Why outdoor unit not coming on even after setting temperature too low
  • 674 Answers
First thing check your ciruit breakers or fuses and make sure you have power to the outside unit. Remove the small cover on the outside unit that covers the contactor, capacitor, circuit board, etc. Then set the thermostat to call for a/c. Check and see if the contactor is pulled in supplying power to the fan and compressor. If it isn't check for 24vac that powers the coil in the contactor. If the contactor is pulled in supplying power then your capacitor could be the problem. You can check it with a multimeter with the capacitor check function. If it looks swollen then it is probably bad. Let me know what you find and I can give you some more stuff to check if that isn't it.
Posted on May 29, 2010
Hi,My remote do not get the good temp in my house. Ex: I set to 80F in heat mode but the thermopump operate slowly and dosn't get hire than 70-72F. The remote see the unit and all. Is the sensor in th
You have a heat pump.
Once the outdoor temperature falls below 36 degrees, heat pumps will sharply lose their ability to heat.
If you are getting a 72 degree indoor temperature when the outdoor temperature is 28-30 degrees, the heat pump is performing up to spec.
On heat pumps, the air coming out of the nearest air vent to the unit should be heated approximately 40 degrees warmer than the air entering the unit.
If you have a 70 degree indoor air temperature, the heat pump should be supplying 110 degree air at the closest air vent to the indoor unit.
Gas heat is a much better heating source where outside temperatures are commonly below 36 degrees.
Even electric furnaces perform better than heat pumps under these conditions.
Nov 30, 2014 | Heating & Cooling
How do I get the -- away and get the outdoor temperature to work?
You may have to "reset" it by removing both indoor and outdoor unit batteries, waiting briefly, then reinstalling batteries in the outdoor unit followed by the indoor unit. After awhile, the outdoor unit should begin sending information to the indoor unit.
Nov 20, 2014 | Oregon Scientific Wireless Weather Station...
Cannot get the weather station model ws-916ou-it to show outside temperature
I have three of these WS-916OU-IT units. After a few years, the outside sensor just fails. You will get dashes and a "TR" low battery signal, even if the batteries are good
just buy another whole weather station (short money) and set both the old and new weather station unit to receive from the single new outdoor sensor.
To do this - just follow the procedure for a single sensor - that is - put the batteries in the new sensor - then within 30 seconds - put the batteries in all the weather stations - they will all pick up the same outdoor sensor.
I now have three units running off of one outdoor sensor.
Seems a bit silly, but it works.
Feb 27, 2012 | Measuring Tools & Sensors
The outdoor unit doesnt work for ac panasonic cs c9mkp,i have following the instruction on manual book.
After switching the indoor unit to cool, the indoor fan starts and the light flashes, lower the temperature setting to 16 degree centigrade. When the light stops flashing the outdoor fan and the compressor start, if not check the wiring connection going to the compressor contactor. Check if there is power supplying the holding coil of the contactor. If the contactor works, check the power on both contact points by using a volt meter. If the outdoor fan only works, you need to check line working pressure. If the standing pressure is low, compressor will not start.
Sep 02, 2011 | Panasonic Heating & Cooling
Hi...my split Ac donot cool down the room temperature....even outdoor unit is working....
Even though the outdoor fan is running it may not have the compressor on, one quick way to check is to grab the large copper line going to the outdoor unit to see if it is cooler than the small line. Another way is to open access panel and use a amp meter. If the compressor is running it may be low on freon, if not running it could be burned, loose wiring connections, bad capacitor or bad compressor.
Aug 24, 2011 | Heating & Cooling
I have a 16 SEER Goodman air conditioner and during the morning hours, temperature ranging 75 degrees outside, the compressor comes on but not the outside fan. It only runs for a minute and a half then...
The fan is shutting off in order to maintain head pressure when the outdoor temperature is low. This is common on 16 seer and above systems. It helps your system be more efficient.
Jun 06, 2011 | Goodman Heating & Cooling
My Honeywell AC unit doesn't seem to be working properly. It will not retain a temperature. I set the thermostat to hold a temperature of 70 degrees. Room temp still reads 74 degrees. Something is working,...
The frost on the pipe indicates you have a dirty filter, dirty evaporator coil, Blower not running at the proper speed (to slow) or you are low on refrigerant.
Jun 29, 2010 | Heating & Cooling
Instead of the heating element turning on the heat pump runs out side thermostate is not set on eheat
The heatpump is your 1st. stage heat, when you have a call for heat it will bring on the outdoor unit.
When the first stage heat can't heat the house and the indoor temperature drops 2° or 3° then 2nd. stage heat will kick in and maintain the house temperature at about 2° or 3° below the temperature setting.
If you outdoor unit fails or goes into defrost then emergency heat will kick in and keep the house at 2nd stage temperature approximately 2° or 3° below thermostat setting.
If you have an outdoor thermostat or balance point setting on outdoor board, it will shut the outdoor unit off at a certain set outdoor temperature and the 2nd stage heat will be primary heat for the house.
Jan 05, 2010 | Heating & Cooling
Airconditioner LG LSk181-N2 shutting off
Sounds like your aircon is stuck on heating mode. Or. The outdoor fan speed is affected by ambient temperature, or low refrigerant. In heating mode the indoor fan will come on for a while to sense temperature and will then wait for the outdoor unit to pump up pressure and build up heat.
Feb 01, 2009 | LG LS-K1830CL Cool Mini Split Air...
Carrier 42G250CF-1 won't blow cold air (on lamp flashes)
sounds like you low on freon, you will need a qualified tech to refill the freon.
Nov 19, 2007 | Heating & Cooling
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
