Question about Kenmore HE2 Plus Front Load Washer
Kenmore HE2 Front Load Dryer Dryer keeps on stopping & door opens
Kenmore HE2 Front Load Dryer - When the dryer turns off the door automatically opens. I tried to turn it back on to fluff the clothes and it starts but then immediately stops and the door pops open again.
We have had the dryer for 3 years and it has never done that before. I was wondering if that is a built in safety feature and if it is overheating.
Thanks - Lois from Maryland
Benimur
  • 6966 Answers
SOURCE: fluff on clothes
Probable reason why fluff/lint is still present even when a rinse is done is simply because they were not flushed out together with the water.
Depending on the brand and model of your machine, there might be a lint filter on the drain system that is already full and therefore would require removal, cleaning or possibly replacement. To my knowledge, here are basically two (2) types of lint/fluff filter. One is at the or near the end of the drain/discharge tube/hose/pipe which is basically a slip-on and can be cleaned rather easily. The other is internal and would normally be placed right after the tub before any pump hose or tube. This type is a bit more cumbersome to remove/clean replace.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 24, 2008
SOURCE: Need to change door from left hand to right hand open on kenmore HE2
I am looking for the same answer on the washer. You can definitly change the dryer. The holes are on the other side under black tape.
Posted on Jun 26, 2008
  • 5 Answers
SOURCE: Dryer stopped working
The dryers drive belt most likely broke. it must be replaced with a new one.
Posted on Dec 20, 2008
SOURCE: clothes dryer motor overheating
Have you repalced the thermostat?
Posted on Jan 12, 2009
vickygomar
  • 460 Answers
SOURCE: Kenmore HE2 Dryer Does Not Autmatically Shut Off
We need the error code # please
Posted on May 12, 2009
Dryer won't turn off
thermal fuse it is not check door switch or if you are using auto cycle check for a restricted or blocked vent Cheers
Dec 02, 2013 | Kenmore 63942 Dryer
Kenmore he2 front load dryer
door switch error...implies the door is ajar..or that the switch is not working.
Feb 26, 2008 | Dryers
Can i reverse the door opening direction on this model? thanks
no you cant but if you have the matching dryer swap machines and reverse dryer door .hope this helps .please rate my response :)
Dec 09, 2009 | Kenmore HE2 Plus Front Load Washer
How to replace door switch on old kenmore stac.dryer 110.88752792
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.Check online for the part repairclinic.com has it for $14.00 not bad
Nov 17, 2009 | Kenmore 63942 Dryer
Switching the door swing opening?
only if there are capped off screw holes on other side, look for caps mirror image to other side.
Sep 02, 2009 | Kenmore HE2 Plus Front Load Washer
Change door opening on Kenmore HE2 washer and dryer
yes - there is a hinge kit to do so.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 28, 2009 | Kenmore HE2 Plus Front Load Washer
Dryer works for few minutes then stops
clothes can open the door if door latch is weak, causing door opening and stopping the cycle, or a bad automatic sensor
Feb 17, 2009 | Kenmore 62602 Electric Dryer
Kenmore HE2 Dryer makes three beeps but wont start
What happens is that the door switch gets turned inside. I just took mine apart because of the same problems listed. The switch has a tab inside that has to make contact with the internal switch. I pulled mine apart and turned it so it made contact...put it back together and it works fine now. After doing all that it seems like you could turn the swith from the outside a quarter turn with a pair of pliers and accomplish the same thing.
Mar 22, 2008 | Kenmore Elite HE4 Electric Dryer
Nov 16, 2007 | Kenmore 43142 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
81 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
