Question about Jenn-Air JCB2285HES Side by Side Refrigerator
Refrigerator is running too cold; milk and other things are freezing.
Refrigerator is too cold even when adjust the temperature
Too much freon? Or maybe you got the controls mixed up. My refrigerator used to freeze a gallon of milk over-night.
Nov 18, 2012 | GE Adora DSS25KSTSS Stainless Steel Side...
Freezeing food, milk fruits no control over it
Most likely, the damper door in the air control tower at the top back of the refrigerator section has broken, so that cold air from the freezer is entering the refrigerator whenever the compressor is running, instead of only when the refrigerator section needs more cold air. I beleive you will need a part number WR49X10091 to repair it.
Oct 29, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Our refrigerator started having problems by freezing stuff like milk, now the milk is curdling in a day or two. We have the temp set at 33 and it is still not working properly.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 13, 2011 | Kenmore Top Freezer Refrigerator
My Fridge is not having the tempature to cool the food and the freezer is not freeezing the food but t is cold enough to keep my milk cold. I left my milk and water in the freezer and it didn't freeze...
heatman101
Jul 02, 2011 | Refrigerators
It does not freeze the top it mild cold not icy. the bottom does not even keep milk cold it goes soure.
heatman101
Apr 23, 2011 | Heating & Cooling
Milk, lettuce freezes after temperature is reduced
turn both control to the same number the lowest number and then wait 24 hrs if you want it needs to be cooler move both controls 1 number then wait 24 hrs and see if you are happy
Apr 06, 2010 | Maytag MSD2756G Side by Side Refrigerator
GE Profile Arctica Side-by-Side Refrig PSC23MGMB IS WAY TOO COLD!
it sounds as if the ice door is not closing properly. Check the little rubber door seal to see if it is sealing properly. If not try a hair dryer to soften it. Otherwise you have to buy a door kit.
Feb 01, 2009 | Refrigerators
Freeing food in refrigerator, even vegetables in vegetable tray
You have 2 dials in the refrigerator. One is the thermostat setting the cold temp in the freezer, the other is a damper that allows cold air from the freezer to the refrigerator. Set the thermostat to the middle then try closing down the damper, most say colder or warmer refrigerator. If the damper is closed and your refrigerator is still freezing, then I would guess that the thermostat is bad. A thermostat runs about 40 to 60 dollars wholesale. Retale should be about double.
Oct 20, 2008 | Samsung RS2534 Side by Side Refrigerator
Jenn-Air JCB2285HES Side by Side Refrigerator Logo
52 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
