Question about Garden
What mix of 2 stroke oil do I use for a Stihl hedge trimmer, in other words how much 2 stroke oil do I put into 5 litres of petrol. Thanks.
  • 252 Answers
If using top quality 2 stroke oil
you put 100 mils of oil into 5 litre container and add 5 litres of fuel only that is 50:1 petrol oil ratio
cheers pauly46
Posted on Sep 12, 2010
How do I mix two stroke engine fuel
Put oil in your petrol can add the exact amount of petrol put the cap on shake well use and store out of sunlight
Jul 17, 2014 | Trueshopping NEW 2 STROKE OIL FUEL PETROL...
Is it 25/1 petrol and oil for a sthil blower bg85 thanks
hi artwill3544
no
using sthil 2 stroke oil mix at the rate of 50:1 that is 20 mils of oil per 1.0 litre of petrol that you mix , or if you mix 5 litres you would pour in 100 mils of 2 stroke oil into a 5 litre petrol petrol can , then add 5 litres of petrol only and give good shake to mix , then fill your blower with that mix
cheers pauly46
Sep 21, 2011 | Garden
Is a Victa Sunbeam 160 Special a 2 stroke or 4 stroke? Wondering what additive to use with fuel. Thanks so much for your help.
hi there tanyajames88
your victa is a 2 stroke vc160 these units sare stated to run 25:1 fuel / oil ratio
that is 40 mils of 2 stroke for every 1.0 litre of petrol that mix
so if mixing 2 litres - 1st put in 80 mils of good quality 2 stroke oil then put in 2 litres of petrol , give good shake and fill up your mower tank
2 stroke oil that you would use for sthil chainsaw would be ok its hi quality
you could use some fuel stabilizer additive to hekp stop mix from going stale too soon
if wish but most times just mix enoyugh mix to het job done , then mix more if need it
that way mix is always fresh
vheers pauly46
May 29, 2011 | Garden
Need gas misture ratio for trimmer SRM2501
pauly46 here
the ratio you should use is 50:1
that is 20 mils of 2 stroke oil for every 1.0 litre of petrol that you mix
so if you want to make 2 litre mix use 40 mils of 2 stroke oil , then add 2 litres of petrol only and give good shake
note use good quality 2 stroke oil , such as sthil or husqvarna oil from your outdoor power shop
but if using general 2 stroke oil from a garage use 40 mils of oil for every 1 litre that you mix
this ratio is 25:1 this mix is on the richer side
cheers hope this helps
May 01, 2011 | Echo Garden
Could you please let me know. 1] Can I use E10 fuel in my new RLT 30 CET 30cc trimmer that I have just purchased and am yet to start up? 2] Is 50 to 1 50mm of oil to one litre of petrol?
Hi and welcome to FixYa, I am Kelly
First off the engine is designed to operate on unleaded fuel. The manufacturer makes no statements at all about E-10 Fuel. I will tell you from experience that you can use E-10 Fuel but.... should you ever have a warranty claim make sure the entire fuel system is 100% unleaded pre-mixed fuel. Your not going to hurt the unit using E-10 fuel as long as you maintain the proper fuel-oil mixtures. If anything a splash more of 2 stroke oil as in 22 mm / liter vs 20 mm. Or (+) 8 mm per gal.
Manufacturers statemenrts and recommended fuel mixtures below:
Thanks for choosing FixYa,
Kelly
n This product is powered by a 2-stroke engine and
requires pre-mixed petrol and 2-stroke lubricant . Premix
unleaded petrol and 2-stroke engine lubricant in
a clean container approved for petrol.
n This engine is certified to operate on unleaded petrol
intended for automotive use with an octane rating
of 87 ([R + M] / 2) or higher.
1 Litre + 2 0 ml =
2 Litres + 4 0 ml =
3 Litres + 60 ml = 50:1 (2%)
4 Litres + 80 ml =
5 Litres + 100 ml =
The full operators manual is here:
http://www.screwfix.com/sfd/i/cat/pdfs/89/p4763889.pdf
Feb 27, 2011 | Ryobi 15" Electric Factory Reconditioned...
The person I bought it off said it takes 50 to 1 don't know how to measure that
50 to 1 means that for every 1 unit of (2 Stroke) oil you use 50 of the same units of petrol. Most 2 stroke oil bottles have a measure on the side which you use to measure how much oil you're using so for 5 Litres of petrol (approx 1 gallon) you would use 100ml of oil.
50 to 1 which is usually written as 50:1 is a very light mix. Husqvarna saws use 40:1. You need to use good quality 2 stroke oil from tool hire shops rather than the cheaper stuff you can buy at petrol service stations. Some makes of 2 stroke oil, like Stihl, have a measuring cup on them with ratios marked on the side. To fill them you take the cap off the measuring cup and fill to the mark at 50:1 by squeezing the oil bottle. Then pour that into 5 litres of petrol. You can also buy mixing bottles in some hardware stores with ratios marked on them. You fill the oil up to the mark 50:1 and then fill it up with petrol to get the right mix.
Dec 23, 2010 | Garden
What is proper gas mixture?
fuel mix ratio is 50:1 using good quality 2 stroke oil
ie if you mix 20 mils of oil for every 1 litre of petrol that you mix
that is 50:1
or if you want a 5 litre mix put in 100 mils of oil into a clean petrol container 1st then put in 5 litres of fuel only and give good shake
cheers paul
Aug 13, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I inherited a Rancher 50 20" chainsaw from my uncle only noone know the oil gas mixture.
using good quality 2 stroke oil use ratio 50:1
that is 20 mils of oil per 1 litre of petrol that you mix
put oil in can 1st then add petrol and give good shake
so if mixing 5 litres pour in 100 mils of 2 stroke oil and add 5 litres of fuel only
cheers hope it helps
Aug 07, 2010 | Husqvarna Garden
Garden Logo
699 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
