Question about Maytag MMV4205 Microwave Oven
Door latch broke off - Maytag MMV4205 Microwave Oven
  • Maytag Master
  • 9,047 Answers
Even though you didn't mention your model number, since you posted this under MMV4205, I'll assume that's what you have.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If by door latch you mean the hook-like latch head that protrudes from the door, you will need to take the door apart to fix it.
Please do not remove the door. When a door is removed, one must be sure it is remounted exactly to prevent leakage, which can pose a risk or arcing or even fire.
Normally you have to separate the door panels (as shown in the attached photo) to access the parts.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on May 30, 2010
The door latch broke
Slightly different model, but this will help you fix it.
https://m.youtube.com/watch?v=JqeeGBhRwFw
Feb 06, 2016 | Samsung SMH2117S
Tip
Maytag MMV4205 door won't stay shut.
After tearing apart my microwave, I found a little spring broke off the latches. Open the door to the microwave, pop off the plastic piece that the latches on the door go through. You will see a spring behind the latch. If the spring is not connected to the latch it won't operate properly. The spring was held onto the latch with a tiny plastic piece that broke off. An easy solution instead of buying a new latch is to heat up one side of the spring without burning yourself and melt it through the latch piece where it was originally connected then put everything back together.
Hope this helps,
Pillarair
on Jul 21, 2009 | Maytag MMV4205 Microwave Oven
Why does the light / safety switch stay on when the door latches shut ?
Most likely there is a part missing from the door latch mechanism that you need. This probably broke off when the handle failed. It would be a tab or wedge shaped piece of plastic that strikes the door switch and pushes the switch closed when the door is completely shut. You will need to find that piece and glue it back on or get a new handle assembly from Samsung.
Aug 01, 2012 | Samsung Microwave Ovens
I have a door latch on my whirlpool microwave that has broke several times. We have glued it back several times due to I am a cheap *** and don't want to buy the whole door. Well luckily my dad lo
Please Heidi,
FOR SAFETY REASONS...
It is vital that you have all covers in place and the MICROWAVE fully contained at all times when operating.
You have a high frequency radio there...
It is best to always have a substantial amount (like a cup of water) to absorb the energy...
The best thing that can happen with the energy... it will turn back on the magnetron (source) and COOK ITSELF...
The worst... you will be feeling your own
eyeballs getting WARM.
BE SAFE (please).
Carnac the Magnificent
Apr 25, 2017 | Microwave Ovens
Inner Bootom Door Hinge Broke off...since then it will not turn on...Will that prevent microwave from functioning?
You probably mean the door LATCH broke off. Yes, that will prevent your oven from operating. The door latches operate switches inside to indicate that the door is closed. If the control board doesn't see the right switch settings, it thinks the door is open and won't allow cooking. Replacement latches are available, but you should check with a professional shop to do the repair. If door repairs aren't done correctly, there is a chance of microwave leakage and an unsafe oven.
Nov 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Door latch broke.
Part is available,
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=JE1640WA01&productCategoryId=0123245&brandId=0432&modelName=MICROWAVE&diagramPageId=00001&documentId=E2134524&pop=flush
Eric
Nov 21, 2009 | GE JE1640WA/GA Microwave Oven
Microve latch/spring assembly ... have a broken head on the latch which i can repair but cannot see where to attach other side of spring on Maytag MMV5207bas
Unfortunately, the exploded views do not show the innards of the door.
So as new latch head is not available separately, so if you cannot fix yours, a whole new door will be needed.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
There's probably a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
You can use use epoxy and some kind of hardware to fashion a new spring mount.
If you have to do any gluing, make sure the parts are squeaky clean and dry before you glue them, or it will not hold up.
Oct 30, 2009 | Microwave Ovens
The door latch broke, and I can't get the door open, or the food that was in there before the latch broke!!!
Remove the cover --- you shuld be able to release the lock from withinthe cabinet.
While you are there, you may want to replace the door safety interlock switch(s)
You may have to disassemble the door to get the latch fixed.
Oct 19, 2009 | Microwave Ovens
Panasonic s550bf Door Latch
Do you still have the piece that broke off? If so, you may be able to use two part epoxy to glue it back in place. I did this with a colaric MW and it did the trick. The latch was hook shaped and made from a hard plastic. Pete
Sep 02, 2007 | Sharp R-1610 Microwave Oven
Maytag MMV4205 Microwave Oven Logo
163 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
