience by removing the glass and using a tester.. good luck
Was this helpful?
Yes
No
Popular Solutions for Toshiba COPIERS - E-STUDIO 650
We have a toshiba e-studio 550-810 printer driver gl-1020. It will only print the "odd...
(More)
We have a toshiba e-studio 550-810 printer driver gl-1020. It will only print the "odd pages" We've looed, and no we aren't printing to odd pages. It happens to everyone's machines. We reloaded the print drivers. We even had a new controller and hard drive installed. It still doesn't work. "The guy" is suppose to install a new board tomorrow, which leaves us with only a loaner copier.
Toshiba e-studio 550 is only displaying "Starting Controller - Please Wait" when switched...
(More)
Toshiba e-studio 550 is only displaying "Starting Controller - Please Wait" when switched to printer mode.
"starting controller please wait" and then nothing happens copies but won't print Toshiba...
(More)
"starting controller please wait" and then nothing happens copies but won't print Toshiba estudio 550 I was told I need gl 1020 and some type of recovery - I'm totally lost Any help would be great thanks
