Question about Sony VAIO NS Series Notebook
The builty-in wireless card connection stopped
1-the builty-in wireless card connection stopped working.
2-the router is fine and the server also, the light of the wireless
3-conection switch does light whe is on.
I apreciate help with this problem thank you
    Brigadier General:
  • 10,406 Answers
Purchase either a USB or a PCMCIA wireless-adapter, install it, connect it, and use it, after "disabling" the built-in wireless-adapter.
Or, if your computer is still under "warranty", exercise the warranty to get SONY to fix it.
Posted on May 29, 2010
If i want to connect to my computers wifi it doesent want to
Hi
To connect you computer to you Wireless router you should need some importand thing to Know.
1) What is you ip series, and your router DHPC server is on or Off.
Basicaly the router defualt IP is coming 192.168.1.1 or 192.168.0.1 is router and DHCP server is On.
then conecting you Laptop or wifi follow the mention below instrucation.
1) On you wifi and search, you get you router in serch list.
2) Put the preshard key and press connect
3) In few second you connect to you wifi.
Cheer
Aug 02, 2011 | Cell Phones
Lap top will not conect to the wireless internet connection
If you are on a laptop: (windows)
1. check to make sure your physical on off switch for the wireless card is turned on. Windows will sometimes still show it as being active while the switch is physically still off.
2. Disable/re inable the software connection to the wi fi
(MAC) Disable reinable the wireless card in dropdown menu
3. restart the wi fi router
Jan 16, 2011 | WiFlyer - Portable, shareable WiFi base...
Its saying my wireless internet is connected but when i plugged the internet cord into the router, it doesnt work anymore! its been like that for about a month & a half now.
Make sure all the wires are connected properly. 1.-Unplug your modem and router from the power supply. Wait 1 minute. 2.-Plug your modem back to the power and wait for all the lights to stop flashing. 3.-Plug your router back to the power and wait for the lights to stop flashing
Follow these steps and your internet should be working again!
Jan 14, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
My system unable to connect to server.How do I go about this problem.
First Check For bad connection Wire Betwen PC and Routers See if you have a green lignt on Connection 1-2-3 and 4 If you plug into 1 you suppose to see a green light on same on 2 3 4..Now Check inside your Control Panel if you see your network Card to be eligeble to connect to the Router Box To do So... open setting Control Panel, Network Connection ..click on local area connection ..take off the check on notify me and put it on the Show icon on notification.. Then your conected to you router ...
Oct 01, 2010 | Computers & Internet
Picks up wireless network but unable to connect to the internet. I am trying to connect to the wireless on a laptop and a phone, both work fine else where but i am unable to connect to the internet using...
what is the wireless status in system tray? is it local or local and internet.
1. first check if it works fine with wire conection or not.
2.if it fine with cable then issue is with wireless. probably issue with Wireless security key.
3. go to available wireless networks and select the net work, if it is asking for wireless key please enter that. if you donot remember that perform router reset.that takes care of it.
Sep 24, 2009 | Linksys Wireless-G WRT54G Router
Internet no longer working, but internal network is fine.
i agree with all the above.. it's definately clear as mud how the network is designed and or funtioning. The machines connected to the wireless d-link router.. are they via cat5 inthe wired ports or wireless ? is the server the machine thats connecting to the switch and wiress router and modem? i'd say reset all switches modems routers and machines.. shut them all down.. then fire the cable modem, then the wireless router then the desktop switch then the server, the workstations and the one lonely wireless.. run "ipconfig /all" on all machines and if they aren't all sharing common ips and access, provide the results here for further investigation.
May 20, 2009 | Dell Dimension 2400 PC Desktop
Loss of internet connection to desktop with WRT 160 N
If you do this and post the results I can tell you how to configure the router as you do not need the domain:-
1. connect to modem with an ethernet cable, without the router
2. assuming it's windows, start --> control panel --> Network Connections --> double click on the Local Area Connection --> Click details and post ip address, subnet, default gateway and both dns servers
Jan 20, 2009 | Linksys WRT160N Wireless Router
Our internet went down for several hours (it was an area-wide problem with our server). Once the internet came back up, my motorola 850G router will not work. I have reset the router, but the modem light...
(It worked for me for WR850G, when I had a similar issue. However, don't know how your connection is setup.)
1. Switch-off the ISP modem that connects to the router
2. Switch off the wireless router
3. Now switch on the ISP modem
4. Switch on the wireless router
Regards,
Warija
Dec 22, 2008 | Arris Wireless G Broadband Router (wr850g)
Cant add a security password to stop others gaining access to my internet connection.
I think you try to change the password with your wireless conection, right?
Things WILL go wrong if you access the Routher wireless, use a cable when you want to make changes.
/Teis
Helpfull?
Vote!
Nov 23, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wireless
Hi there!
I want to help you out. I have some questions to ask you first:
1. What brand and model are your wireless router and laptop?
2. Does the laptop have a built-in wireless card or you installed one?
3. If it's has its built-in wireless card, check the wireless switch of the laptop. ICheck if it is on or off (some laptops sometimes has an on/off switch)
4. Check if the wireless light on your router is on (it's sometimes refered to "WLAN")
5. How many wired & wireless computers do you have and their operating system?
Your physical connections are correct. BTW, can you also specify what port from the modem is going to the router? Some routers have 1 port named "Internet or WAN" and 4 ports for "Ethernet." Check if the modem is connected to the "Internet or WAN" port.
May 04, 2008 | Computers & Internet
Sony VAIO NS Series Notebook Logo
130 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
