Question about Whirlpool Washing Machines
Whirlpool washer (model LA9100XTW1)
My Whirlpool washer (model LA9100XTW1) is releasing something during wash cycles. When I remove the clothes, there is a grease-like substance around the bottom of the tub that is getting on the clothes. Is it grease or a deteriorating belt?? Please help!
  • 24 Answers
Usually problems like this, you just have to take it apart and see. I can tell you a few things that will help though. It's not a deteriorating belt. In fact this machine doesn't have a belt at all, it's what is called "direct drive". The closest thing it has to a belt is a round piece of rubber in between a gear but that's near the motor and it's not possible for it to get inside the tub. In fact, it's hard for anything to get in there to stain clothes. Usually what causes this, is a build up of dirt, soap, mud, mold, etc that collects under the agitator and finally just gets enough to start releasing into the tub. It's pretty easy to take out the agitator and check under there, here's how.
To remove the agitator on a Whirlpool top-load washer, remove the solid cap or fabric softener dispense from the middle of the agitator. Then remove the white cap on the inside of the agitator. This might be stubborn, so just start off pulling gently and keep pulling until it comes out. Under that is a 7/16" bolt. Remove that and then the agitator will slide off the transmission shaft.
The only other option is removing the inner tub entirely, but that requires a special tool to get a nut off of the drive block, so that limits DIY repairs.
Posted on May 29, 2010
Dirt like substance coming out from the washine during wash cycle
Possible that there is dirt in the drum that comes up when the drum revolves. This can be due to dirt that had accumulated within and needs to be removed. Please try to watch this link and get some tips to clean the drum.
click on : cleaning the drain
Jan 01, 2013 | Washing Machines
Rl on the control panel
The "rl" (remove load) error code appears when you are running the "Clean Washericon1.png" cycle. You must not have a load of clothes in the washer during this cycle. Remove the clothes from the drum, and restart the cycle. The "Sud" error indicates that the detergent is over-sudsing. The Duet washer automatically combats this by reducing the amount of suds in the washing machine. Let the washer finish the suds-reduction steps. Use less detergent during the next wash cycle.
Oct 21, 2012 | Whirlpool Duet GHW9150P Front Load Washer
How do i replace the agitator in my old heavy duty whirlpool washing machone?
Hello.
The Whirlpool Ultimate Care II washing machine is atop-loading clothes washer. The washer has several cycles to choose from,including cycles for washing normal clothes, permanent press items, delicateand items marked "Hand Wash." To do its job, thewashing machine relies on an agitator, located in the center of the wash tub.The agitator rotates during the wash cycle, moving the clothes around the washtub so that they are cleaned equally. If the agitator is broken, it will notsufficiently agitate the clothes and must be replaced. ·1 Unplug the washing machine from the wall outlet or turn off the power supplyin your service panel. · 2 Open thewashing machine lid and remove any clothes remaining inside. · 3 Remove thefabric softener cup by squeezing the bottom lip of the cup and lifting itstraight off. · 4 Pry theagitator cap off of the top of the agitator with a flat-head screwdriver. · 5 Remove thebolt at the bottom of the agitator, using the socket wrench with extension, andthen remove the agitator from the washing machine. Tip the agitator to removethe bolt and washer. · 6 Install thenew agitator onto the drive shaft. · 7 Secure thenew agitator with the bolt that you originally removed. · 8 Press theagitator cap and fabric softener cup back into position on top of the newagitator. · 9 Restore powerto the washing machine to complete the repair.
Thanks.
Sep 07, 2011 | Whirlpool Washing Machines
Grease or rust ?? My front loading whirlpool duet washer is
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some degreaser added (like Goo-Gone) on the fullest/hottest setting you have.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Very loud rumbling noise during spinning
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Sep 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Grease-like stains on clothing
hi. i can help. the grease is coming from one of two places. Either some item with grease on it got placed in the machine and the grease transferred to the tub where it will cause the problem until it is spotted and removed with a degreaser, or wears off.
OR the grease is coming from the washer itself. Perhaps some grease oozed out of the mechanicals related to the aggitator.
Either way I would get a strong flash light or trouble light and look carefully in the tub and around the aggitator for grease. Then remove it with a cloth and some degreaser, available at any auto parts store.
Jun 27, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
The spin cycle for my
Dear shelldon39, Fri 2-20-2009 9:24pm EST (USA)
Some machines will shut down during the spin cycle as a precaution to prevent damage!
They will do this if you overload the washer with clothes and/or use too much detergent!
If this doesn't help please get back to me with more details!
jack
Feb 21, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
153 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
