Question about Panasonic CW-1006FU Air Conditioner
Gas not enter in the A/C
The gas does not get refill
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 195 Answers
I am unsure ezactly what youre saying, a bit more data surely would help , wouldnt you think?? just saying, Getting back to yhr gas does not refill, you might mean hold a charge, in which case replacement is the economical viable solutiion at this juncture.
Posted on May 29, 2010
How do I refill air condition gas
You don't!! Its a task for a trained person because there are more steps to take than just refilling. Also the gas is harmful so get help.
Nov 06, 2014 | Toyota Genuine 1 30 / 40 series Estima...
Hard to refill gas tank have to pump real slow car runs fine
You've got your gas tank presure release valve.stuck or no good
Jul 15, 2014 | Hyundai Motor 2003 Sonata
When I put gas in my tank, I have to pump the peddle to get my 06 Buick Rendezvous to start! It only happens when I put gas in the tank? Any suggestions??
man you only puts fuel when you fuel tank is really empty and that cause the air to enter into the fuel circuit try next time to refill before it gets totally empty and lights up
your car will turn on without pedal trick
May 31, 2011 | 2006 Buick Rendezvous
Mu ac is blowing warm air not cold whats up with it
dear sir/madam
please try to check first airconditioner,s comressor, its working or not if it,s working and not getting cold then it can be low gas problem andf it,s need to refill freon gas ,i will leave it,s up to you for contact to a/c technician for refill gas or refill by yourself ( if you know how to refill gas)
thank for using fixya for your air conditioner,s problem
hope answer the question
please vote!
Jul 02, 2010 | Whirlwind FH-778 Air Conditioner
Ran out of gas, refilled, drove about 9 feet, it shut off and won't restart, plenty of crank, but won't turn over. Put gas stabilizer into tank, let it sit, tried again. Still won't turn over.
hi, let me give my opinion about it... if you already refilled a gas.. try to pump and make sure that it will bleed because the you encountered an AIRLACK PROBLEM... even u refill a gas it won't start if u don't pump it... thank you very mch...
Jul 06, 2009 | Poulan Garden
Lg 2hp split air condition needs original refill gas
hi! there,
well! there several factor to be consider in
insufficient cooling effect,
1. under charge, low charge of freon
how to detect: Check oprerating current
using clamp ammeter ,
clamp on one line and
take reading compare
this to rated current on
manuals if below
your system is under
charge,recharge
freon 22 ,if same is good
check also on sight
glass located on hi side
if bubbles appear your
system is under charge
irecharge if clear still
good.
Freon 22 and others are refrigerant gas and easily evaporate when they escape on athmospheric pressure.they are dagerous to our athmosphere if they expose,they destroy our stratosphere that filter sunlight coming to earth the radio active of sun cannot enter or block by stratosphere if this destroy radio active affect our mother earth.
so in charging freon,they should not escape or leak in our athmosphere take all necessary precaution,there is international law about freon leaking on air,try to update on this issue.
2. evaporator coil and blower should always maintain in obstruction and paricles blocking the fin.if the ice is developed on eveporator this mean evaporator is dirty need to be clean also with fan and blower.they cannot blow air sufficiently due to ice solidified on fin to block air passage.also, on condenser tube fin don let to distored rejection of heat sufficienly help good evaporation of freon .
if fan and blower has insufficient in blowing of air, change bearing, perfomance
will improve in full effeciency.
so cheers and have a nice day to london
guys thank's
Apr 03, 2009 | Panasonic CW-1006FU Air Conditioner
Refilling a dunhill lighter
All rechargeable lighters have a refilling nozzle (usually at the bottom of lighter).
All the good quality gas refill cans have the nozzle adapters inside sovering cup.
Brake off the nozzle adapters off the cup and try to fit them onto lighters refilling nozzle.
When found the best fit adapter, put it onto gas refill cans nozzle and holding the lighter and can upside down connect all nozzles together and push together.
As these nozzles are made for mass production lighters, tey do not fit perfect and some gas leak will occure.
Anyway- few seconds will be enough to refill any lighter.
In case if your lighter do not refill by explained action, the refill nozzle in your lighter is damaged or faulty.
Hope it does help.
Do not forget to rate, please.
Jan 23, 2009 | Dunhill Watches
Starting problem after gas refill.
possible the gas pump release valve ,check your gas pump.
Sep 02, 2008 | 2000 Toyota Camry
Panasonic CW-1006FU Air Conditioner Logo
49 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
