Question about Bosch Axxis WFL 2060 Front Load Washer
My bosch axiss doesn't spin the belt is still good
We have a Bosch Axiss washing machine.. the drum does not spin so I check the belt and it is in good shape the water can fill the tub and it can drain but it still doesn't spin I need some HELP
  • Bosch Master
  • 19,396 Answers
Hi.
If the machine is tumbling but does not spin, check and eventually replace the pressure switch.
The pressure switch is located on the drain line, and connected to a rubber hose that can be found at the lower side of the tub. This device is used by the electronic control to determine the water level, the cycle won't advance until there is no water detected after drain part of the cycle. If the pressure switch is faulty, the spin phase may not start.
If the machin is not tumbling and not spinning, and the basket never turns when cycling, but cycle advances regularly, it is because of a faulty variable speed motor, or more often because of a defective MCU (motor control unit). The MCU is an electronic module hosted inside a sealed box, between timer control and motor.
Testing the part is quite complex as there is need to read Volts while cycling and jumping motor to energize it directly. If that is the problem, better getting a technician to test MCU, motor and timer control.
Regards.
Posted on May 29, 2010
My Bosch washing machine won't turn the bowl
Hi Justene,
i Think its control circuit has a problem.
or the fuse for motor drive circuit is damaged.
please check with electrician.
regards.
nuwan
Jan 13, 2014 | Bosch Washing Machines
How to remove cover from axis car seat to be washed
Good Afternoon
The instructions for removal of the fabric can be found in the instruction manual. If you have lost your instruction manual please go to www.maxi-cosi.com and select the Axiss carseat to download a replacement instruction manual.
Jul 17, 2011 | Maxi-Cosi Axiss Reflection Booster Car...
Drum will not spin on any cycle.bosch nexxt 300.
http://www.searspartsdirect.com/partsdirect/part-model/Bosch-Parts/Washer-Parts/Model-WFMC2201UC13/1794/0153200/50033052/00003?blt=06&prst=&shdMod= If the drum is not turning on any cycle then I would suspect either the belt - Item 308; or the motor - Item 327.
If you are saying that it doesn't go into the spin cycle (but the drum turns in other settings) then I would suspect the control board - Item 333
Jun 24, 2011 | Bosch Nexxt 300 Series WFMC2201UC
I have an Axiss and was wondering if you can remove the adjustable head support. My 19mth olds head seems to be squished into this and always falls asleep slouched forward as her head doesn't fit into...
Good Afternoon
The head support in the Axiss should not be removed as this is part of the integral design of the Axiss carseat and it controls the height of the harness.
Jun 07, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
What is the life expectancy of Bosch front loader (under counter)? Making loud noises during wash - not spin - cycles. Worth repairing?
not long. have a Bosch Axiss WFL 2060. It started making buzzing noises starting about a year ago and I ignored them. It failed and I am replacing either the motor or/and more things. If ur a DIY its definitely less expensive than a new machine. dwkendall sends
Dec 27, 2010 | Bosch WFK 2401
Bosch axiss dryer WTA3510US wont run checked power, fuses. i close the door hit start the drying light comes on but nothing happens no clicks noies's nothing. is it the relay board or somthing else?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 14, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Axiss washer front door seal replacement
Remove the top of the machine(screws are at the back).
Look down the side of the front door on the inside of the machine.
You will see a metal wire band holding the rubber on.
You usually only need a screwdriver to loosen the screw which holds it tight.
Try it out and get back to me if you get problems
good luck
Jan 31, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Drive belt and noises.
your drum shaft is broken this is making the pulley wobble causing the belt to come off and it will also explain the noise. This is a very expensive job sometimes requiring the complete tub to be changed might be time for a new machine
Jul 30, 2007 | Bosch Classixx WVF 2402 Front Load...
Bosch Axxis WFL 2060 Front Load Washer Logo
91 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
