Question about Music
Dln't have a plug for an mk928 keyboard
What is the model number on the plug (which i don't have) for a mk928 keyboard. I think it will be dc12v adaptor with power output of 2 x 6w (found this on a website so don't know if it is correct). the keyboard works with batteries but it needs 8 x D which would be a bit expensive to run!!!!
  • Music Master
  • 5,603 Answers
You would be safe with a 12 volt DC adapter of 1 amp capacity.
YOU MUST match the polarity and I can't find if the center pin is positive or negative. It SHOULD be marked on the case near the plug for the power in.
Use a bright light and see if the pin or the shell is shown as + or -
Notes this is the only critical thing to get right once you have a 12 volt DC adapter that fits the jack.
Posted on May 29, 2010
Testimonial: "Thanks a lot, sorry for delay replying, I forgot the website I used !!!!!!!! Will check your suggestion and respond again if problem fixed."
I have a ypg535 and headphones work but no sound from keyboard. I did unplug the headphones.
If you have sound through the headphones but not the internal speakers then assuming there is nothing stuck in the socket, headphone adaptor, broken plug etc then it would point to the amplifier section of the keyboard having failed. Sound via the hip socket is normally from the pre amp stage. Is there any slight hissing from speakers? If so this reinforces amplifier theory as the speakers are obviously connected.
please state model number of the keyboard and answers to the above .
regards
dan
Jul 20, 2017 | The Music
Looking for a sustaining pedal for the Casio ctk 401 keyboard. What models will be compatible?
They are all compatible. Make sure the port on the keyboard is the same size as the plug on the pedal, usually a phono plug. Also make sure it is a sustain pedal and not an "on off " switch.
Apr 22, 2016 | Casio Music
Yamaha psr 300
I'd suspect power supply first - filter capacitors may have leaked/dried out. That would be an easy fix for someone familiar.
Mar 05, 2014 | Yamaha Full-Size Keyboard
When was this manufactured
Well, first, we need more information:
First, what kind of instrument has this serial number- Guitar, keyboard, mixer...
Next, is there an available model number?
Last, if there isn't a model number, can you give a general description or the instrument?
Jun 23, 2013 | Music
Behringer K3000FX Ultratone Keyboard Amplifier from day 1 has had a slight buzz
For a start , check headphones out.
• if it don't work , check power supply of the preamps.
• If it is OK, could probably the main amp have fail.
But check the main volume .
Sep 11, 2012 | Behringer Ultratone K3000fx 300w Keyboard...
How can I send recordings to my laptop? I have a usb connector and i want to connect my portable grand to my laptop but the laptop does not detect the piano and i don't know what to press on the piano...
Hi mjaynneb,
I could be wrong here but I have a number of keyboards and the USB connection is usually for Midi control from software like Cubase and the like. If by recording you mean recording Audio then I think you'll find that it won't be possible using the USB port.
Midi is great and I use it a lot. It enables you to arrange music using your computer. Also you can record the music you play on the Keyboard on the computer as Midi. This means that the computer can play back through your arranger what you just played. Bear in mind though that Midi is purely numbers that represent notes, velocities and note duration so is not actually audio.
My keyboards have the ability to record to SD card or a Hard Drive, however if this is not a feature of your arranger then probably your best bet for recording audio from it is by using the Audio out ports of your arranger and using a connecting lead to a good low noise sound card on your computer. As you are using a laptop you can find external usb sound cards/interfaces so that should do fine. Then you could probably use something like Audacity which is free software, to record to a wav file.
I hope this helped.
Kind Regards
mparkyn
Jul 27, 2011 | Yamaha DGX 640 Keyboard Arranger
My keyboard keeps shutting off within a minute or two of playing. The woman I purchased it from told me that it had an auto-off battery saving mechanism if you don't touch a key for a while, but this...
If you are running on batteries, they are either depleted OR may have corrosion on the contacts in the keyboard which is COMMON problem. If using an adapter, the cords chronically work loose. A last problem is the switching for using battery or adapter can have poor contacts. If you don't have an adapter, get one and get one SPECIFICALLY for the keyboard... I don't know how many I have had to tell they have the wrong adapter and that is why their unit won't work.
May 15, 2011 | Casio CTK-720 Electronic Keyboard with...
I have the a Casio Keyboard that has an SD slot, but whenever i put songs on my SD card & then plug it into the keyboard, it says that there is an ERROR . What am i supposed to do . Step by Step . to...
Does it say ERR NO FILE? If so, then read on. The reason you have this error is because you don't have a folder on your sd card named MUSICDAT. Solution:
  1. Insert your sd card into computer
  2. Make folder called MUSICDAT.
  3. Then, transfer all files inside the folder (make sure your songs are in MIDI format).
  4. Safely remove your sd card.
  5. You're ready to put it in you Casio Keyboard!
If you still get the error, take time to read you manual. Read the "using the sd card" part. The folder name might be different for your Casio Keyboard (because mine's a CTK-5000).
...and IF you still get the error, perhaps the songs you meant in your question are MP3 songs (like the ones you play on the iPod)? Then, that's a different topic... :)
Well then, good luck!
Feb 28, 2011 | Casio Lighted Keyboard LK90STADMC
Disc error
If it is a Technics keyboard, please post what model it is.Unfortunately Panasonic doesn't seem to think that their Technics line of musical instruments is important enough to have its own category on their website. It is easier to Google the specific model number to find a manual. Without the model number, I can't look at the manual and help you.
Oct 21, 2009 | Music
Music Logo
104 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
