I have an equator washer and some times its leaking water on the bottom on the left side can some body please give me a solution
Plug off the wall socket. Open up behind & top after taking off the plug from the mains wall socket. Check to see if there is hose loose or torn from where you think the leak is from. It is also possible that one of the hoses to your dispenser drawer has come loose, and the water trickles down to the left area, you should check this also. Tighten or replace as necessary.
Hi
The water leaking on floor can be a serious issue as this may cause the inside parts to malfunction or in some cases rusting of the body. To check where exactly it is leaking; inspect the leak while it is running. After the cycle is complete quickly turn off the power, lie down the machine on left/right side and check from where the water is leaking. If it is the hose or drain pump then check whether hose is connected firmly and is not cut. If it not the hose/pump inspect if the leak is on the drum corner or anywhere on the upper side of the drum. If it is on upper side that means the drum is cracked and it is a costly affair. However, if it is leaking from the circumference then it is due to transmission seal. To replace the transmission seal you'll need to disassemble the washer and the drum assembly. Please post back in case of any issues. Hope this helps...
Daniel
