Question about Nautilus Exercise & Fitness
My tv pixelates when i am running on the treadmill..i have a t514
    President:
  • Nautilus Master
  • 832 Answers
Their is either a cold soldier joints or loose connections on the upper console you'll have to physically inspect all connections leading from the lower board to upper console. Usually the display screen are connected with a mylar connector or hard wired to upper console if your not a tech and don't have any electronics background this can get very involved. My suggestions is call Nautilus and if still under warranty replace unit, if not under warranty get pricing or take it to a computer shop a skilled tech should be able to diagnose a locate the problem.
Posted on May 29, 2010
  • supertall May 07, 2011
    just in case you did NOT.... check the cable connection first. It needs to be tight. Also, it could be a bad connector. you can cut your cable and put on a new metal coax end. These are simple and inexpensive solutions that have fixed the exact problem for me on my t914 treads in my gym over and over. Easy stuff. If its not that check the same connection up under the tv itself since there are two places and two different cable plug ins. on on the base of the tread, and another into the bottom of the tv.
How can I fix my treadmill as it won't run due to Safety Key Lock even when Safety Key is inserted?
Check here for guidance on how replace or repair your safety key:
http://www.partsfortreadmill.com/parts-for-treadmill/treadmill-safety-key/
http://www.treadmillsrepair.co.uk/2014/08/treadmill-safety-key.html
Apr 03, 2014 | Nautilus T514 Treadmill
Nautilus t514 safe key issue
1_ reset the machine, disconnect the machine.
2) test the magnet, the key is magnet, test for attraction or repulsion with the magnet from your refrigerator, if do not pass the test replace the magnet.
3) replace and go and buy in homedepot for little price!
God bless you
Jul 18, 2012 | Nautilus T514 Treadmill
We have a Reebok Vista Treadmill and it turns on but none of the controls work including the ones for the TV?
adjust the reed switch, see the diagram attached, clean, and tigh the connector very well.
Try to RUN the software calibration for diagnose and troubleshooting.
sincerely. God bless you
Apr 28, 2012 | Reebok Vista Treadmill - RBTL13305
Treadmill buttons don't work right. TV won't turn off. Treadbelt won't run.
1) Try to reconnect the plug between console and pcboard very well.
2)Clean the contacts with special contact cleanear( radio schack or computer store) with carefully only the buttons, if you can open the cover better.
3) adjust the Sensor SWITHC.
4) Look for any wire loose, or making bad contact, or break wiring( continuity) test the fuse and breaker.
If after you did those steps, and the problem persist, the console board is faulty.but first change the sensor switch, you must be shure after adjustment.11_18_2011_12_23_17_am.gif
Nov 17, 2011 | Exercise & Fitness
Hi Need to change NAD T515 to region free/ Thanks
Same procedure as NAD T514
1. Turn player on without any disc in.
2. Push "pause".
3. Push "3, 1, 4, 1, 5, 9".
4. A blue menu comes visible. Follow instructions there, or turn "0" and "pause".
5. Turn of player.
Mar 04, 2011 | NAD T 515 DVD Player
The tv on my treadmill has lines through it,
Your problem is the three capacitors which are located beside ic50. Yhey are 100 / 22 and 10uf.
The ESR will be high. Change all three and your up and running.
Philly.
Dec 04, 2010 | Precor C956 Treadmill with Cardio Theater...
Treadmill belt adjustment
There are two bolts on the back of the treadmill. Turn the right side clockwise to make the belt go left, turn the left side clockwise to make it go right. Never tighten more than 1/2 turn at a time, and do this while machine runs at 2-3 mph. Belt should be just tight enough to not slip. If your belt is really tight and it still slips you have other problems.
Jan 03, 2010 | Nautilus Exercise & Fitness
Red and green stripes (1" wide) running down the screen. Started with one red, now a green and another red. The stripes come and go at times, but most of the time they are present.
I hate to be the bearer of bad news but this is actually one of those known and predicted issues with LCD televisions. What these are called are "dead" lines of resolution aka dead pixels aka frozen pixels.
This is one of the flaws of LCD televisions, there is a completely random, unpredictable fail rate of LCD pixels in all panels, the likeliness of failed pixels varies depending on the quality of the panels used in the TV.
There really isn't a resolution to make them go away, if they are simply frozen, usually a light (VERY LIGHT) tapping of the screen at the top and bottom points of the line will refresh the pixels. If they are coming and going more often, it means that the panel is weak or malfunctioning in those areas and you need a new panel in the TV. Unfortunately it's quite an expensive repair, running at least $400 USD, if you are within warranty period (usually only 3 months for dead lines of resolution.. but it varies up to 12 months depending on the manufacturer) I would suggest calling Vizio and inquiring about a replacement TV. They generally won't allow a repair as it costs them less to simply give you a new unit all together.
My apologies for your bad luck!
Dec 09, 2009 | Vizio 42 in. LCD TV
Pixel damage
Those small pixels are now damaged not much u can do with it. Some people say you can press on the screen the pixels affected and possiblilty get them to make contact and light back up ( I honestly highly doubt it) If u can live with and not very distracting keep watching it. But if you want to order a replacement, more than likely it will cost more than the TV did when u bought it. If its still under warranty get it replaced if possible.
Jan 28, 2008 | Philips 42MF531D 42 in. LCD Television
Exercise & Fitness Logo
60 people viewed this question
Top Nautilus Exercise & Fitness Experts
David Payne
David Payne
Electro Med Services...
Techmotionusa.com
Techmotionusa.com
Are you a Nautilus Exercise and Fitnes Expert? Answer questions, earn points and help others
