Question about Karcher 1750 Psi Elec Pressure Washer
When we turn on the pressure the noise is a jerking movement
Evrything works until the nozzel on the karcher is switched on then it starts to **** rather than a smooth sound or action
4 Suggested Answers
  • 92 Answers
SOURCE: Karcher electric pressure washer
Dear mike husband,
One reasin for this fault could be a damaged lance or turbo lance. Try by replacing with new ones. If the problem is not solved, then the fault is due to a damaged spill valve. The spill valve could easily be damaged by using not suitable chemical or detergents. After using chemical detergents, one must always rinse the machine by passing pure water. The spill valve could also be damaged by leaving the machine for a long time with pressure in the system. One must never store such machines with pressure still inside. Always press the gun before storing.
Well the solution is to change the spill valve with a new one. In some cases even faulty suction valves can give this problem. But in the majority of cases it is the spill valve.
If you do not know how to fix this problem, it is better to be done by an expirienced technician.
Regards,
MG.
Posted on Nov 05, 2008
  • 92 Answers
SOURCE: Karcher 3.97M Short cycles after trigger is released.
Dear csdamman,
There is a valve called the spill-valve. It is often called the control valve. This valve activates the micro-switch. When the gun is released, pressure builds up and compresses this spill valve. At the same time it puts off the micro-switch. This will then stop the machine. Now when the spill valve is faulty it cannot hold compreesion under pressure so it starts de-compressing and starts the machine again. This goes on in a cycle as you explained. So you have to change the spill valve. If the spill valve that operates the micro-switch is part of the upper head,...then the whole head must be renewed. Myself I rarely service Spill Valves. The best thing is to renew it. From your explanation it seems that you did not take notice of this Spill-Valve. Infact when you mentioned Pressure Switch, I do not know if you are refering to the spill valve. If you are....then saying that the Pressure Switch moves and operates freely, does not mean that it is OK.
In certain machines in the outlet...there is a small valve, coloured black and red or green and yellow. This sometimes when faulty, it gives the fault you mentioned. Sometimes an inlet valve gives the fault you mentioned. But from my expirience it is most of the time that the Spill-Valve is the fault.
Regards,
Fulltech.
Posted on Jul 22, 2009
  • 4090 Answers
SOURCE: karcher 2400 Psi Pressure Washer No gain of pressure
remove the hose from the machine. Check that water is flowing. and there is no corrosion reducing the opening. If that is OK then it is the internal seals and pressure vallve on the pressure unit Cost to have it fixed by Karcher is $200
Thanks for using FIXYA
Posted on Sep 26, 2009
What is this problem - Karcher 3.86 electric pressure washer: humming noise, plug gets very hot, then unit shuts down?
Your pressure washer is either not fitted with a run/stop device in which case like mine you have to switch off within a few seconds of closing the trigger. Check your model features?
The humming noise is the motor stalled out against the pump because there is nowhere for the water to go. The shutoff is caused by the safety overload switching off after overheat.
Or, it has a pressure operated run/stop which is not working. Because water and electricity don't mix, I would suggest getting more specific help. You can download Karcher manuals /spares lists online from Karcher specialists but remember electricity is the silent killer.
May 20, 2014 | Karcher Garden
Karcher will not **** up detergent
onl use low pressure nozzels to pick up detergent, high pressure creats too much bck pressure
Mar 29, 2014 | Karcher Garden
Karcher 380 works fine until I turn it off. it will then not work for say half an hour
over pressure switch stuck, dismntle switch and clean or replace ( located between on/off switch and pump head
Feb 22, 2014 | Karcher Garden
Craftsman 1800 psi pressure washer won't start
disconnect the hoses to and from the machine and the try it.
the machine might have a blocked nozzle in the lance, of so get a paper clip and clear the jet backwards
Jun 23, 2009 | Karcher 1750 psi Electric Pressure Washer
Karcher K 3.68 M operation
These units have pressure valves that automatically turn off the pump once the pressure is high enough. The pressure switches do fail and sometimes stick and act as you've described.
May 07, 2009 | Alfred Karcher K 5.93 M Electric Pressure...
No pressure on certain settings
Dear Osville,
It is not clear what type of lance or nozzel you have. You said that the machine works fine with the circulating water jet(the turbo). So it seems the machine is fine. I do sometimes service variable nozzels and variable lances. But the best solution is to replace nozzels and variable nozzles and lances with new ones. Regarding the fan spray setting it could have no pressure because it might be in the chemical setting. The chemical setting lets out a fan shape flow of water, but with less pressure. The chemical system only works on low pressure in domestic washers, that is why it needs a low pressure flat spray. The pencil jet has 2 jets comming out because if it is a lance or nozzel with ball bearings, these ball bearings must have stuck in a wrong position. Also 2 jets can come out, due to a damaged nozzel hole.
Altogether, the best advice is to buy a new nozzel or lance...which ever your machine uses. All Karcher machines have their own specific nozzels, lances and high pressure hoses. You cannot change these from one model to another.
Regards,
Fulltech.
Apr 29, 2009 | Alfred Karcher K 5.93 M Electric Pressure...
Pressure washer lacks pressure initially?
Dear allbusiness9,
This problem is most probably due to a faulty Spill Valve( also called Control Valve). When the gun is released the spill valve is compressed and it either closes a micro switch or just opens from the bottom and keeps the water circulating. All spill valves keep the water circulating from the bottom part. Now when the gun is pulled (opened)...the spill valve extends and closes the bottom part, and thus water goes out of the nozzel. When you work with no nozzel, there is enough water flow to close the bottom part of the spill valve. So when the nozzel is placed back there is no chance that the bottom part leaks water. When the gun is started with the nozzel....the bottom part of a FAULTY spill valve,..will colapse and pressure drops. So to fix the fault you must change the Spill Valve. In some occasions, I also found that suction valves give this problem. A faulty sucktion valve will colapse under high pressure, and lets water pass the other way round.
But in my opinion and experience, your problem is in the Spill Valve.
Regards,
Fulltech.
Apr 23, 2009 | Karcher 2500 PSI Pressure Washer
On my karcher pressure washer, how do i get the soap to come out of the spray nozzle?
Two nozzels came with your washer one has a cone shaped head, the other one is blunt, attach the blunt one to the trigger. You will notice on the barrel of the nozzel it says "mix" turn the indicator line to "mix" and it should work. This is a very low pressure setting and is used to "apply" the soap only. You cannot despense soap in the hight pressure mode.
Apr 13, 2009 | Karcher K2.26 Electric Power Washer
Karcher 1750 Psi Elec Pressure Washer Logo
52 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
