Question about Coleman Powermate Powermate 5000W Generator
Will run on choke but stalls when choke is off tecumseh hm100
Install a J19 plug.
Posted on Jun 25, 2010
  • 905 Answers
Your main / idle fuel jet is likely clogged. Shutoff the fuel / drain the tank, and drop the carburetor bowl. You should see the main jet. Spray it out with carburetor cleaner and/or compressed air. DON'T insert anything metallic into the jet to try and clean it out or you will end up scarring it and rendering it useless.
Posted on Jun 12, 2010
  • pflyman2477 Aug 01, 2011
    I have a 3500 coleman powermate with a carb problem. It would not start, after 3 years of non use. Main jet was plugged. I used a pipe cleaner soaked in gas to clear it by removing the float bowl and swabbing out the main jet. Be gentle, as not to scratch the inside of the jet however. Two pulls and it ran like new. Clean is the word. Gently clean the choke plate inside the carb. Remove the inline fuel filter and see if you can blow through it. If not , replace it. Not really the big deal I was expecting. You don't even have to remove the carburator to do this. Hope this helps anyone who has the same problem. Its just a common since job. Good Luck
Carb needs rebuilt and I do not know the part # for this engine, Tecumseh HM100 159370P-B
Should be a metal tag somewhere on the tiller that gives all the information, Will give Model #. type and serial #. Your parts dealer can I dentify the carburetor from those nos.
Feb 20, 2010 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Poping
Is the exhaust holed? If so, i's possible for the exhaust to form a comustible mixture in the muffler, and periodically ignite, causing the popping. If not, this can indicate a lean mixture. Most HM100's have adjustable jets - back off the main jet about 45 degrees. If the carb is not adjustabe, it wll have to be removed and properly cleaned out.
Oct 18, 2009 | Heavy Machinery
Tecumseh HM100 piston replacement
standard size rings & im sure it the torque should be 40 in pounds
Jun 08, 2009 | Garden
Tecumseh Snow King HS40 engine only runs on full choke, no power
i did and thanks - just picked up one that does the same thing and i plan to take your advise
Thank you Jerr
Jan 01, 2009 | Karcher 2500 PSI Pressure Washer
HM100 tecumseh
Did you buy the starter separate? If it came with the engine, it should already be hooked up. If you have to wire it yourself, there is a PDF file online (Tecumseh Technician's Handbook) that tells how to wire it up.
Dec 31, 2008 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Coleman Powermate Powermate 5000W Generator Logo
848 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
