Question about Canon iR 2016i Black and White Copier
SETUP OF NETWORK PRINTER IR2016I
I WANT TO SETUP FOR THE SCANNER ON NETWORK BY USING IR2016I CANON MULTIFUNCTIONER TO SCAN ON ALL COMPUTER.
  • 1,219 Answers
Install network scan gear on all PCs and make necessary settings ( IP, discover,... ), it should work as PULL scanner.
Posted on Jun 02, 2010
How i do scanner in canon ir2022
connect computer to network
install canon color network scangear, select printer ip in this software.
now you need scanning software.
I'm using freekapture.
place document in printer scanner. click scan button on printer.open freekapture and start scanning
Jul 06, 2012 | Canon iR 2022 Printer
Hi How do I get my Canon iR2016i to automatically
You need to install a PDF printer driver on yourcomputer first. There are quite a few freeware PDF writer programs on theInternet you can download one such as CutePDF.
Scan your document then click on File - Print and select the PDF writer as theprinter device. Then name and save the PDF file. To download Cutepdf PDF printer driver (freeware) click onthis link :- http://www.cutepdf.com/
Jun 29, 2011 | Canon iR 2020i Laser Printer
I wanted to print and scanned on canon ir2016i directly from my computer. how can i do that? how can i able the printer identify my IP?
if u are on network then u can simply enter the ip address in system settings tab in additional functions.then load the driver ,it will autorun after detecting machine. the scanner is network scanner and will work only in network.
if u are single pc user then load the drive and connect the machine through usb printer port when the driver asks to connect. hola
May 25, 2011 | Canon iR 2016i Black and White Copier
I cant seem to get my printer to scan - please could you advise? it prints and copies just fine.
Which model Canon All-in-one do you have? What OS is on your computer? Wired or wireless connection - if wired USB, then try a new cable. Scanners often fail when the printer works due to a lack of bi-directional communication with the computer.
Did you install the Canon drivers (or full software) if available? These are available here: http://www.usa.canon.com/cusa/support/consumer for supported OS versions for each model. Click on Printers and Multi-function then the product family and then the model. Make sure to select x64 if you have a 64-bit Windows OS. Not all Canon all-in-ones have support for scanning under the Mac OS.
For USB printers, if you plugged in the data cable before installing the Canon drivers, you usually get a generic driver that only runs the printer. If you have done this, then uninstall the driver and remove the data cable before installing the Canon software.
For networked printers, sometimes you need to connect the printer via USB and install additional setup files to get the scanner to work. (Not all scanners work over a network; with a wireless network, signal loss can be a problem.) Again it depends on the model - check the documentation.
Next are you trying to use the buttons on the all-in-one or launching the scans from the computer? If you are using the buttons on the scanner, you need the full software (MP Navigator for Windows) installed and a monitor program running on your machine. Otherwise, you will be limited to launching a scan from the computer. (Please note: you need to set up the destinations for the scan buttons in the software first; so scan from the computer at first to see what the best default settings are for most of your documents.)
I hope this helps.
Feb 06, 2011 | Canon Office Equipment & Supplies
I am trying to setup this imagerunner 2270 as network printer/scanner. it prints okay but i cannot scan, downloaded scan gear too
Do have some sort of scanning software like OmniPage? The scan gear is used as an twain interface between the copier and the computer. Hope this helps.
Feb 02, 2011 | Canon imageRUNNER 2270 Copier
Need help to setup the scan fuction for Canon Image runner 4570
Do you have the send feature or just scan? If just scan you need to install scan gear to the computer you want to scan to and configure scanner, than can pull scan fro canon to any viewer installed on your computer. If you have the send feature, make a folder on the c drive of the computer , share the folder with all permissions. Touch send on screen, reg. new address, touch file, arrow down to smb file, browser button to see your network, highlight your network, touch down highlight your computer name, enter user name and password as shown, log in to your computer from canon and highlight the shared folder and hit ok. you should now be able to send to that shared folder
Oct 24, 2009 | Canon Office Equipment & Supplies
Canon IR scan problem
Read the Manual (comes with Tool). If you don't have the Tool download it from the Canon site. Go to the copier and press the System/Options button next to Copy/Mailbox/Fax. Press Online. Then try scanning. Go back to copier and press Offline so can photocopy again.
May 27, 2009 | Canon imageRUNNER 2200
Canon ImageRunner Scan feature won't connect to network
its waiting for the command from the computer. in order to use scan you have to down load the canon scan tool from imagerunner.com / support/ downloads/ office products/ then canon network utilities. look for network scan gear tool ... down load save open run setup then open the program and you can either let it search for a scanner or you can put in the IP adress for the copier. then under your scanning software ( ADOBE PRO) eg. you selesct the scan gear tool as the scanner. to scan a doc you put paper in feeder select scan online then from your computer tell your software to scan good luck
Jan 02, 2009 | Canon imageRUNNER 5000 Copier
Laserclass 730i scanner driver software
The scanning is based on scanning to email. It isn't really controlled from the computer like a typical scanner is. The settings are all on the panel of the device. They are resolution, Contrast, and Doc Type. From there, you have to configure the machine t send the scanned image to an email address. The email address requires that you have the device setup for email with a network address, smtp server, etc.
May 01, 2008 | Canon 730i Laser Printer
Canon iR 2016i Black and White Copier Logo
923 people viewed this question
old marine
old marine
