Question about Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
Not firing how can i test to see if a pilot generator is ok
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 195 Answers
It should be at 750 mv or a bit less if in the system under load, test it out ot system, make sure flame is at the tip of the pilot generator, as the temprerature differentail across its body is what creates the 3/4 volt or 750 mv. easier to simply buy one, test the valve using a AA battery with a wire taped on each end, simulate a pilot generator by attaching the wires where the generators wires went, if it works its ok, and generator is bad
Posted on May 29, 2010
Jandy lg250n changed temp control still won't fire. any way to check millivolts
Yes, with a meter.
To check only the pilot generator, to see if producing enough Milivolts to operate heater, 'Clip' your meter leads to the ends of the pilot generator wires. Now push down on the gas valve knob in Pilot mode, and after a minute, the Milivolts can be read. Because the leads are NOT on the gas valve (most accurate way), you will need to hold down the knob, during the test.
To locate where an open circuit may be, why heater is not firing...
place one meter lead on one of the TH connections at the gas valve. The other lead will start at the next sensor in line away from the gas valve. Place on each side. If MV's present on 'in' side, and not on 'out' side that sensor is the reason. If no MV on 'in' side, but had it on 'out' side of previous sensor, then that wire is the reason for no fire.
Jun 08, 2015 | Jandy Pool & Spa
I AM WORKING ON A COZY W501E WALL FURNACE AND CANT GET THE PILOT TO STAY LIT. i HAVE CHANGED THE GAS VALVE, THERMOCOUPLE,AND THE SENSOR FOR THE HIGH LIMIT. THE PILOT WONT STAY LIT.
Pretty much the only thing that will do that is the thermocouple not generating enough voltage for the valve to say it's OK.
Usually you need to hold the button for pilot lighting for 60 seconds. You can use a meter to check that it's generating enough power. The thermocouple has to be in the pilot flame properly.
Check this video:
https://www.youtube.com/watch?v=suen7QlJl4o
Gas furnace will not light Thermocouple test with the multimeter
Or see this site:
How to Test Thermocouple with Multi Meter Heating and Cooling
Feb 11, 2015 | Cozy Heating & Cooling
How do I clean or replace the pilot generator on a Jandy Lite 2 pool heater? The pilot will stay lit but the main burners will not come on. Jumpering the gas valve will ignite the main burners and the
if the pilot stays lit and main burners wont fire you don't need to replace the pilot generator! you have an open safety, poor electrical connection or a problem within the tstat controls
Aug 19, 2014 | Pool & Spa
No Heat. Replaced the gas control valve. Pilot burning OK
Try bleeding the gas line to the valve. They are always full of air after a valve replacement. BE CAREFUL!!!!!!!!!!!! Gas is explosive!!!! Does the valve "click" when the stat calls for heat? If not, check the wiring.
Dec 12, 2013 | Water Heaters
Need to light pilot light
You need to turn the knob on the gas valve (inside the heater) to the "pilot" position. Then, while holding a flame over the pilot assembly push down on the knob.
Gas should come out of the pilot and ignite. Continue holding the knob down for 10-15 seconds. Release the knob and the pilot should stay lit. If not the pilot generator may need to be replaced.
Turn the knob to the "on" position, close the heater and turn the heater on and turn the thermostat to hot. The heater should fire. If it does not fire and the pilot goes out, that may also indicate a pilot generator problem.
Nov 20, 2013 | Teledyne Laars Pool & Spa
Heater fires 3 times then quits, light on control board quits blinking then minutes later it tries again.
It sounds like a weak pilot generator. They wear out after a number of years. It is trying to fire which means the safety loop is all good. Sometimes the pilot generator is strong enough to keep the pilot valve open, but upon call for heat the main gas valve isn't getting enough voltage to open (and a good voltage output from the generator drops to nothing). It's not too hard of a diy
Sep 12, 2013 | Jandy Lite 2 Natural Gas Pilot Light...
My laar hot shot natural gas pool heater pilot says lit but wont fire any more replaced pilot generator pilot that whole unit nice pilot but wont fire
problem isnt with the pilot generator. you have either an open safety withing circuit, lose wiring connection, or tstat issue
Aug 17, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
I have an old gravity gas furnace with a PG9 pilot generator. The pilot goes out once per week. How would I install a new one?
first of all check to see if you need a vent stack wind might be blowing it out if ok then check to see if spider web in pilot generator if ok replace pilot generator turn off gas then follow the small silver tube down under replace the pilot generator
Dec 31, 2010 | Teledyne Laars IGNITION TRANSFORMER
Raypak rp 1200 - pilot is on, unit will not fire. 10-12 ohms in safety loop. 340 ma from generator with loop connected. 440ma with loop disconnected. Do I need to clean the generator/pilot orfice? If...
If this is a MV heater you need 500MV to run the heater. 200 to start the pilot and 300 to open the main valve. If your dropping 100MV on the safty circut you will need 600 or better to fire the heater. I would clean all the connections on the safty circut. I will usually change the whole pilot assembly, but you can get away with just the pilot generator.
It's hard to say how to remove the pilot as their are a couple of different ones and the heater you have listed has none, but a hot surface ignitor instead. Also it runs on 110 or 220v stepted down to 24v for most of the safty circut.
Sep 04, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Heating & Cooling Logo
739 people viewed this question
Top Lite On Heating & Cooling Experts
1STHVACMAN
Paul Carew
Michael Galve
Michael Galve
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
