Question about Philips DVDR890 DVD Recorder
Will not record anymore, and won't playback any dvd,s, when i load a dvd it shows no disc,
When I put original cd display showing NO CD
Posted on Sep 29, 2012
5 Suggested Answers
  • 4 Answers
SOURCE: recorded disc playback trouble
You have to finalize the dvd's through the menu... from page 36 of the manual....on the remote control press SETUP use the arrow key to select "DISC EDIT" press OK Use the arrow key to select FINALIZE press OK. A confirmation window appears, use the arrow to select YES and press OK.
Posted on Jan 28, 2008
  • 289 Answers
SOURCE: Mechanical Noise in Drive
hii..please go for a change in belt.
thanks..
Posted on Feb 01, 2009
guitarman002
  • 80 Answers
SOURCE: How can I record a tv show onto a blank disc? I
Make sure you have the right DVD disc and the disc is clean if you do... (2) make sure you connected it right and are fully seated. LINE IN on your DVD-R is for the recorder part LINE OUT on the tv is to send it to the DVD-R If you done that try another RCA cable or two That should fix it
Posted on Jul 15, 2009
  • 35 Answers
SOURCE: my dvd/vcr recorder combo records,
If this doesn't happen with regular DvDs you rent or buy, there may be something wrong with the way you're recording DvDs then.
It could also mean the lens head on your DvD reader is dirty
below is a link with instructions on how to clean
http://www.ocmodshop.com/ocmodshop.aspx?a=1225
Posted on May 02, 2011
What is the settings for playback?
There are no specific settings for playback on this machine?
If the lazer does not read discs and the display shows NO DISC or UNKNOWN DISC then the lazer pick-up needs replacing.
I believe that the lazer pick-up for this LG recorder has been discontinued?
Jun 22, 2016 | LG RH1999H DVD Recorder/HDD Recorder
Bush dvr3006 will play audio disks but wont play any dvd ! just says load for ages then turns off or no disk ! help please ?
These are the formats your DVR will or will not play.
  • Blu Ray Playback: No
  • Blu Ray Recording: No
  • Compact Flash Card: No
  • DTS Decoder: No
  • DVB-C: No
  • DVB-S: No
  • DVB-T: No
  • DVD Audio Playback: No
  • DVD Player / Recorder: DVD Recorder
  • DVD+R Playback: Yes
  • DVD+R Recording: Yes
  • DVD+RW Playback: Yes
  • DVD+RW Recording: Yes
  • DVD-R Playback: Yes
  • DVD-R Recording: Yes
  • DVD-RAM Playback: No
  • DVD-RAM Recording: No
  • DVD-RW Playback: Yes
  • DVD-RW Recording: Yes
  • DVI Interface: No
  • DivX Playback: No
  • Double Layer Recording: No
  • Electronic Program Guide (EPG): No
  • Ethernet: No
  • Firewire IEEE-1394 Interface: No
  • HD-DVD Playback: No
  • HD-DVD Recording: No
  • HDMI Interface: No
  • HDTV: No
  • IPTV (Internet Protocol Television): No
  • Integrated VCR: No
  • MP3 Recording: No
  • MPEG4 Recording: No
  • Memory Stick: No
  • Multimedia Card: No
  • Number of Scart Interfaces: 1
  • PCMCIA Interface: No
  • Progressive Scan: No
  • Real Dolby: AC3
  • Secure Digital Card: No
  • Show View: No
  • Smart Media Card: No
  • Super Audio CD Playback: No
  • Super Video CD / Video CD Playback: No
  • Table / Portable: Table
  • USB Interface: No
  • W-LAN Connection: No
  • xD-Picture Card: N
May 24, 2014 | Televison & Video
Why does my pye py 90DG does not accept any dvd(R-WR)?
Try reloading the driver for dvd player burner. If this does not work try downloading the "read program" for the specified dvd drive.
May 03, 2014 | Televison & Video
I have a panasonic dmr-75v dvr and it won't read blank dvd's.i tried 3 different brands of dvd's with no luck of
This machine will only accept DVD-RAM & DVD-R Discs.
All other formats of Recordable DVD will be rejected for either Recording or Playback.
Please leave feedback.
Cheers
Andy
Jun 03, 2011 | Panasonic DMRES15 DVD Recorder
Need manual for Funai SV2000 Model#WV20V6
Visit www.funai-corp.com and under manual type your model to download pdf.
Jan 06, 2009 | Funai TruTech DVDVCR Dual Recorder
DVD+RW playback problem(s)
same prob with the shows freezing up
with a DVD+/- RW disc the amout of time keeps dropping because with every recording process the disc loses a life you can burn those disc 200 times before they become useless so the disc might be beyond the life peroid or bad
my prob is with the DVD-/+R disc tho and i figured it out the disc was bad
for the grinding noise if its hi piched its normal thats the disc spinning up to read or write speed
if that not the case something is rubbing in there and that might explaine the writting errors
**DISCLAMER**
the disc manurfacture dose not take resposnablity for defective disc and any loss they have caused(if the data is lost)
Aug 23, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Is it dying?
If the player is in VCR mode you will get this problem when loading discs, make sure the light on the front shows dvd. It also happens when trying to record form VHS to DVD in the dubbing menu if you are in DVD mode.
Jun 14, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
DVD player does not read discs anymore
the Laser is most likely defective. most likly it will need replacement. There is no correction that can made to correct the problem except to that of a replacement of the laser
Apr 06, 2007 | Toshiba D-VR4 DVD Recorder/VCR
Can I playback my movies on a DVD-ROM drive?
No, DVD-RAM disc recorded on the DVD Camcorder will not play back on every drive. Some of the new DVD-ROM drives designed to be compliant with the new DVD-RAM book2 standards will playback discs recorded on the DVD Camcorder. Many previous DVD-ROM drives on the market that came out before the DVD-RAM standard was released will not play back discs recorded on the DVD Camcorder. HITACHI manufactures DVD-ROM drives for some PC manufactures as OEM products. HITACHI model GD-7500 DVD-ROM has DVD-RAM read/write compatibility.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Can I playback my recorded DVD-R discs on any DVD Player?
Yes, A finalized DVD-R disc provides playback capability to most home DVD players and DVD drives. (An 8cm DVD-R disc recorded by this camcorder may not be able to be played back by some DVD players / DVD drives, depending on the player, the DVD-R disc and the condition of the recording.)
Philips DVDR890 DVD Recorder Logo
42 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
