Question about Lexmark X2350 All-In-One InkJet Printer
Faxing I have a lexmark tm x2350 all in one printer. Is it possible fax documents thru this copier? I lost my instruction book and don't know how to use some of the fitures. Thank you, Nelly
    Scholar:
  • 79 Answers
Yes it is possible I own the same printer. The way it works is first you must have a modem installed in your pc and hooked up to a working phone line. After that is done the lexmark software that came with it should have a fax feature somewhere you need to fiddle around with it. I think it was in the Scanning program in particular.
Hope this helps
Thanks for reading!
Posted on May 02, 2008
SOURCE:
I have a lexmark x2350 (all-in-one,2300 Series).In the troubleshoot ,said printer status ready.But when i try print,or take a print page text,i hear:printing started,printing complete,but the machine don`t...
Try to update your printer driver. Please visit the Lexmark website at http://bit.ly/qQJd8g. Select your operating system to download the file.
If that doesn't help, follow the steps below: 1. Disconnect the printer from your computer. 2. On your computer, go to Control Panel > Printers and Faxes. Delete the Lexmark X2350 print object. 3. Reboot your pc. 4. Once the pc completely boots up, reconnect the printer into the pc. Wait until your pc fully recognizes the USB connection. 5. To ensure the print object has been successfully created automatically. Go to Control Panel > Printers and Faxes. You should see a new Lexmark X2350 print object in the list. 6. Try to print again.
Jul 28, 2011 | Lexmark X2350 All-In-One InkJet Printer
How do you load a lexmark X5650 all in one printer, copy, photo, scan, and fax? I am trying to figure out how to load the fax to send the fax to someone.
Sending a fax using the printer control panel:
  1. Make sure the printer is on and is connected to a working phone line.
  2. Load an original document faceup into the Automatic Document Feeder (ADF) or facedown on the
    scanner glass.
  3. From the printer control panel, press the Fax button.
  4. Enter a fax number, or press Address Book to select a number from the Speed Dial or Group Dial list.
  5. Press Color or Black to select a color or black-and-white fax.
  6. Press Start to send the fax job.
Source: Lexmark 5600-6600 Series Fax Guide
May 06, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
How do i fax several docs. to same number/?
Actually, it's just like sending a single-page document to a particular number but you just have to insert the multipage document in the feeder. Here's the Lexmark X4270 User's Guide for your reference: http://www.lexmark.com/publications/pdfs/2007/4200/ug/en/frameset.html. Go to Sending a Fax in Faxing for instructions on faxing multipage document. However, if you're gonna be having a mechanical problem on the printer, I suggest you contact Lexmark Technical Support to further investigate the problem. Thanks.
Jul 01, 2010 | Lexmark X4270 All-In-One InkJet Printer
How can i use my fax with magic jack.using lexmark X2350
This is the answer that I got from the FAQ page.
SOMETIMES.
We do not officially support using faxing with magicJack.
Please try the following steps to use magicJack with your fax (contact your fax manufacturer for details):
  1. Turn off error correction on your fax machine or program
  2. Set the fax machine or program to use the slowest speed available
  3. Increase the speed, checking at each speed that faxes work
It seems that it depends upon the faxing unit that you use.
Mar 31, 2010 | Lexmark X2350 All-In-One InkJet Printer
Why can't i send a fax? Also why can't I get a english manual?
You can visit official site of lexmark.com and take full instructions, how to work with yours fax.
1) you must to connect yours fax prooperly to telefon line
2) insert document
3) enter number
4) press "Start" (or "OK")
Mar 06, 2009 | Lexmark X4270 All-In-One InkJet Printer
I lost the Lexmark X5650 Printer, Scanner, Copier and Fax CD, What can I do?
Hey,
The lexmark drivers and software required for installing the printer is available at www.lexmark.com
Select Drivers & downloads then driver finder.
Type in your model x2350 for example
Select your windows version
Download the setup program.
1.Download software
2.Run the downloaded setup
3.Plugin the printer when asked
4.Done
Thanks,
Ekse
Mar 05, 2009 | Lexmark X7350 All-In-One Printer
Software
I AM HAVEING A PROBLEM WITH TRYING TO GET MY FAX MACHINE TO WORK
Jun 06, 2008 | Lexmark X2350 All-In-One InkJet Printer
Lost my install cd to Lexmarkallin one 7300 printer fax copier what do I do?
You should download drivers from Lexmark website. Its totally free.
  1. Click here for download.
  2. Select your printer model no.
  3. Make download and install.
Thanks
Iqbal
Apr 26, 2008 | Lexmark X2350 All-In-One InkJet Printer
Office one note
First check your printer in printers and faxes menu if it is online.
When printing documents when you are ready to print, at the upper art of the tab choose the printer you install in your computer that is Lexmark X5300.
Jan 24, 2008 | Lexmark X2350 All-In-One InkJet Printer
Lexmark X2350 All-In-One InkJet Printer Logo
67 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
